Wine install 2 probs
  • 57 views sinds 30-01-2008
Tijdens mijn install van wine...... stuit ik op 2 kleine problemen!
ik ben de howto van een site aan t volgen.
Before you try to install Wine it is a good idea to run winecheck,type ./tools/winecheck
Dat doe ik dus en krijg ik t volgende
[Simon@kf-ijss-tg01-0490 wine-20021031]$ ./tools/wineinstall
WINE Installer v0.73
Running configure...
./configure: line 85: conftest.sh: No such file or directory
./configure: line 86: conftest.sh: No such file or directory
chmod: failed to get attributes of `conftest.sh': No such file or directory
./configure: line 198: conf1638.file: No such file or directory
./configure: line 946: config.log: No such file or directory
Configure failed, aborting install.
[Simon@kf-ijss-tg01-0490 wine-20021031]$ kopete
[Simon@kf-ijss-tg01-0490 wine-20021031]$ ./tools/winecheck
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LANG = "nl_NL.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
This script verifies the configuration of the whole Wine environment.
Note that this is an ALPHA version, and thus it doesn't catch all problems !
The results of the checks are printed on the right side:
OK - test passed without problems.
NOTICE - Not a problem but something for the user to be aware of.
SUSPICIOUS - potentially problematic. You might want to look into that.
BAD - This is a problem, and it leads to configuration score penalty.
CRITICAL - A critical problem which can easily lead to malfunction.
FAILED - This problem leads to Wine failure almost certainly.
The result will be printed as a percentage score indicating config completeness.
------------------------- checking miscellaneous stuff -------------------------
001. Checking for root user... OK.
--------------------------- checking Wine base files ---------------------------
002. Checking for file "wine"... which: no wine in (/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/home/Simon/bin)
FAILED (file not found).
- ADVICE: Make sure the "wine" command is in your PATH (echo $PATH; export PATH=xxx).
003. Checking for correct .so lib config (please wait)... OK.
----------------------------- checking config file -----------------------------
004. Checking config file access... readline() on closed filehandle CFGFILE at ./tools/winecheck line 523.
FAILED (/home/Simon/.wine/config does not exist).
- ADVICE: it is ok in case you have ~/.winerc. If you don't, then you're in trouble.
--------------------- checking system devices used by Wine ---------------------
005. Checking sound device /dev/dsp... OK.
006. Checking audio mixer device /dev/mixer... OK.
007. Checking MIDI sequencer device /dev/sequencer... OK.
----------------------- checking registry configuration ------------------------
008. Checking availability of winedefault.reg entries... CRITICAL (entry "SHAREDMEMLOCATION" not found in system.reg registry file).
- ADVICE: file winedefault.reg, the most basic wine registry environment, doesn't seem to have been applied using regapi.
009. Checking availability of windows registry entries... NOTICE (entry "Default Taskbar" not found).
- ADVICE: A Windows registry does not seem to have been added to Wine as this typical Windows registry entry does not exist in Wine's registry. A complete original Windows registry entry set will *not* be available with a no-windows install. Usually this will present no problem in running applications although this can affect newer programs.
9 tests. 0 suspicious, 0 bad, 1 critical, 2 failed.
T is ff wa tekst.. :D
En dan t volgende.....
The configuration of WINE
in order to run Wine needs some files and directories.
First you must create a virtual ('fake') windows drive
The following directories mut exist in your $HOME directory:
.wine
.wine/c_drive
.wine/c_drive/Windows
.wine/c_drive/Windows/Fonts
.wine/c_drive/Windows/Start Menu/Programs .wine/c_drive/Windows/System
.wine/c_drive/Windows/System32
.wine/c_drive/Windows/Temp .wine/c_drive/Program Files
.wine/c_drive/Program Files/Common Files
After this copy the following files from wine-20021007/documentation/samples to $HOME/.wine/Windows:
system.ini and win.ini
All applications will be installed on this fake Windows drive.
Wine also needs a configuration file. Copy the file config from wine-20021007/documentation/samples to $HOME/.wine.
Ik heb een 'fake' windows drive..
maar de rest.
P.S. men ICQ is 137118029
Alvast bedankt
  • Jordi
Jordi
#1#1
Dit topic dicht op verzoek van topicstarter.
Het zal wel niet, maar het zou maar wel.
