vraag over boot messages (dmesg)
  • 68 views sinds 30-01-2008
1 ) Linux version 2.2.20ext3 (root@conn6m) (gcc version 2.7.2.3) #6 Thu May 2 12:00:25 2002
2 ) BIOS-provided physical RAM map:
3 ) BIOS-e820: 0009f000 @ 00000000 (usable)
4 ) BIOS-e820: 07eae000 @ 00100000 (usable)
5 ) Detected 927125 kHz processor.
6 ) Console: colour VGA+ 80x25
7 ) Calibrating delay loop... 1848.11 BogoMIPS
8 ) Memory: 127180k/130744k available (1560k kernel code, 416k reserved, 1496k data, 92k init)
9 ) Dentry hash table entries: 16384 (order 5, 128k)
10 ) Buffer cache hash table entries: 131072 (order 7, 512k)
11 ) Page cache hash table entries: 32768 (order 5, 128k)
12 ) Intel machine check architecture supported.
13 ) Intel machine check reporting enabled on CPU#0.
14 ) 256K L2 cache (8 way)
15 ) CPU: L2 Cache: 256K
16 ) CPU: Intel Pentium III (Coppermine) stepping 0a
17 ) Checking 386/387 coupling... OK, FPU using exception 16 error reporting.
18 ) Checking 'hlt' instruction... OK.
19 ) Checking for popad bug... OK.
20 ) POSIX conformance testing by UNIFIX
21 ) PCI: PCI BIOS revision 2.10 entry at 0xfc0ce
22 ) PCI: Probing PCI hardware
23 ) Linux NET4.0 for Linux 2.2
24 ) Based upon Swansea University Computer Society NET3.039
25 ) NET4: Unix domain sockets 1.0 for Linux NET4.0.
26 ) NET4: Linux TCP/IP 1.0 for NET4.0
27 ) IP Protocols: ICMP, UDP, TCP
28 ) TCP: Hash tables configured (ehash 131072 bhash 65536)
29 ) Starting kswapd v 1.5
29 ) parport0: PC-style at 0x378 (0x778), irq 7 [SPP,ECP,ECPPS2]
30 ) Serial driver version 4.27 with no serial options enabled
31 ) ttyS00 at 0x03f8 (irq = 4) is a 16550A
32 ) ttyS01 at 0x02f8 (irq = 3) is a 16550A
33 ) RAM disk driver initialized: 16 RAM disks of 4096K size
34 ) loop: registered device at major 7
35 ) PCI_IDE: unknown IDE controller on PCI bus 00 device f9, VID=8086, DID=2411
36 ) PCI_IDE: not 100% native mode: will probe irqs later
37 ) hda: QUANTUM FIREBALLP AS20.5, ATA DISK drive
38 ) hdc: _NEC DV-5800A, ATAPI CDROM drive
39 ) ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
40 ) ide1 at 0x170-0x177,0x376 on irq 15
41 ) hda: QUANTUM FIREBALLP AS20.5, 19595MB w/1902kB Cache, CHS=2498/255/63
42 ) hdc: ATAPI 48X DVD-ROM drive, 512kB Cache
43 ) Uniform CD-ROM driver Revision: 3.11
44 ) Floppy drive(s): fd0 is 1.44M
45 ) FDC 0 is a National Semiconductor PC87306
46 ) ppa: Version 2.07 (for Linux 2.2.x)
47 ) WARNING - no ppa compatible devices found.
As of 31/Aug/1998 Iomega started shipping parallel
port ZIP drives with a different interface which is
supported by the imm (ZIP Plus) driver. If the
cable is marked with "AutoDetect", this is what has
happened.
48 ) imm: Version 2.03 (for Linux 2.0.0)
49 ) scsi : 0 hosts.
50 ) scsi : detected total.
51 ) NET3 PLIP version 2.3-parport gniibe@mri.co.jp
52 ) plip0: Parallel port at 0x378, using IRQ 7
53 ) early initialization of device plip0 is deferred
54 ) SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256).
55 ) 3c59x.c 18Feb01 Donald Becker and others http://www.scyld.com/network/vortex.html
56 ) eth0: 3Com 3c905C Tornado at 0xec80, 00:06:5b:10:59:42, IRQ 5
8K byte-wide RAM 5:3 Rx:Tx split, autoselect/Autonegotiate interface.
MII transceiver found at address 24, status 782d.
Enabling bus-master transmits and whole-frame receives.
57 ) Partition check:
hda: hda1 hda2 < hda5 >
58 ) VFS: Disk change detected on device fd(2,60)
59 ) RAMDISK: bzip2 Compressed image found at block 867
60 ) aaaiiiiiiiiiiiiioooooooooooooooooooooooooooooboiiiiiiiiiiioooooooooooooooooooooooooooooooboiiooooooooooooobfff
61 ) bzip2_out:0x00253000
62 ) bytes_out:0x00253000
63 ) NTFS version 000607
64 ) VFS: Mounted root (minix filesystem).
65 ) Freeing unused kernel memory: 92k freed
66 ) Linux PCMCIA Card Services 3.1.29
kernel build: 2.2.20ext3 unknown
options: [pci] [cardbus]
67 ) PCI routing table version 1.0 at 0xfbc30
68 ) Intel ISA/PCI/CardBus PCIC probe:
no bridges found.
69 ) ds: no socket drivers loaded!
70 ) eth0: Initial media type Autonegotiate.
71 ) eth0: MII #24 status 782d, link partner capability 4461, setting full-duplex.
kan er iemand mij a.u.b. vertellen wat bovenstaande allemaal betekent.
Heb het nodig voor school
please
  • flat
behalve regel 60 lijkt 't me toch allemaal vrij duidelijk, niet?
btw: als je voor school is, lijkt 't me verstandig om 't zelf uit te zoeken. daar leer je namelijk veel meer van :)
"Happiness is a way of travel, not a destination."
--Roy Goodman
Ik ben 2 dagen bezig geweest met het zoeken de betekenis van de termen die in deze lijst voorkomen.
Maar kan vele van de termen niet vinden
als ik bv naar "hash table" zoek dan vind ik "frutsel tabel".
Dit lijkt me in de "OS" wereld niet de juiste omschrijving.
Ik kom bijvoorbeeld niet te weten waarvoor een hash table dient.
Een groot aantal punten uit de lijst begrijp ik wel, alleen die afkortingen zijn voor mij nog niet duidelijk.
ik weet in iedergeval wat BogoMips nu betekend.
Milioen Instructions Per Second
Dit zou een indicatie geven hoe snel je prossesor is.
  • alt-92
alt-92
ye olde farte
Verwijderd schreef op 03 november 2002 @ 10:19:
[google=hash table entries]
levert als eerste hit al op:
The Hash Table Library
http://www.math.utah.edu/~beebe/software/hash/hash_toc.html
* What are Hash Tables?
  • arikkert
  • Laatst online: 15:34
nodig voor school ?
vraag een andere afstudeeropdracht :*) :*)
  • Pantagruel
  • Laatst online: 19-08 21:19
Pantagruel
Mijn 80486 was snel,....was!
Zo her en der wat ingevuld, sommige zijn inkoppertjes hoor !
1 ) Gebruikte linux kernel ver, gcc ver en date stamp van bak
BIOS gegevens ?
5 ) 927 MHz CPU-tje
6 ) Console frequentie VGA 80kolomenx25regels
7 ) Calibrating delay loop... 1848.11 BogoMIPS rekenkracht van je CPU in BogoMIPS
8 ) Memory: 127180k/130744k available (1560k kernel code, 416k reserved, 1496k data, 92k init) geheugen ruimte wat vrij is en in gebruik
9 ) geen idee, do we care?
10 ) geen idee, do we care?
11 ) geen idee, do we care?
12 ) CPU check mogelijk
13 ) Ja CPU check op 1e CPU
14 ) 256K L2 cache (8 way) cache samenstelling
15 ) CPU: L2 Cache: 256K cache groote
16 ) CPU: Intel Pentium III (Coppermine) stepping 0a, inkoppertje
17 ) fpu AANWEZIG
18 ) HALT functie aanwezig (energie beheer)
19 ) bug check
20 ) compat. test
21 ) PCI BIOS revisie gegevens
22 ) PCI: Probing PCI hardware wat denk je ?
23 ) netwerkgedoe
24 ) netwerkgedoe
25 ) netwerkgedoe
26 ) netwerkgedoe TCP/IP
27 ) IP Protocols beschikbaar: ICMP, UDP, TCP
28 ) TCP Hash aanwezig
29 ) swap aan
29 ) printerpoortje
30 ) serieele aansturing
31 ) com-1
32 ) com-2
33 ) RAM disk
35 ) IDE controller probe
36 ) IDE controller gevonden
37 ) 1e IDE device
38 ) 3e IDE device
39 ) ATA kanaal 1 irq en i/o
40 ) ATA kanaal 2 irq en i/o
41 ) hdd = QUANTUM FIREBALLP AS20.5, 19595MB w/1902kB Cache, CHS=2498/255/63
42 ) cdrom = ATAPI 48X DVD-ROM drive, 512kB Cache
43 ) CD-ROM driverused
44 ) Floppy drive= 1.44M
45 ) floppy controller
47 ) storage devices op de printerpoort ??
49 ) scsi detect niets
50 ) dus geen scsi device listing
51 ) netwerk via par-poort mogelijk ?
52 ) Ja,plip0: Parallel port at 0x378, using IRQ 7
54 ) SLIP activering vor PLIP netwerk
55 ) van wie is die 3com kernel driver ook al weer ??
56 ) 3Com 3c905C Tornado gevonden op irq en i/o
57 ) partitie check
58 ) file system gevonden
59 ) compressed ramdisk ??
60 ) errrhhhhhhhhhhhhh
61 ) ??
62 ) ??
63 ) NTFS versie 000607
64 ) Root systeem gemount = minix filesystem
65 ) ongebruikte gehuen ruimte van kernel laden legen
66 ) LPCMCIA device driver ver
68 ) Geen cardbus cpic aanwezig
Asrock Z77 Extreme6, Intel i7-3770K, Corsair H100i, 32 GB DDR-3, 256 GB Samsung SSD + 2 x 3TB SATA, GeForce GTX 660 Ti, Onboard NIC and sound, SyncMaster 24"&22" Wide, Samsung DVD fikkertje, Corsair 500R
VFS: virtual File System?
POSIX: is een geheel van standaarden voor interfaces welke op het UNIX besturingssysteem zijn gebaseerd.
Klopt bovenstaande?
BogoMIPS:
Million Instructions Per Second
bedankt Pantagruel.
Nu is me al wat meer duidelijk
de term PPA is me nog onduidelijk.
Heeft het iets te maken met parallel port hardware?
  • roelio
roelio
fruitig, en fris.
ppa = parallel port adapter naar ik meen
voor een evt. ZIP drive:
The ppa module is the Linux driver for the Iomega PPA3 parallel port SCSI host adapter.
Erm als jij zelfs geen stukken uit dmesg kan verklaren op je zelf, dan zit je in de verkeerde studierichting.
Met Linux spelen is verplicht engels kennen en HOWTO's lezen op http://www.tldp.org/ .
/me agrees with r00tx
Dit is eenvoudig zelf op te zoeken met google. Zijn genoeg sites waar ze de msg's in dmesg uitleggen
  • roelio
roelio
fruitig, en fris.
true :)
  • Jordi
Jordi
#1#1
Ehm... dit kan je idd zelf wel opzoeken. Het is hier geen GoH (Gathering of Huiswerkhulp) ;)
Het zal wel niet, maar het zou maar wel.
