Dxr3, definitief geen windows XP drivers
Al 2 anderhalf jaar ben ik in het bezit van een dxr3 kaart. Opzich een heel leuk kaartje als het werkt.
Toen windows XP uitkwam waren er geen drivers voor de dxr3, na een tijd kwamen er beta driver die bij praktisch iedereen niet (goed) werkte.
Ik heb vanochtend maar even met creative gechat en er wordt dus toegegeven dat de normale drivers er ook nooit komen en dat ik maar bij de system recruirements moest kijken op de verpakking.
Oftewel die kaart was toen 300 piek toen ik hem kocht en daar heb ik nu helemaal niks meer aan.
New Conference with Laura
from CLE
donderdag 31 oktober 2002 11:38:33 GMT+01:00
Laura : Thank you for contacting Creative Interactive Chat.
How can I help you?
You : Ehm, windows XP has been out for more then a year now and i still can' use my dxr3, becuase
creative doesn' have drivers
You : are you there ?
Laura : I am sorry but only BETA drivers are available for this card on Windows XP. They are avail
able to download from the following link:
http://www.europe.creativ...t/drivers/ENCORE_DXR3.EXE
According to our software development plan full drivers will not be released.
You : The beta drivers are very unstable and they make my operating system give error' and on ...
i just want normal drivers. I can't work with my "expensive" card now.
Laura : I am sorry I cannot offer you assistance. This is a BETA release and as such does not incl
ude technical support.
You : Yes i know that, it stands clearly at the download. But you just said that there won't come
any drivers for windows XP. Is it possible then to get a refund for my equipment ?
Laura : I am sorry but I cannot organise any refunds. The Dxr3 would have been supplied to you wit
h System Requirements. These system requirements do not include Windows XP.
You : That is a point, but creative can't ignore that millions of people use windows XP. And the d
xr3 is used by alot of people
Laura : I am sorry but there is nothing that I can help you with on this matter.
You : Is there someone who can then ?
Laura : well the drivers are not going to be released so I don't know of anyone who could help you
You : So i have about 200euro's of unwothy equipment here ?
Laura : As I have explained the System Requirements are available as a guideline when purchasing p
roducts.
You : I' sorry, but ithink that's a very lame excuse. All other manufactures of computer hardware
make drivers for windows XP avalible (if the hardware is not too old) and it just that creative does
n' even try, becuase the beta drivers are just ripped from another manufacture.
Laura : On the initial release of any product, Creative Labs will clearly label which Operating Sy
stems are supported on the included CD. The released product generally supports most current Operati
ng Systems.
Creative Labs subsequently provides updates for the drivers/software to incorporate support for ne
w technology including new Operating Systems. This additional service relies on several factors, suc
h as OEM manufacturers, market demand and product life cycle.
Hence, this development is not indefinite, but mainly focused on ensuring the products full functi
onality under the requirements for which the card was designed and in later environments depending o
n certain elements, such as the above mentioned.
I am sorry I cannot help you any further. Goodbye.
You : Ok, bye. But next time put a big label on the package that says:"DO NOT BUT CREATIVE STUFF,
BECAUSE THE SUPPORT STINKS"
Laura : I am sorry that you feel that way. Goodbye
CONFERENCE CLOSED
Ik heb zelf ook zo'n Dxr3 kaartje, maar die werkt gewoon perfect onder winXP met de beta drivers, dus ik vind het vreemd dat het bij zoveel mensen niet werkt. :/
  • manowar
  • Laatst online: 24-09 19:04
BA :r niet kewl heb zelf ook een DXR 3 kaart
(overgekocht van mn baas samen met een tv tuner/capture card voor 20 euro)
maar zou inderdaad leuk zijn als er offieele drivers voor kwamen
btw hij werkt wel bij mij maar alleen op TV en er zijn nog wat dingetjes wat ik mis in de software
system spec: http://specs.tweak.to/3452 ..
  • MeNTaL_TO
  • Laatst online: 20-10 07:32
MeNTaL_TO
The future is not set
Ik meen me iets te herinneren met gekraakte drivers van de Hollywood +, is in principe dezelfde kaart, ik weet alleen de website niet meer, maar ik neem aan dat dit de beste oplossing is.
[edit]
Ik hoop dat dit niet illegaal is en dat ik weer een OW (en nu dus waarschijnlijk ook een ban) krijg, maar je kan alles na lezen op deze site
http://www.angelfire.com/sd/dvd/dxr3crk.html
[ Voor 0% gewijzigd door MeNTaL_TO op 31-10-2002 12:30 . Reden: site gevonden ]
Wenn ist das Nunstruck git und Slotermeyer? Ja!... Beiherhund das Oder die Flipperwaldt gersput! The Hornets of Hades have descended upon me
  • manowar
kan me niet voor stellen dat je hier ene ban voorkrijgt je hebt alleen een link naar een driver page :)
Ja, die hollywood driver werken opzich wel.
Maar er zijn gewoon veel problemen bij mij mee, ze draaien zeer onstabiel.
En ik heb een dtt2200 speaker set van creative en die ondersteunt geen ac3 decoding, en dat kan je software matig met de creative drivers onder 98 wel doen.
  • MeNTaL_TO
MeNTaL_TO
manowar schreef op 31 oktober 2002 @ 12:34:
Het lijkt me ook niet illegaal om andere drivers op je hardware te gebruiken, maar ik ben geen modje, merk het snel genoeg.
Laat iig weten of het wel of niet werkt, ik heb de problemen niet, heb gewoon een H+, maar sinds ik een standalone heb gebruik ik die nog maar zelden.
Van sigma zijn er iig wel xp drivers.
  • MeNTaL_TO
MeNTaL_TO
Verwijderd schreef op 31 oktober 2002 @ 12:38:
Powerdvd gaan gebruiken? Kan je alleen niet op je tv kijken zonder tvout op je videokaart.
Maar creative is idd erg schofterig met driver updates, ik had vroeger een dxr2 en die doen het niet op een athlonboard en creative wilde er ook niets aan doen, kreeg als antwoord koop maar een dxr3 (kon hem met korting krijgen maar verzendkosten uit de VS waren wel voor mijn rekening) ben blij dat ik een hollywood+ gekocht heb en geen dxr3.
Creative is het voor mij snel aan het afdoen (net als ATI, heb je een 7500 mobile, kan je er nergens drivers voor vinden, en dell doet ook niet echt zijn best, nu maar de Omegadrivers geinstalleerd, maar het absurd dat je zulke kunstgrepen uit moet halen om je dure hardware aan de praat te krijgen?)
  • manowar
Ja zal ik zeker doen , hebben ook een standalone alleen dies van mn ouders , this one iZ all mine :)
btw weet iemand hier iets op ?? ->> als ik geluid tijdens een dvd wil hebben als ik hem via de DXR kaart op mn TV draai moet ik steeds de plug uit mn geluidskaart halen en in de DXR kaart stoppen (heb geen comp speaker set maar een grote bitch van sony 650 W >:)) en kan nergens in de software vinden dat je het geluid over standaard geluids kaart kan laten lopen :/
  • MeNTaL_TO
MeNTaL_TO
manowar schreef op 31 oktober 2002 @ 12:45:
Doorlussen van je dxr3 naar je geluidskaart (line-out naar line-in)?
En 650W wat? PMPO, RMS?
Mijn Aiwa is 1800W helaas wel PMPO, RMS is 90W per kanaal, en dat is herrie genoeg.
Ik mag niet klagen, eenvoudige (geen gel op het moment voor een leuke Yamaha receiver) aiwa 5.1 (geen DTS) receiver met een Sony 32fx60 breedbeeld tv (32") aangesloten op een pioneer 535 via scart.
[ Voor 0% gewijzigd door MeNTaL_TO op 31-10-2002 13:39 . Reden: typo ]
  • manowar
aa jmmr genoeg is het zn groot ding in 1 weet het type nmmr niet maar dat met die line out/in nog helemaal niet aan gedacht maar het is als ik goed nadenk 325W rms
heb op de line out wel eens een apparte versterker (2* 120W 2*80W) daar staat een 300W subwoofer op :D
  • jellyshock
  • Registratie: December 1999
  • Laatst online: 12-09 07:57
jellyshock
ik weet het niet hoor, maarrrr
Ik heb ook een dxr3 en hij werkt wel onder XP met de betadrivers (zijn gewoon de H+ drivers met een creative logootje).
Maar ik begrijp het Creative standpunt wel. Er staat nergens dat de kaart windowsXP ondersteund. In dit geval zijn we gewoon allemaal de lul.
aAarGhh
  • almightyarjen
  • Laatst online: 18:05
almightyarjen
When does the hurting stop?
In Win2K draait die kaart van mij ook al niet lekker, met Betadrivers redelijk. XP boycot ik sowieso. Dus ik draai nog lekker 98SE...
Wat hebben we nu geleerd?? Misschien nu eens (massaal) overstappen op Terratec of zo??
Het heeft volgens velen lang geduurd, maar uiteindelijk is er wel support gekomen voor Windows XP. (ergens op Tweakers.net wel gelezen dat er nogal velen teleurgesteld waren hierover)
Ik overweeg om dezelfde reden nu over te stappen naar Terratec. Any comments?!?
  • Logic
  • Laatst online: 16-10 18:17
Logic
SmartOS:Love at First Boot
Ik heb zelf ook zo een creative kaartje..
Ik heb er maar een dual boot van gemaakt, op mijn pc.
win98 speciaal voor die dx3, maakt toch niet zoveel uit.. hoeveel ruimte is nou win98 met alleen maar de drivers en een paar programma's .
tegenwoordig zijn de hdd's zo groot...
Zodra als ik onder xp een film wil kijken loopt ie meteen vast.
If it bleeds, it can be killed!
jellyshock schreef op 31 oktober 2002 @ 14:51:
Ja ok, ik begrijp hun standpunt ook wel.
Maar laten we wel wezen, deze kaart is nog geen 2 jaar oud. Hij kostte voor mij toen best veel en dan vind ik dat daar nog best wdm drivers voor gemaakt kunnen worden.
