[samba pdc]domain not found
  • Zwerver
ik heb een winxp client en een samba met de volgende conf file:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
#======================= Global Settings =====================================
[global]
workgroup = Schependom
netbios name = Nijmegen2
server string = Samba Server %v
printcap name = lpstat
load printers = yes
printing = cups
printer admin = @adm root
log file = /var/log/samba/log.%m
max log size = 50
log level = 3
security = user
encrypt passwords = yes
smb passwd file = /etc/samba/private/smbpasswd
unix password sync = Yes
passwd program = /usr/bin/passwd %u
passwd chat = *New*UNIX*password* %n\n *ReType*new*UNIX*password* %n\n *passwd:*all*authentication*tokens*updated*successfully*
username map = /etc/samba/smbusers
winbind uid = 10000-20000
winbind gid = 10000-20000
template homedir = /home/%D/%U
template shell = /bin/false
socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
os level = 99
domain master = yes
preferred master = yes
domain logons = yes
logon script = %m.bat
logon script = %U.bat
logon path = \\%L\Profiles\%U
logon drive = H:
logon home = \\%L\%u
add user script = /usr/sbin/useradd -d /dev/null -g machines -c 'Machine Account' -s /bin/false -M %u
add user script = /usr/sbin/useradd -s /bin/false %u
domain admin group = root admin administrator
name resolve order = wins lmhosts bcast
wins support = yes
dns proxy = no
client code page = 850
character set = ISO8859-1
#============================ Share Definitions ==============================
[homes]
   path = %H
   read only = no
   valid users = %S
[netlogon]
   comment = Network Logon Service
   path = /var/lib/samba/netlogon
   guest ok = yes
   read only = yes
   write list=@admin
[Profile]
    path = /var/lib/samba/profiles
    browseable = no
    guest ok = yes
[printers]
   comment = All Printers
   path = /var/spool/samba
   browseable = no
# to allow user 'guest account' to print.
   guest ok = yes
   writable = no
   printable = yes
   create mode = 0700
   print command = lpr -P %p %s # using cups own drivers (use generic PostScript on clients).
   lpq command = lpq -P %p
   lprm command = cancel %p-%j
[print$]
   path = /var/lib/samba/printers
   browseable = yes
   read only = yes
   write list = @adm root
En tot mijn verdriet krijg ik bij het aanmelden de melding:
.... Domain not found .....
Waarna ik moet inloggen op de local computer, waar dan (tot mijn verbazing) ineens wel op het domain aangelogt is :?
Ik snap het niet. Ik wil graag gewoon aankunnen melden zonder die foutmelding van XP. Is dit een XP bug en zit dit niet in NT/2000/9xofME? want ik kan dit niet testen hier.
Lay outje
Woonachtig Down Under. Ik negeer je insults niet, maar tegen de tijd dat ik ze lees zijn ze meestal niet relevant meer
  • Zwerver
**kick na een dag**
  • Dionysus007281
  • Laatst online: 07-07 17:03
Dionysus007281
Spank my monkey!
Probeer eens in lokaal beveiligingsbeleid => beveiligingsopties => "Lid van domein: gegevens in digitaal kanaal coderen of ondertekenen (altijd)" uit te zetten. Ik weet dat dat wel eens probs kan opleveren.
Dual Opteron 248 Nu met Asus X800XT PE @ X850XT PE Server.
  • Zwerver
is al uit, stond ook in de howto (ibm en samba)
