Ik heb wel iets gevonden zoals hieronder maar ik heb dit van Microsoft Q280821 als je dit artikel erbij pakt staan er ook meer oplossingen bij.
Method 2: Reset the Word Data Key in the Windows Registry
WARNING: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk.
If Word is installed on your computer but was once running from the network, and there is a long delay when you open documents when not connected to the network, try the following procedure.
The Word Data key stores information that is specific to the printer that is installed. To remove this printer information from Word, rename or delete the Word Data key in the Windows registry. When you restart Microsoft Word, Word recreates the Word Data key automatically.
NOTE: After you rename or delete the Word Data key, some settings in Microsoft Word are reset to their default settings.
To rename or delete the Word Data key in the Windows registry, follow these steps:
Quit all Windows programs.
Click Start and then click Run.
In the Open box, type Regedit and then click OK.
Open the following registry key:
HKEY_CURRENT_USER\Software\Microsoft\Office\9.0\Word
Under the Word key, click the Data subkey.
On the Edit menu, click Rename or Delete.
Click Yes if the following message appears:
Are you sure you want to delete this key?
On the Registry menu, click Exit.
After you rename or delete the Word Data key, click Run on the Windows Start menu.
In the Open box, type Winword.exe /R /Y, and then click OK.
Ik hoop dat je er wat aan hebt
