Philips 180P1B TFT scherm
  • 40 views sinds 30-01-2008
  • Leader98
  • Laatst online: 20:25
Nu in de aanbieding bij Paradigit:
Philips 180P1B TFT scherm voor 799 euro :)
Het plaatje wat erbij staat klopt niet (het is de 180P2B). Nu wil ik graag de specs van dit scherm weten. Google geeft wel wat sites maar tot nu toe nog geen handige info.
Zijn er tweakers die dit scherm of informatie hierover hebben, of weten te staan op het web?
  • mindcre8r
  • Laatst online: 27-08 08:58
mindcre8r
Tradepedia
UTFSE! :)
Main Specifications
Viewable Size 18.1"
Product Description Philips Brilliance 180P2B - flat panel display - TFT - 18.1"
Digital Video Standard Digital Visual Interface (DVI)
Image Aspect Ratio 4:3
Diagonal Size 18.1"
Power Consumption Operational 48 Watt
Colour support 24-bit (16.7M colours)
Max Resolution 1280 x 1024 / 75 Hz
Dot Pitch 0.28 mm
Dimensions (WxDxH) 39.9 cm x 18 cm x 40.3 cm
Compliant Standards UL, CSA, FCC-B, SEMKO, CE, MPR-II, NUTEK, TUV/GS, TCO '99, DDC-2B , EPA Energy Star
Power AC 110/220 V ± 20% (50/60 Hz)
Device Type Flat panel display / TFT active matrix - desktop
Weight 7 kg
General
Compatibility PC
Height 40.3 cm
Depth 18 cm
Width 39.9 cm
Display Type Flat panel display / TFT active matrix - desktop
Enclosure Color Beige
Weight 7 kg
Miscellaneous
Environmental Parameters Temperature: 5 °C - 35 °C Humidity: 20 - 80%
Mounting Kit Optional
Power
Power Device Power supply - integrated
Power Consumption Stand by /
Sleep 2 Watt
Compliant Standards EPA Energy Star
Voltage Required AC 110/220 V ± 20% (50/60 Hz)
Software / System Requirements
Software Included Drivers & Utilities
Min Operating System Microsoft Windows 95, Microsoft Windows XP, Microsoft Windows 98/ME/2000
Cable(s) / Peripheral(s)
Cable(s) Included 1 x display cable - external
Interface(s) Required
Port(s) / Connector(s) Required 1 x display / video - VGA / VBE - 15 PIN HD D-Sub (HD-15) - 1
1 x display / video - DVI-Analogue Digital - 29 PIN Combined DVI - 1
Audio Output
Type None
Video Input
Analogue video Signal RGB
Display
Display Screen Coating Anti-reflective, hard coating
Response Time 30 ms
Video Bandwidth 135 MHz
On-Screen Controls Brightness, pincushion distortion, OSD-position
Front Panel Controls Power on/off, brightness, adjust +/- , menu, mute
Factory Preset Resolution Modes 640 x 350 / 70 Hz
720 x 400 / 70 Hz
640 x 480 / 60 Hz
640 x 480 / 67 Hz
640 x 480 / 75 Hz
800 x 600 / 56 Hz
800 x 600 / 60 Hz
800 x 600 / 75 Hz
832 x 624 / 75 Hz
1024 x 768 / 60 Hz
1024 x 768 / 75 Hz
1152 x 870 / 75 Hz
1152 x 900 / 76 Hz
1280 x 1024 / 60 Hz
1280 x 1024 / 75 Hz
Max Sync Rate (V x H) 76 Hz x 82 KHz
Dot Pitch 0.28 mm
Viewable Size 18.1"
Diagonal Size 18.1"
Image Max V-View Angle +85 / -85
Image Max H-View Angle +85 / -85
Image Brightness 250 cd/m2
Image Contrast Ratio 350:1
Image Colour Temperature 9300K, 6500K
Bears and Bulls
  • Leader98
Waar heb je dit gevonden? thnx!
30 ms, ik zou gaan voor de 25 ivm ghosting
  • mindcre8r
mindcre8r
Tradepedia
zoals ik al zei: Use The F*cking Search engine :8
Tip: [Test] en dan [monitor naam] Werkt altijd prima :)
Bears and Bulls
  • mindcre8r
mindcre8r
Tradepedia
Verwijderd schreef op 11 november 2002 @ 11:14:
is niet per definitie waar.
er zijn schermen die prima gamen met 30ms rt.
Het id iid wel aan te raden maar hey 799 is niet duur en het ligt er maar net aan wat je gaat doen. ik zou iig voor de samsung gaan.. pricewatch: Samsung SyncMaster 181T (18", 25ms, D-sub/DVI-D)
Bears and Bulls
