Ik wil dvd's kunnen afspelen onder mijn Gentoo installatie. Daarvoor heb ik ogle gedownload en compiled d.m.v. emerge ogle
Als ik een dvd probeer af te spelen krijg ik dit:
stuartje@gentoo stuartje $ ogle /mnt/cdrom
Build: Linux 2.4.19-gentoo-r9 #7 SMP Sun Oct 6 11:44:40 CEST 2002 i686 Pentium III (Coppermine) Sun Oct 13 21:58:35 CEST 2002 mmx Xv oss alsa
Runtime: Linux 2.4.19-gentoo-r9 #7 SMP Sun Oct 6 11:44:40 CEST 2002 i686 Pentium III (Coppermine)
Note[ogle_ctrl]: ogle 0.8.5
Debug[ogle_ctrl]: Started /usr/lib/ogle/ogle_cli with pid 16294
Debug[ogle_ctrl]: Started /usr/lib/ogle/ogle_nav with pid 16295
Debug[ogle_ctrl]: Started /usr/lib/ogle/ogle_mpeg_ps with pid 16296
Debug[ogle_ctrl]: Started /usr/lib/ogle/ogle_vout with pid 16297
Debug[ogle_vout]: CLK_TCK: 100
Debug[ogle_nav]: Opening DVD at "/mnt/cdrom"
libdvdread: Using libdvdcss version 1.2.2 for DVD access
libdvdread: Attempting to use device /dev/cdroms/cdrom0 mounted on /mnt/cdrom for CSS authentication
Debug[ogle_nav]: sending subp demuxstream 0
libdvdread: Attempting to retrieve all CSS keys
libdvdread: This can take a _long_ time, please be patient
libdvdread: Get key for /VIDEO_TS/VIDEO_TS.VOB at 0x0000013a
libdvdread: Elapsed time 2
libdvdread: Get key for /VIDEO_TS/VTS_01_0.VOB at 0x0000c82c
libdvdread: Elapsed time 0
libdvdread: Get key for /VIDEO_TS/VTS_01_1.VOB at 0x00014ea0
libdvdread: Get key for /VIDEO_TS/VTS_02_0.VOB at 0x003909bb
libdvdread: Get key for /VIDEO_TS/VTS_02_1.VOB at 0x003909c0
libdvdread: Get key for /VIDEO_TS/VTS_03_0.VOB at 0x00392855
libdvdread: Get key for /VIDEO_TS/VTS_03_1.VOB at 0x0039285a
libdvdread: Elapsed time 5
libdvdread: Get key for /VIDEO_TS/VTS_04_0.VOB at 0x0039437e
libdvdread: Get key for /VIDEO_TS/VTS_04_1.VOB at 0x00394383
libdvdread: Found 4 VTS's
libdvdread: Elapsed time 9
Debug[ogle_ctrl]: _new stream bf, 0
Debug[ogle_ctrl]: _new stream e0, 0
Debug[ogle_ctrl]: Started /usr/lib/ogle/ogle_mpeg_vs with pid 16298
Debug[ogle_mpeg_vs]: Using MMX accelerated media functions
*** Backward scr discontinuity
system_clock_reference: [0.000000 s]
prev system_clock_reference: [6.502806 s]
demux: changed to scr_nr: 1
## video_stream:req cap
video_dec: shmid: 28409870
video_dec: data_buf shmid: 28344332
## video_stream:got cap and stream
vs: get ouput buffer
Debug[ogle_ctrl]: got capability video_out
horizontal_size: 720, vertical_size: 576
padded_width: 720, padded_height: 576
frame rate: 25
prev system_clock_reference: [0.500216 s]
demux: changed to scr_nr: 2
xscreensaver-command not found.
Debug[ogle_vout]: set_sync_point()
Note[ogle_vout]: using default config for ':0.0'
Note[ogle_vout]: Using 'X11' as source for geometry
Note[ogle_vout]: Xinerama extension not found/active
*vs: offset not valid
Debug[ogle_ctrl]: _new stream bd, 80
Debug[ogle_ctrl]: Started /usr/lib/ogle/ogle_audio with pid 16300
Note[ogle_vout]: Using 'XF86VidMode' as source for resolution
Note[ogle_vout]: Display w: 347, h: 260, hp: 1024, vp: 768
Note[ogle_vout]: Display sar: 266240/266496 = 0.999039
No accelerated IMDCT transform found
Debug[ogle_audio]: decode_a52: found sync
Note[ogle_audio]: Using audio driver 'alsa'
[ogle_alsa]: Opening device: default
Note[ogle_vout]: Found Xv extension 2.2, checking for suitable adaptors
Note[ogle_vout]: Xv adaptor "SIS Video Overlay" port 52 image format 842094169
Debug[ogle_vout]: resize: 1023, 576
#!!###!!###!!![ogle_alsa]: error while opening alsa.
: No such file or directory
FATAL[ogle_audio]: failed opening the alsa audio driver at default
Debug[ogle_ctrl]: child: 16300 exited with 1
Debug[ogle_ctrl]: pid: 16300 exited with status: 1
Debug[ogle_ctrl]: child: 16294 killed
Debug[ogle_ctrl]: pid: 16294 terminated on signal: 2
Debug[ogle_ctrl]: child: 16298 exited with 0
Debug[ogle_ctrl]: pid: 16298 exited with status: 0
Debug[ogle_ctrl]: child: 16297 exited with 0
Debug[ogle_ctrl]: pid: 16297 exited with status: 0
Debug[ogle_ctrl]: slaying child: 16295
Debug[ogle_ctrl]: slaying child: 16296
Debug[ogle_ctrl]: removing shmid: 28311563
Debug[ogle_ctrl]: removing shmid: 28344332
Debug[ogle_ctrl]: removing shmid: 28377101
Debug[ogle_ctrl]: removing shmid: 28409870
Debug[ogle_ctrl]: removing shmid: 28442639
ctrl: ipc_rmid: Invalid argument
Debug[ogle_ctrl]: removing shmid: 28475408
Debug[ogle_ctrl]: removing shmid: 28508177
Note[ogle_ctrl]: exiting
Ogle wil alsa gebruiken maar ik gebruik geen alsa voor mijn geluid maar een simpele kernel module. Weet er iemand een oplossing?
frame rate: 25
