[PHP4 / GD2] Compile problemen
  • _Gekkie_
  • Laatst online: 20-03 18:27
_Gekkie_
And the cow said: Helloooooow?
ok...
Ik heb problemen om mn PHP4 GD compatible te maken... ik probeer mn php te configgen en maken... maar bij het maken gaat het stuk:
Server Specs:
Debian Woody
PHP4.2.2
GD2.04 (en 1.8.4) (maar libgd.so -->libgd.so.2.0.8)
./configure:
./configure \
--with-mysql=/usr/local/mysql \
--with-apxs=/usr/local/apache/bin/apxs \
--with-zlib \
--with-png-dir=/usr \
--with-freetype \
--with-freetype-dir=/usr/local/lib \
--enable-versioning \
--with-gd=/usr \
--enable-gd-native-ttf \
--with-jpeg \
--with-jpeg-dir=/usr \
--with-ttf \
--with-xml \
--enable-track-vars \
--enable-trans-sid \
--enable-ftp
Dus nu komt 'make'
output:
29
30
31
32
33
Making all in gd
make[2]: Entering directory `/personal/zooi/php-4.2.2/ext/gd'
make[3]: Entering directory '/personal/zooi/php-4.2.2/ext/gd'
/bin/sh /personal/zooi/php-4.2.2/libtool --silent --mode=compile gcc
-I.
-I/personal/zooi/php-4.2.2/ext/gd -I/personal/zooi/php-4.2.2/main
-I/personal/zooi/php-4.2.2 -I/usr/local/apache/include
-I/personal/zooi/php-4.2.2/Zend
-I/usr/local/include/freetype2/freetype -I/usr/local/mysql/include/mysql
-I/personal/zooi/php-4.2.2/ext/xml/expat  -DLINUX=22
-DDEV_RANDOM=/dev/random -DMOD_SSL=208112
-DUSE_HSREGEX -DEAPI -DUSE_EXPAT -I/personal/zooi/php-4.2.2/TSRM -g -O2
-prefer-pic  -c gd.c
gd.c: In function `zm_startup_gd':
gd.c:303: `gdArc' undeclared (first use in this function)
gd.c:303: (Each undeclared identifier is reported only once
gd.c:303: for each function it appears in.)
gd.c:304: `gdPie' undeclared (first use in this function)
gd.c:305: `gdChord' undeclared (first use in this function)
gd.c:306: `gdNoFill' undeclared (first use in this function)
gd.c:307: `gdEdged' undeclared (first use in this function)
gd.c: In function `zif_imagecreatetruecolor':
gd.c:588: warning: assignment makes pointer from integer without a cast
gd.c: In function `zif_imagecolorat':
gd.c:1626: structure has no member named `tpixels'
make[3]: *** [gd.lo] Error 1
make[3]: Leaving directory `/personal/zooi/php-4.2.2/ext/gd'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/personal/zooi/php-4.2.2/ext/gd'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/personal/zooi/php-4.2.2/ext'
make: *** [all-recursive] Error 1
Iemand enig id?
[ Voor 0% gewijzigd door _Gekkie_ op 01-11-2002 12:32 . Reden: beetje te lange zinnen :) ]
Gekkie is a proud member of TheBenny!
  • Blubber
Zeker weten dat GD goed werkt?? Doe eens ldd opde gdlib.so. Anders kan je ook PHP 4.3.0-dev van CVS trekken. Ik had namelijk ook problemen met PHP4 en GD2 maar PHP 4.3.0 heeft ingebakken gd support. TIs alleen geen officieele release :)
  • _Gekkie_
_Gekkie_
krijg ik een " statically linked "
dus lijkt me dat het wel werkt...
Anders inderdaad even 4.3.0-dev... CVS-en.. hmmzz
edit: hmmmzz.. dat CVS verhaal zz toch sukke... is er nergens een tarball te halen?
  • _Gekkie_
_Gekkie_
is het te vroeg voor een !schop! ?
  • Kees
  • Laatst online: 11:54
Kees
Serveradmin / BOFH / DoC
ja :P
Maar toch eens wat leesvoer voor je:
http://www.php.net/~rasmus/gd.html
Hmmz wat ik heb gedaan op Debian.
GD downloaden, makefile aangepast, make, make install. Daarna php gecompileerd (4.3 en 4.2 deden het beide). Toen werkte het gewoon. Ik gebruik alleen geen prefix........
  • _Gekkie_
_Gekkie_
wh00000000000t!!
Kees you are my GD/PHP hero!!
Merci beaucoup!!!!
* _Gekkie_ slaakt een zucht van verlichting!!
