UT2003 critical error
  • argro
  • Laatst online: 04-02 17:05
UT2003 Build [2002.05.31.18.31]
OS: Windows XP 5.1 (Build: 2600)
CPU: AuthenticAMD PentiumPro-class processor @ 1003 MHz with 511MB RAM
Video: NVIDIA GeForce2 MX/MX 400
Assertion failed: InPos<=Size [File:..\..\Core\Inc\FFileManagerWindows.h] [Line: 57]
History: FArchiveFileReader::Seek <- ULinkerLoad::Seek <- LoadImportMap <- ULinkerLoad::ULinkerLoad <- UObject::GetPackageLinker <- ULinkerLoad::VerifyImport <- ValidateImports <- ULinkerLoad::Verify <- ULinkerLoad::ULinkerLoad <- UObject::GetPackageLinker <- ULinkerLoad::VerifyImport <- ValidateImports <- ULinkerLoad::Verify <- ULinkerLoad::ULinkerLoad <- UObject::GetPackageLinker <- ULinkerLoad::VerifyImport <- ULinkerLoad::VerifyImport <- ValidateImports <- ULinkerLoad::Verify <- ULinkerLoad::ULinkerLoad <- UObject::GetPackageLinker <- ULinkerLoad::VerifyImport <- ULinkerLoad::VerifyImport <- ValidateImports <- ULinkerLoad::Verify <- ULinkerLoad::ULinkerLoad <- UObject::GetPackageLinker <- ULinkerLoad::VerifyImport <- ULinkerLoad::VerifyImport <- ValidateImports <- ULinkerLoad::Verify <- ULinkerLoad::ULinkerLoad <- UObject::GetPackageLinker <- ULinkerLoad::VerifyImport <- ValidateImports <- ULinkerLoad::Verify <- ULinkerLoad::ULinkerLoad <- UObject::GetPackageLinker <- ULinkerLoad::VerifyImport <- ValidateImports <- ULinkerLoad::Verify <- ULinkerLoad::ULinkerLoad <- UObject::GetPackageLinker <- ULinkerLoad::VerifyImport <- ValidateImports <- ULinkerLoad::Verify <- ULinkerLoad::ULinkerLoad <- UObject::GetPackageLinker <- ULinkerLoad::VerifyImport <- ULinkerLoad::VerifyImport <- ValidateImports <- ULinkerLoad::Verify <- ULinkerLoad::ULinkerLoad <- UObject::GetPackageLinker <- UObject::StaticLoadObject <- (Engine.Level None.MyLevel Entry) <- VerifyPackages <- UGameEngine::LoadMap <- UGameEngine::Init <- InitEngine
Dat is er dus aan de hand! Iemand die dat begrijpt? Ik niet iig.
so·wie·so (bw.) 1 hoe dan ook => überhaupt
  • White Dust
  • Laatst online: 22-09 10:04
White Dust
PlaneScape: Torment
Kun je even je specs neer kalken, vermelden of je de drivers/patches up to date hebt...
Als ik het zo zie kan het een corrupte file zijn... als je hem legaal hebt gekocht kan het zijn dat hij vekeerd is gedrukt... als je hem illegaal hebt is het waarschijnlijk een corrupte download ;)
  • Ramon
  • Laatst online: 07:22
en wanneer krijg je de error? Bij starten van UT2k3 of bij spelen van een bepaalde map?
  • argro
bij het starten van UT, direct na het begin scherm krijg ik deze melding en sluit UT weer af
  • Hahn
  • Laatst online: 24-10 17:09
White Dust schreef op 30 oktober 2002 @ 22:13:
Specs:
The devil is in the details.
