opeens geen files van >600 branden?
  • Zak
  • Laatst online: 11-09 12:40
Opeens kan ik met mijn Lite-on 32x (halfjaartje oud ofzo, ongeveer 400cd's) geen bestanden van >600mb branden?
Windows XP 5.1
WinAspi: -
ahead WinASPI: File 'C:\Program Files\ahead\Nero\Wnaspi32.dll': Ver=2.0.1.45, size=172099 bytes, created 27-2-2002 15:50:33
Nero Version: 5.5.7.8
Recorder: <LITE-ON LTR-32123S> Version: XS0R - HA 1 TA 0 - 5.5.7.8
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI
CD-ROM: <LG CD-ROM CRD-8400B>Version: 1.12 - HA 0 TA 1 - 5.5.7.8
Adapter driver: <atapi> HA 0
=== Scsi-Device-Map ===
DiskPeripheral : Maxtor 33073H3 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : LG CD-ROM CRD-8400B atapi Port 0 ID 1 DMA: Off
CdRomPeripheral : LITE-ON LTR-32123S atapi Port 1 ID 0 DMA: On
DiskPeripheral : IBM-DTTA-351010 atapi Port 1 ID 1 DMA: On
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 767MB (785908kB)
Free physical memory: 419MB (430044kB)
Memory in use : 45 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Wizard: Off
CD-ROM (ISO)
31.10.2002
22:36:25 #1 Phase 104 File dlgbrnst.cpp, Line 1438
SMART-BURN activated
22:36:26 #2 Text 0 File Reader.cpp, Line 118
Reader running
22:36:26 #3 Text 0 File Writer.cpp, Line 127
Writer LITE-ON LTR-32123S running
22:36:26 #4 Text 0 File Burncd.cpp, Line 2621
Turn on Disc-At-Once, using CD-R/RW media
22:36:26 #5 ISO9660GEN -11 File geniso.cpp, Line 4381
First writeable address = 0 (0x00000000)
22:36:26 #6 Text 0 File ThreadedTransferInterface.cpp, Line 684
Setup items (original item values)
0: TRM_DATA_MODE2_2336 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 356218 (356218) = #356218/79:9.43
relocatable, CD pos for caching/writing not required/required, no patch infos
22:36:28 #7 Text 0 File DlgWaitCD.cpp, Line 196
Last possible write address on media: 359847 (79:59.72)
Last address to be written: 356220 (79:11.45)
22:36:29 #8 Text 0 File DlgWaitCD.cpp, Line 1338
Recorder: LITE-ON LTR-32123S;
CDR code: 00 97 15 17; OSJ entry from: Ritek Co.
ATIP Data:
Special Info [hex] 1: C0 00 90, 2: 61 0F 11 (LI 97:15.17), 3: 4F 3B 49 (LO 79:59.73)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid)
22:36:30 #9 Text 0 File ThreadedTransferInterface.cpp, Line 834
Prepare recorder LITE-ON LTR-32123S for write in cue-sheet-DAO
DAO infos:
MCN:
TOCTYPE: 0x20 Close CD
Tracks 1 to 1:
TRM_DATA_RAW_MODE2, 2352/0x0, ISRC "", FilePos 0 352800 838177536
22:36:30 #10 Text 0 File ThreadedTransferInterface.cpp, Line 684
Setup items (after recorder preparation)
-> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 356218 blocks [LITE-ON LTR-32123S ]
22:36:30 #11 Phase 24 File dlgbrnst.cpp, Line 1438
Caching of files started
22:36:30 #12 Phase 25 File dlgbrnst.cpp, Line 1438
Caching of files completed
22:36:30 #13 Phase 36 File dlgbrnst.cpp, Line 1438
Burn process started at 32x (4.800 kB/sec)
22:36:30 #14 Text 0 File ThreadedTransferInterface.cpp, Line 1960
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
22:36:30 #15 Text 0 File Mmc.cpp, Line 11088
StartDAO : CD-Text - Off
22:36:30 #16 Text 0 File Mmc.cpp, Line 15587
Set BUFE: SMART-BURN -> ON
22:36:30 #17 Text 0 File Mmc.cpp, Line 11331
CueData, Len=32
41 00 00 34 00 00 00 00
41 01 00 21 00 00 00 00
41 01 01 21 00 00 02 00
41 aa 01 34 00 4f 0b 2b
22:40:13 #18 Text 0 File ThreadedTransfer.cpp, Line 222
all writers idle, stopping conversion
22:40:23 #19 SCSI -1135 File Cdrdrv.cpp, Line 1211
SCSI Exec, HA 1, TA 0, LUN 0
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
22:40:23 #20 MMC -1135 File ThreadedTransferInterface.cpp, Line 1448
Write error
22:40:23 #21 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1448
Could not perform end of Disc At Once
22:40:23 #22 CDR -201 File WriterStatus.cpp, Line 155
Invalid writestate
22:40:23 #23 TRANSFER -24 File WriterStatus.cpp, Line 155
22:40:23 #24 Phase 38 File dlgbrnst.cpp, Line 1438
Burn process failed at 32x (4.800 kB/sec)
22:40:23 #25 Text 0 File Scsicmd.cpp, Line 386
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
Dit is een log van Nero.
Wie weet waaraan dit kan liggen?
  • Angels2
  • Laatst online: 15-03-2025
Ik zie het volgende in je log:
Sense Code: 0x0C
Sense Qual: 0x00
Dit is een buffer underrun/write error (ondanks aangeschakelde burn proof), hij krijgt waarschijnlijk de lead-out niet geschreven.
Je kan eens iets anders dan Ritek plaatjes nemen.
Je haalt de gegevens toch niet van je cdrom die nog op pio staat?
Nero kan je ook officieel updaten van 5.5.7.8 naar 5.5.9.14 van de website van nero.
  • Zak
Angels2 schreef op 01 november 2002 @ 13:10:
sorry? Ritek is dat een cdr merk? Ik brand met platinum. Waarom doen deze het dan opeens niet meer? ik zit nou midden in een spindel van 100 en die andere 50 heeft 'ie prima gedaan.
Nope ik haal ze van een externe harde schijf. En die staat niet op PIO en is retesnel. Vreemde is dat als ik op de pc van mijn broertje brand met dezelfde instellingen en vanaf dezelfde locatie (of de schijf aan zijn pc) dat het dan wel werkt?
gevalletje kapotte hd? En zo ja hoe kan ik dat bij de winkel bewijzen want die zeggen natuurlijk niks mis mee als hij wel bestanden brandt van <600mb.
