error branden iso / cue files nero
  • wvkreg
  • Laatst online: 07-09 11:17
Ik heb de FAQ gelezen, bios update gedaan, firmware updates gedaan en ook sp 1 installed. Toch krijg ik bij het burnen van een .cue file heel vaak deze error.
Windows XP 5.1
WinAspi: -
ahead WinASPI: File 'C:\Program Files\ahead\Nero\Wnaspi32.dll': Ver=2.0.1.50, size=131072 bytes, created 25-6-2002 17:34:54
Nero Version: 5.5.9.14
Recorder: <LITE-ON LTR-40125W> Version: WS01 - HA 2 TA 0 - 5.5.9.14
Adapter driver: <atapi> HA 2
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <Image Simulation> Version: 1.0g - HA 0 TA 0 - 5.5.9.14
Adapter driver: <PrecSim> HA 0
Bus Type : default (0) -> SCSI, detected: ?
=== Scsi-Device-Map ===
CdRomPeripheral : Image Simulation 1.0g PrecSim Port 0 ID 0 DMA: ?
DiskPeripheral : Maxtor 52049H3 atapi Port 1 ID 0 DMA: On
DiskPeripheral : MAXTOR 6L060J3 atapi Port 1 ID 1 DMA: On
CdRomPeripheral : LITE-ON LTR-40125W atapi Port 2 ID 0 DMA: On
CdRomPeripheral : PIONEER DVD-ROM DVD-116 atapi Port 2 ID 1 DMA: Off
DiskPeripheral : MAXTOR 4K060H3 A08. hpt3xx Port 3 ID 0 DMA: ?
OtherPeripheral : HPT RCM DEVICE hpt3xx Port 3 ID 0 DMA: ?
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 61865984 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523756kB)
Free physical memory: 245MB (251860kB)
Memory in use : 51 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Enabled (1)
Wizard: Off
5.11.2002
CueSheet
16:41:45 #1 Phase 90 File dlgbrnst.cpp, Line 1571
Buffer Underrun Protection activated
16:41:45 #2 Text 0 File Reader.cpp, Line 118
Reader running
16:41:45 #3 Text 0 File Writer.cpp, Line 127
Writer LITE-ON LTR-40125W running
16:41:45 #4 Text 0 File Burncd.cpp, Line 3588
Turn on Track-At-Once, using CD-R/RW media
16:41:45 #5 Text 0 File ThreadedTransferInterface.cpp, Line 660
Setup items (original item values)
0: TRM_DATA_RAW_MODE1 (Cue Sheet Track)
2 indices, index0 (150) provided
original CD pos #0 + 322431 (322431) = #322431/71:39.6
relocatable, CD pos for caching/writing not required/not required, no patch infos
16:41:46 #6 Text 0 File DlgWaitCD.cpp, Line 203
Last possible write address on media: 359845 (79:59.70)
Last address to be written: 322430 (71:41.05)
16:41:46 #7 Text 0 File DlgWaitCD.cpp, Line 208
Write in overburning mode: FALSE
16:41:46 #8 Text 0 File DlgWaitCD.cpp, Line 1420
Recorder: LITE-ON LTR-40125W;
CDRW code: 00 97 26 66; OSJ entry from: CMC Magnetics Corporation
ATIP Data:
Special Info [hex] 1: D0 00 90, 2: 61 1A 42 (LI 97:26.66), 3: 4F 3B 47 (LO 79:59.71)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid)
16:41:46 #9 Text 0 File ThreadedTransferInterface.cpp, Line 812
Prepare recorder LITE-ON LTR-40125W for write in TAO
DAO infos:
MCN:
TOCTYPE: 0x0 Close CD
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 660645888
16:41:46 #10 Text 0 File ThreadedTransferInterface.cpp, Line 840
Removed 2 run-out blocks from end of track 1.
16:41:46 #11 Text 0 File ThreadedTransferInterface.cpp, Line 660
Setup items (after recorder preparation)
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 322429 blocks [LITE-ON LTR-40125W ]
16:41:46 #12 Phase 32 File dlgbrnst.cpp, Line 1571
Simulation started at 24x (3.600 kB/sec)
16:41:46 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1948
Verifying CD position of item 0 (relocatable, no CD pos, no patch infos, orig at #0): write at #0
16:41:46 #14 Text 0 File Mmc.cpp, Line 17168
Set BUFE: supported -> ON , SMART-BURN : ON
16:42:31 #15 TRANSFER -1 File ThreadedTransfer.cpp, Line 1225
Algemene fout
16:42:31 #16 Text 0 File ThreadedTransfer.cpp, Line 222
all writers idle, stopping conversion
16:42:32 #17 Text 0 File ThreadedTransfer.cpp, Line 216
conversion idle, stopping reader
16:42:32 #18 CDR -201 File WriterStatus.cpp, Line 147
Invalid write state
16:42:32 #19 TRANSFER -18 File WriterStatus.cpp, Line 147
Could not perform EndTrack
16:42:36 #20 Phase 34 File dlgbrnst.cpp, Line 1571
Simulation failed at 24x (3.600 kB/sec)
16:42:36 #21 Text 0 File Scsicmd.cpp, Line 402
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=5.3.1.158, size=23420 bytes, created 15-10-2002 13:14:38
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 29-8-2002 10:27:50 (Adapter driver for rec)
File 'Drivers\precsim.sys': Ver=1.14.0.0, size=62688 bytes, created 26-4-2002 0:00:00 (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Wat is hieraan te doen?
  • golfdiesel
  • Laatst online: 20:22
Is het probleem dat de schrijver begint met schrijven maar niet verder dan de lead-in komt? Je hebt een lite-on schrijver, gaat het ledje oranje/geel branden en gebeurd er verder niets?
dat probleem heb ik ook met cue-sheets, met verschillende brand programma's.
"I love the smell of burning diesel in the morning. It smells like ... victory!"
  • Angels2
  • Laatst online: 15-03-2025
Haal eens je naam en serienummer van de log af...
CMC staat als discfabrikant niet echt hoog aangeschreven. Misschien kan je brander er niet goed mee overweg en gaat daarom de fout in.
Je kan iso's ook eerst rippen met bv. Isobuster (www.isobuster.com) en dan de files zelf.branden.
  • wvkreg
Ik denk meer dat het aan de kwaliteit van de cue files en de iso files ligt, omdat het met andere files wel lukt. Alleen files van Sharereactor.com werken niet / nooit.
Oh en waarom staat op de Pioneer DVD de DMA off??
Iso Buster gedownload: even de files naar HDD proberen te extracten.
Volgende error.
Afbeeldingslocatie: http://home.wanadoo.nl/wvkreg/error.jpg
en wat doet deze newbie nou weer fout met plaatjes posten??
Grrr
Wim <<<--- Dummie
[ Voor 0% gewijzigd door wvkreg op 07-11-2002 19:39 . Reden: meer data ]
  • McKaamos
McKaamos
Master of the Edit-button
wvkreg schreef op 07 november 2002 @ 18:27:
Volgende error.
Grrr
Wim <<<--- Dummie
dus het is alleen met een bepaalde ISO file zo?
dan moet je gewoon een andere ISO inlezen (van een CD) of downloaden.
en plaatjes posten doe je zo:
[img]http://www.jouwplaatjes.nl/Wim_dummie/foutmelding.jpg[/img]
das dus met brackets en niet met pijltjes.
en ook zonder spaties.
de link liever ook zonder spaties, en als et onvermijdelijk is maak er dan "%20" van in de link.
en DMA off/on kan je wel in windows wijzigen (werk zelf niet met XP dus ik weet niet waar) als de DVD al bij het starten van je PC aangeeft dattie op ATA of UDMA mode draait.
alssie aangeeft dattie op PIO4 werkt zal DMA dus niet werken.
  • chucky666
chucky666
d.y.w.play?
dma in windowsxp > configuratie scherm>systeem>hardware>apparaatbeheer>ide ata/atapi controller>primairy ide>geavanceerd.
een OW voor blaten in de IT? laat IT dan maar voortaan links liggen :(
  • wvkreg
Het is inderdaad alleen met cue en iso files van Sharereactor, semi legaal denk ik? Het zal dus wel aan hun liggen. Mijn DVD speler zit als slave op secondary ide port en al stel ik hem in op DMA if available in Win XP , maar hij blijft staan op PIO mode? Het zal wel...
  • McKaamos
McKaamos
wvkreg schreef op 07 November 2002 @ 19:40:
hm jah zou kunnen dattie in windows wel DMA aangeeft (als optie instelling), maar dat de DVD dat eigenlijk niet ondersteunt.
lijstje met IDE Modi:
ATA133 (UDMA133)
ATA100 (UDMA100)
ATA66 (UDMA66)
ATA33 (UDMA33) <-Meeste cdspelers en branders, is maximum voor 40 pins IDE kabel
PIO4
PIO3
PIO2
PIO1
Als je IDE apparaat aangeeft PIO mode4 te kunnen tijdens het starten zal hij nooit hoger komen. zelfs als je DMA mode aanzet in windows.
Als hij aangeeft dat hij ATA33 (UDMA33) is, zal de DMA mode inschakelen in windows een CPU load verlichting en een snelheidswinst opleveren.
Hoger dan de aangegeven snelheid zal het apparaat ook nooit komen.
  • wvkreg
Kan het kloppen dat mijn dvd speler op PIO mode 4 draait. dat zie ik nl in apparaatbeheer. Ik neem aan dat ik dan een verkeerde flatcable gebruik, hoewel de cdrw draait wel gewoon udma2. Ik heb een Epox KTA3+ bord en kan evt ook op de RAID aansluitingen nog apparaten aansluiten. Pls advise...
  • NLuna
  • Laatst online: 01-06-2023
probeer eens CDRWIN 5 dat gebruik ik ook altijd om .CUE en .BIN files te branden en het werkt altijd...
Specs | P5Q-E P45| C2D E8400 E0 @4.0GHz | Scythe Mugen | TWIN2X4096-8500C5DF | GTX260-216 Black Edition | Dell UltraSharp 2209WAf
  • Speedy
  • Laatst online: 06:46
Als het alleen met een bepaald programma is kan het natuurlijk zijn dat het cue sheet verkeerd is. ff editten met wordpad en grote kans dat hij dan wel werkt.
Verder probeer te branden met CDRWIN 3.8/4 (5 is van andere fabrikant en imho minder prettig, maar dat is persoonlijk), ik heb daar in principe nooit problemen mee.
Flickr | Lego collectie
nero brandt bij mij geen enkele cue file met iso. Ik gebruik fireburner hiervoor, heel simpel programmatje en brandt al m'n cues perfect!!!
  • chucky666
chucky666
d.y.w.play?
wvkreg schreef op 26 November 2002 @ 11:10:
op je raid zou ik in ieder geval geen dvd/cd/cd-rw drives opzetten.
hiervoor gaarne alleen hd's gebruiken.
als je dvd speler op pio4 draait en je brander op dma dan is de kabel goed :)
het kan zijn dat je dvd speler geen dma ondersteund, of dat er een jumper omgezet moet worden achterop de speler.
  • pstalman
  • Laatst online: 07-09 16:41
Bekende problemen met iso's.
Ik kon eigenlijk nooit op de goede manier een iso branden met nero... tot ik het volgende probeerder
start nero, roep wizzard op. Kies dan:
cd next, nieuw cd next, andere cd-types next, cd van image bestand aanmaken next, kies dan branden (NEE NERO GAAT DAN NOG NIET FIKKEN) want je kiest IMAGE maken.
NU maakt nero van jou iso een NRG bestand, dit gaat vaak wel goed.
https://d4armory.io/Player/803500
  • ajslaghu
  • Laatst online: 23-08 12:20
problemen met aopen / liteon (schijnen hetzelfde te zijn) is dat de brander op de primary slave moet. Daarvoor had ik errors met mp3's branden , iso s en de aspi ondersteuning. Het probleem schijnt zich vaak voor te doen want ik zie het vaak bij vrienden. Ik zelf heb 3 keer mijn brander geruilt (en dan deed hij het weer een tijdje om na een tiental cd's te stoppen) .
Tevens nieuwste nero / CDRW firmware / bios .
Bij oude versies van nero crashede branders on der xp nog wel eens bij het uitwerpen. dit omdat de brander nog niet klaar met de lead-out.
CDRW liet zich bij ook niet updaten , zodra die aan de primary slave hing deed hij het wel. Bizarre materie die branders.
Errors in iso's kan ik je ook niet aan helpen.
Goede manier om iso's te testen is met daemon tools . dan mount je de iso op je harddisk, als cdom, kan je de installatie draaien en testen. (ik brand eigenlijk niet meer sinds dit kan, binnenkort extra hardeschijf nodig)
Als je het absurde aanneemt, kan je het tegenover gestelde bewijzen ??
  • wvkreg
Brander op de primary slave?? Maar ik heb een probleem met de dvd pioneer lezer. Ik neem dan ook aan dat ik niets hoef te veranderen. De lezer zit als secondary slave en de brander op secondary master. De kabel is dus goed. Ik snap het allemaal niet zo meer. De brander is een Lite On.
  • chucky666
chucky666
d.y.w.play?
wvkreg schreef op 26 November 2002 @ 21:37:
nee, is niet nodig :)
rustig maar ;)
ik heb ook me lite-on fikker op me secondary master staan en me dvd speler erbij als slave :)
niets aan de hand :)
  • wvkreg
Owww vreemd......Nou bedankt allemaal, dan kunnen we het topic sluiten.
Ik pruts wel zo verder... :) Het is nu opgelost, ik heb de brander en de dvd omgedraaid en op cable select gezet, ze draaien nu in goede UDMA modus.
Thx all
[ Voor 42% gewijzigd door wvkreg op 15-12-2002 12:08 . Reden: oplossing ]
