SMC 7004ABR firmware update
  • 315 views sinds 30-01-2008
  • Gianni Rombios
Deze router net voor 89 euro bij funprice in huis gehaald. Voor de europese versie met partno 750.5703 blijkt niet de nieuwste firmware te worden aangeboden, ik heb hem echter geflashed met de op de us site aanwezige V1.42.003
firmware, bestemd voor de 750.5702. Dit is geen probleem het is precies dezelfde router, alleen de voeding 220 ipv 110 volt is verschillend.
De volgende fixen zijn toegevoegd t.o.v. de laatste europese update V1.40.020:
v1.42.003: 10/11/2002
1. Fixed MsnMessenger Vedio stream only one direction.
2. Removed UPnP by undefine _INCLUDE_UPNP.
3. Fixed PPPoE idle timeout reconnection many times cause memory leakage.
4. Fixed Gateway hang when using modem dail to Malaysia's ISP.
5. Fixed MSN messenger Voice Communication function doesn't work.
6. Fixed NAT issue with SONY PS2.
7. Fixed Prevent MAC loss problem.
v1.42.001: 09/10/2002
=> 1. Fixed PPPoE idle timeout reconnection many times cause
memory leakage.
v1.42.000: 09/10/2002
=> 1. Added UPnP
2. Fixed Gateway hang when using modem dail to Malaysia's ISP.
3. Fixed MSN messenger Voice Communication function doesn't work.
4. Fixed NAT issue with SONY PS2.
5. Fixed Prevent MAC loss problem.
v1.41.01: 08/23/2002
=> 1. Fixed the router lost is factory mac.
2. Added semaphore protection in flash read/write
V1.40.027: 08/12/2002
=> 1. Fixed PS2 bug fixing will causing PPTP passthough hanging in authentication
V1.40.026: 08/01/2002
=> 1 Merged 1.40.024(this version do not built in 1.40.025) and 1.40.025
V1.40.025: 07/31/2002
=> 1. Fixed the Printer Server will print extra blank page.
2. Fixed Sony PS2 compatibility problem.
3. Modified PPTP auto reconnect feature.
4. Dial on demand will always on if auto reconect enable.
5. Only LAN to WAN packet will reflush the PPP timer.
6. SNTP request will not tigger the dial on demand.
V1.40.024: 07/26/2002
=> 1. Added MsnMessenger Alg(this feature should be removed when UPnP was supported)
(For singapore only)
v1.40.023: 06/15/2002
=> 1. Router lost its MAC when reset to default or clone MAC
v1.40.022 : 05/29/2002
=> 1.Fixed clientfiter bug(delete the comparision of starttime and endtime in javascript)
2.This is just a testing version, not for releasing.
v1.40.021 : 04/26/2002
=> 1.Fixed DNS rebound issue (virtual server loopback).
Dit even voor alle smc 7004abr tweakers.
  • Predator
  • Laatst online: 17:59
Predator
Suffers from split brain
Dit is meer iets voor: http://www.tweakers.net/meuktracker
Everybody lies | BFD rocks ! | PC-specs
