printer poorten!
ik wil eigenlijk effe iets te weten willen komen over de poorten:
wat is het verschil tussen spp epp ecp?
en waarom kies je voor epp ipv spp??
wat houd het in
alvast bedankt :)
  • Master__R
  • Laatst online: 19-10 07:08
gezocht niets gevonden!
  • dion_b
  • Laatst online: 22:57
dion_b
say Baah
Beter zoeken :z
Tip: dit is waar de afkortingen voor staan:
Simple Parallel Port
Enhanced Parallel Port
Enhanced (of was het Extended :? ) Capabilities Port
Search ook ff op Bi-directional, dan heb je ze allemaal...
Oslik, blyat! Oslik!
  • JAVA-Doctor
  • Laatst online: 17-10 19:51
Echt wel, de eerste 3 hits zijn al raak, copy & paste:
Parallel port mode (SPP, EPP, ECP):
HP recommends using an EPP or ECP parallel port with the external CD-Writer Plus. Although most new computers have parallel ports which are capable of ECP/EPP modes, the default setting is SPP. In most cases, you will need to enter the computer's CMOS or BIOS setup program to make changes to these settings. Refer to you computer's documentation for information on how to set the port for EPP or ECP modes.
SPP:
Standard Parallel Ports are the slowest type. SPP ports can be called unidirectional, bidirectional, standard, compatible and other names. These ports run at very slow speeds.
EPP:
Enhanced Parallel Port. Similar in speed to ECP (below). EPP is usually the preferred setting since it does not use a DMA channel. This can be a great benefit on systems that have many devices installed.
ECP:
Enhanced Capabilities Port. ECP ports use a DMA channel, but generally provide only a slight increase in speed.
  • |sWORDs|
  • Laatst online: 14-04 12:48
|sWORDs|
vSphere/ESXi
Ik kan je alleen vertellen dat epp 1.7 altijd werkt, heeft iets met bidirectioneel te maken.
Te Koop:24 Core Intel Upgradeset
