Sanyo Z1 projector gekocht ! Kleine review
  • 291 views sinds 30-01-2008
  • tbusquet
  • Laatst online: 11-02 23:14
Ik verwijs voor mijn review even door naar het AVS-forum, dit is een hele interessante projector voor de mensen die digitaal willen gaan, maar niet zo'n enorm budget hebben (ca. 2000 euro).
Veel lees plezier !
http://www.avsforum.com/a...ad.php?s=&threadid=187284
1. Setup
Setup is so darn easy, you just put it anywhere, turn it on, using the lens shift, zoom and focus, and there you go ! Perfect centered image !!
2. Brightness
It's very very bright, just a little too bright for my taste I think, since my room is totally dark, and I have total light control even during the day.
3. Contrast
Contrast is very good, and you notice it very well in the colors.
Black is not completely black (as you would suspect from a LCD).
But since it's so bright, I'm going to try a ND-filter to bring the brightness just a tad down and getter the blacks a little blacker. Where you also notice that the contrast is very good, is in dark scenes, as you wouldn't see anything but a big grey blur on most projectors, the Sanyo gives you a very nice image, where you can still see good detail. Ok the blackest part is not black, but the image is still very watchable with dark scenes.
4. Screendoor
It's there, do you see it from about 3 meters away ? I don't !! But I never found screendoor a problem. But I can say that most people won't find it a problem.
5. Using native panel resolution with HTPC
Here comes the big catch ladies and gents ! The panel resolution is 964x544 according to the manual. So whip out powerstrip, create a custom resolution, and go.. go.. go.. That's where you're wrong. I can tell you, if you have never created custom timings, it's a bitch. The damn thing wouldn't look good, it kept on scaling, no matter what resolution I would feed it. Finally I went back to all the menu's.. found a lot of timing options, and was able to match the projector settings to the powerstrip settings. Not an easy task, but do-able if you put some time into it.
6. Noise
The thing is very very quiet when you put it in "dark-mode". And in that mode it hardly suffers any light-loss. The fan is triggered by the temperature, but after playing it for quite some time, it never became loud or very noticeable, this is also something I'm very happy with, since I can't stand loud fan noise during quiet scenes in a movie, well done Sanyo !
7. Menu's and remote-control
The menu's seem ENDLESS, there are sooo many options, so many things to try out. The menu structure takes some getting used to, but can be accessed pretty easily once you get the hang of it.
For almost everything there is a setting. The remote is excellent, very simple, back lit, and it doesn't matter where you are in the room, or where you point it at, it always works !
Now for the final pre-conclusion, this is a very very nice and easy to use machine, black-levels could be a little better, but with a grey screen or a ND-filter it will shine ! PQ is very good, none of that greenish stuff that we saw on some reviews, basically saturation is excellent. Skin tones are very good. The picture has a real punch and 3d feeling to it. Overall I give it 8 out of 10 at this point.
[JvS edit]
kleine moeite, groot plezier.
[ Voor 0% gewijzigd door JvS op 07-11-2002 15:12 ]
"What are you doing ?" "Filming this dead bird." "Why ?" "Because it's beautiful." Gratis mij quoten is verleden tijd, iedere quote van mij kost vanaf nu €1,79 excl. 19% btw ©
  • Nikel
Wat is een ND filter precies, wat kost het, en wat doet het?
  • tbusquet
ND filter is een grijsfilter, het "absorbeert" dus licht, beetje het zonnebrillen effect. Ze zijn niet zo duur, heb net even gebeld naar de fotowinkel, en een 49mm ND 2x filter kost om precies te zijn 10,66 euro.
Vraagje, waar heb je em gekocht? Amerika of Europa?
Projectors in Amerika zijn ca 60% van de prijzen die ze hier vragen, heb ik het idee!
  • tbusquet
Deze projector is nog niet eens leverbaar in America !! Enige landen die hem tot nu toe leveren zijn; Duitsland en Japan. En ja het prijsverschil is AANZIENLIJK. Ik heb hem dus uit Duitsland laten komen.
Heb je nu je menu's auf Deutsch? =o)
Ja, Duitsland is wel wat goedkoper dan Nederland. EN 2 jaar garantie ipv 1 jaar hier!
Heb je em via postorder laten komen? Welk bedrijf?
Ik wil in de loop van volgend jaar een projector kopen. Geen idee welke. liefst XGA, waarschijnljik DLP. Wordt alleen een beetje depri als ik op amerkaanse sites rondkijk!
Grote probleem met postorder is dat je niet eerst kunt kijken of JOUW projector wel ok is. Geen dode pixels etc. Maar verder heb ik nog geen slechte ervaringen met kopen via internet, moet ik zeggen!
  • tbusquet
Verwijderd schreef op 07 November 2002 @ 13:41:
Nee alle talen, dus engels. nederlands.. duits.. frans.. etc..
Sanyo geeft 3 jaar garantie op deze projector en lamp.
Maar mag ik vragen bij welk bedrijf je hem hebt gekocht?
Wil graag weten welke bedrijven in Duitsland goede service leveren bij dit soort aankopen!
=o)
3 jaar ook op lamp? WOW! Da's niet slecht!
Heb je je filter al? Scheelt het veel?
  • tbusquet
Verwijderd schreef op 07 november 2002 @ 13:51:
=o)
www.big-screen.de
Filter ga ik vanavond ophalen en proberen.
Hmmmm, genoeg keuze daar. Misschien eens een weekendje Berlijn doen =o)
Bedankt voor de link!
Veel plezier en succes met het filter!
=o)
  • tbusquet
Verwijderd schreef op 07 November 2002 @ 15:10:
=o)
Heb het filter net ff opgehaald in mijn pauze, en even voor mijn lens gehouden, het lijkt behoorlijk wat te helpen. Maar had niet echt de tijd om uitgebreid te proberen, mens moet werken heh :(
  • Thefirstikke
Ehrmmm... pics? :D
  • tbusquet
Screenshots zegen helaas niet zoveel, maar ik zal er wel een paar maken als ik klaar met tweaken ben..
  • Tele
tbusquet schreef op 07 november 2002 @ 16:30:
Pics van het apparaat zelf in actie mogen ook, word nu toch wel nieuwsgierig :)
  • tbusquet
Tele schreef op 07 november 2002 @ 23:36:
Zal vanavond eens kijken wat ik kan doen..
  • Zandor
  • Laatst online: 24-06 23:24
Ik ben benieuwd, waarom heb je niet de plv-70 gekozen.
ongeveer dezelfde prijs en meer pixels, toch?
ben benieuwd wat je overwegingen zijn...
Heb op dit moment geen geld, maar een beamer komt er zeker een keer...
[edit]
sorry heb me vergist, plv70 is veeeel duurder
[edit]
E8400, P5K EPU, patriot extreme 800 4GB, EN9600gt, hoontech dsp24v, samsung F1 1TB, dell 2407wfp, canon LBP5200
Canon 50D, 17-85IS, 28-135 IS, 100-300mm, 50mm 1.8
  • lpb
lpb
hoeveel ansilumen is die beamert eigenlijk :?
  • tbusquet
Zandor schreef op 08 November 2002 @ 19:35:
[edit]
[edit]
Dat heb je goed, die PLV-70 is idd een erg mooi apparaat, maar kost ook ongeveer 2x zoveel. Dat is dus de reden :)
  • tbusquet
(¯`;.žž.LPB.žž.;ޝ) schreef op 27 november 2002 @ 20:22:
Volgens de specs 700 lumen.
  • ShadowrunR
  • Laatst online: 12-09 23:05
Lijkt me een zeer leuk ding.
Hoewel deze cinema-projector van barco ook tof lijkt: http://www.barco.com/proj...s/product.asp?element=607 ;) 7kw lamp sterk genoeg? :p
ik zit al een tijdje te denken om een beamer aan te schaffen en dit is zeker een interessante projector die binnen mijn budget past
Waar heb je je scherm gekocht om het op te projecteren?
  • tbusquet
Verwijderd schreef op 28 November 2002 @ 15:49:
Zelf gemaakt, flinke plaat MDF en een pot-witte-latex-muurverf.
tbusquet: op http://www.projectoreurope.com is de projector in Nederland te koop. Ik heb voor de lol gebeld met bedrijf wat ie gaat kosten. Heb er nu nog geen geld voor over. Wil het dan wel netjes wegwerken in plafond, net zoals een schermpje dat je uit kan zwengelen (Hapro Projecta manual oid).
  • pyravex
  • Laatst online: 15-03-2023
pyravex
wa jij bob,stoel moet er staan
Verwijderd schreef op 29 November 2002 @ 15:03:
... en??/ share t plz :)
en hoeveel lichtopbrengst is eigenlijk gewenst?
wanneer word het te fel enz?
|we live in the history of a mad man Mr. G |
  • tbusquet
pyravex schreef op 03 December 2002 @ 09:52:
Daar heb ik een kleine FAQ voor geschreven.
Enige uitleg voor mensen die een projector willen kopen !
  • pyravex
pyravex
die had ik al gelezen
goeie uitleg btw tenminste normaal nederlands
maar isser niert een vuistregel waarmee je na kan gaan of het wel genoeg licht is zeg maar??
Hehe 2100 EX BTW, dus beter zoals The Busquet naar Duitsland. Wel lachen kerel, maar leek erop dat ze ze zelf ook uit Duitsland haalde en gewoon winst er weer op knallen.
  • ErikRo
  • Laatst online: 26-08 18:02
tbusquet,
Ik zit zelf ook te denken aan de Sanyo, maar ik twijfel ook nog over de infocus X1. Prijs zou ongeveer hetzelfde moeten zijn. Heb jij deze nog in je keus overwogen en wat was dan jouw reden om toch voor de Z1 te kiezen?
ps hoe is het met je ND filter afgelopen? was het wat?
[ Voor 12% gewijzigd door ErikRo op 06-12-2002 00:23 ]
"I don't have any solution but I certainly admire the problem." -- Ashleigh Brilliant
  • ErikRo
Ik zag vandaag zelfs een partijtje bij MediaMarkt Arena voor €2400 inc.
Een leuk, kleine PJ met mooi beeld. Er was wat screendoor te zien, maar alleen als je er echt op lette, zodra je de film keek viel het al snel niet meer op.
Maar goed hij is dus nu zelfs in NL te koop.
Btw toen ik vertelde dat hij in duitsland voor maar 2000 te koop was ging na even bellen 150 van de priojs af. Weliswaar geen €2000, maar je kan hem dan wel eerst testen op pixelfouten etc.
Misschien dat als ik was doorgegaan, de prijs nog iets meer naar beneden had kunnen krijgen.
