hoi,
ik wil via ADSI informatie uit onze AD server halen.. daarvoor heb ik dit scriptje :
Maar deze komt terug met een 0x80005000L E_ADS_BAD_PATHNAME error melding.
maar met dit script :
heb ik de gehele path directory gekregen. dus die is wel goed
wat doe ik nou fout?
edit: sorry voor de layout
| Dim userObj
Set dso =GetObject("LDAP:")
ad = "LDAP://d1lon100/CN=Coolegem\, Arjan,OU=Users & Groups,OU=EUR,DC=D1,DC=AD,DC=APL,DC=com"
username = "apl\acoolege"
password = "<nietzichtbaar>"
Set userObj = dso.Opendsobject(ad,username,password,0)
Response.Write("<BR>" & ad & "<BR>")
Set userSchema = GetObject(userObj.schema)
Response.Write "The sample values... <BR>"
With userObj
Response.Write "<B>User Display: </B>" & .displayName & "<BR>"
Response.Write "<B>Manager: </B>" & .manager & "<BR>"
Response.Write "<B>Adsi Path: </B>" & .ADsPath & "<BR>"
Response.Write "<B>Department: </B>" & .Department & "<BR>"
Response.Write "<B>Last Login: </B>" & .LastLogin & "<BR>"
Response.Write "<B>countryCode: </B>" & .countryCode & "<BR>"
Response.Write "<B>userPassword: </B>" & .userPassword & "<BR>"
Response.Write "<B>Phone Number: </B>" & .telephoneNumber & "<BR><BR>"
End With |
| SQLStmt = "SELECT * FROM 'LDAP://d1rot100/OU=Users & Groups,OU=EUR,dc=d1,dc=ad,dc=apl,dc=com' WHERE objectClass='*'"
Set Conn = CreateObject("ADODB.Connection")
Conn.Provider = "ADSDSOObject"
Conn.Open "ADs Provider","apl\acoolege","<niet zichtbaar>"
Set rs = Conn.Execute(SQLStmt)
Do While Not rs.EOF Or rs.BOF
ReturnValue = rs.Fields(0)
If IsArray(ReturnValue) Then
For I = LBound(ReturnValue) To UBound(ReturnValue)
If ReturnValue(I) <> "" Then
Response.Write ReturnValue(I) & "<BR>"
End If
Next
Else
Response.Write ReturnValue & "<BR>"
End If
rs.MoveNext
Loop |
