29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
| Line Message
3 The tag: HTML does not conform to upper/lower case requirements.
4 The tag: HEAD does not conform to upper/lower case requirements.
5 The tag: TITLE does not conform to upper/lower case requirements.
6 The tag: META does not conform to upper/lower case requirements.
7 The tag: META does not conform to upper/lower case requirements.
7 The tag:"meta" is not allowed within: "meta" It is only allowed within: head.
8 The tag: META does not conform to upper/lower case requirements.
8 The tag:"meta" is not allowed within: "meta" It is only allowed within: head.
9 The tag: META does not conform to upper/lower case requirements.
9 The tag:"meta" is not allowed within: "meta" It is only allowed within: head.
10 The tag: META does not conform to upper/lower case requirements.
10 The tag:"meta" is not allowed within: "meta" It is only allowed within: head.
11 The tag: META does not conform to upper/lower case requirements.
11 The tag:"meta" is not allowed within: "meta" It is only allowed within: head.
12 The tag: META does not conform to upper/lower case requirements.
12 The tag:"meta" is not allowed within: "meta" It is only allowed within: head.
13 The tag: META does not conform to upper/lower case requirements.
13 The tag:"meta" is not allowed within: "meta" It is only allowed within: head.
14 The tag: META does not conform to upper/lower case requirements.
14 The tag:"meta" is not allowed within: "meta" It is only allowed within: head.
15 The tag:"meta" is not allowed within: "meta" It is only allowed within: head.
15 The value 'EXPIRES' is not valid for the "http-equiv" attribute in HTML20. The value is valid if double quoted.
16 The tag:"meta" is not allowed within: "meta" It is only allowed within: head.
17 The tag: STYLE does not conform to upper/lower case requirements.
17 The tag:"style" is not allowed within: "meta" It is only allowed within: head.
31 The tag: STYLE does not conform to upper/lower case requirements.
32 The tag: LINK does not conform to upper/lower case requirements.
32 The tag:"link" is not allowed within: "meta" It is only allowed within: head.
33 The tag:"script" is not allowed within: "link" It is only allowed within: a, abbr, acronym, address, b, bdo, big, blockquote, body, button, caption, cite, code, dd, del, dfn, div, dt, em, fieldset, form. . ..
33 in tag: script the following required attributes are missing: type
35 The tag: HEAD does not conform to upper/lower case requirements.
35 Nesting error, "link" should be closed before closing "head"
35 Nesting error, "meta" should be closed before closing "head"
37 The tag: BODY does not conform to upper/lower case requirements.
38 The tag: TABLE does not conform to upper/lower case requirements.
39 The tag: TR does not conform to upper/lower case requirements.
39 The tag: TD does not conform to upper/lower case requirements.
39 in tag: img the following required attributes are missing: alt
39 Nesting error, "img" should be closed before closing "a"
40 The tag: TR does not conform to upper/lower case requirements.
42 The tag: TABLE does not conform to upper/lower case requirements.
45 The tag: TD does not conform to upper/lower case requirements.
45 The tag: "td" doesn't have an attribute: "background" in currently active versions.
46 The tag: TD does not conform to upper/lower case requirements.
46 The tag: "td" doesn't have an attribute: "background" in currently active versions.
50 The tag: TR does not conform to upper/lower case requirements.
52 The tag: TABLE does not conform to upper/lower case requirements.
52 The tag: "table" doesn't have an attribute: "height" in currently active versions.
55 The tag: TABLE does not conform to upper/lower case requirements.
56 The tag: TR does not conform to upper/lower case requirements.
57 The tag: TD does not conform to upper/lower case requirements.
57 The tag: "td" doesn't have an attribute: "background" in currently active versions.
57 in tag: img the following required attributes are missing: alt
57 Nesting error, "img" should be closed before closing "td"
58 The tag: TR does not conform to upper/lower case requirements.
59 The tag: TR does not conform to upper/lower case requirements.
60 The tag: TD does not conform to upper/lower case requirements.
60 in tag: img the following required attributes are missing: alt
60 Nesting error, "img" should be closed before closing "a"
61 The tag: TD does not conform to upper/lower case requirements.
61 in tag: img the following required attributes are missing: alt
61 Nesting error, "img" should be closed before closing "td"
62 The tag: TR does not conform to upper/lower case requirements.
64 The tag: TR does not conform to upper/lower case requirements.
65 The tag: TD does not conform to upper/lower case requirements.
65 in tag: img the following required attributes are missing: alt
65 The tag: TABLE does not conform to upper/lower case requirements.
65 The tag:"table" is not allowed within: "img" It is only allowed within: blockquote, body, button, dd, del, div, fieldset, form, ins, li, map, noscript, object, td, th.
67 Nesting error, "br" should be closed before closing "td"
69 Nesting error, "br" should be closed before closing "td"
71 Nesting error, "br" should be closed before closing "td"
73 Nesting error, "br" should be closed before closing "td"
75 Nesting error, "br" should be closed before closing "td"
77 Nesting error, "br" should be closed before closing "td"
79 Nesting error, "br" should be closed before closing "td"
81 Nesting error, "br" should be closed before closing "td"
83 Nesting error, "br" should be closed before closing "td"
85 Nesting error, "br" should be closed before closing "td"
87 The tag: TD does not conform to upper/lower case requirements.
87 The tag: "a" doesn't have an attribute: "alt" in currently active versions.
88 The tag: TABLE does not conform to upper/lower case requirements.
89 The tag: TD does not conform to upper/lower case requirements.
89 Nesting error, "img" should be closed before closing "td"
90 The tag: TD does not conform to upper/lower case requirements.
90 in tag: img the following required attributes are missing: alt
90 Nesting error, "img" should be closed before closing "td"
91 The tag: TR does not conform to upper/lower case requirements.
92 The tag: TR does not conform to upper/lower case requirements.
93 The tag: TD does not conform to upper/lower case requirements.
93 The tag: "td" doesn't have an attribute: "background" in currently active versions.
93 in tag: img the following required attributes are missing: alt
93 Nesting error, "img" should be closed before closing "td"
94 The tag: TD does not conform to upper/lower case requirements.
94 in tag: img the following required attributes are missing: alt
94 Nesting error, "img" should be closed before closing "td"
95 The tag: TR does not conform to upper/lower case requirements.
96 The tag: TR does not conform to upper/lower case requirements.
97 The tag: TD does not conform to upper/lower case requirements.
97 in tag: img the following required attributes are missing: alt
97 Nesting error, "img" should be closed before closing "a"
98 The tag: TD does not conform to upper/lower case requirements.
99 The tag: TD does not conform to upper/lower case requirements.
99 The tag: "td" doesn't have an attribute: "background" in currently active versions.
100 The tag: TD does not conform to upper/lower case requirements.
101 The tag: TR does not conform to upper/lower case requirements.
102 The tag: TR does not conform to upper/lower case requirements.
103 The tag: TD does not conform to upper/lower case requirements.
104 The tag: TABLE does not conform to upper/lower case requirements.
105 The tag: TD does not conform to upper/lower case requirements.
106 The tag: TD does not conform to upper/lower case requirements.
106 in tag: img the following required attributes are missing: alt
106 Nesting error, "img" should be closed before closing "td"
107 The tag: TR does not conform to upper/lower case requirements.
108 The tag: TR does not conform to upper/lower case requirements.
109 The tag: TD does not conform to upper/lower case requirements.
109 in tag: img the following required attributes are missing: alt
109 Nesting error, "img" should be closed before closing "a"
110 The tag: TD does not conform to upper/lower case requirements.
110 The tag: "td" doesn't have an attribute: "background" in currently active versions.
110 in tag: img the following required attributes are missing: alt
110 Nesting error, "img" should be closed before closing "td"
111 The tag: TR does not conform to upper/lower case requirements.
112 The tag: TR does not conform to upper/lower case requirements.
113 The tag: TD does not conform to upper/lower case requirements.
113 in tag: img the following required attributes are missing: alt
113 The tag: TABLE does not conform to upper/lower case requirements.
113 The tag:"table" is not allowed within: "img" It is only allowed within: blockquote, body, button, dd, del, div, fieldset, form, ins, li, map, noscript, object, td, th.
115 Nesting error, "br" should be closed before closing "td"
117 Nesting error, "br" should be closed before closing "td"
119 Nesting error, "br" should be closed before closing "td"
121 Nesting error, "br" should be closed before closing "td"
122 The tag: "a" doesn't have an attribute: "alt" in currently active versions.
124 The tag: TD does not conform to upper/lower case requirements.
124 Nesting error, "img" should be closed before closing "td"
125 The tag: TD does not conform to upper/lower case requirements.
126 The tag: TR does not conform to upper/lower case requirements.
131 The tag: TABLE does not conform to upper/lower case requirements.
131 The tag: "table" doesn't have an attribute: "background" in currently active versions.
133 The tag: TD does not conform to upper/lower case requirements.
133 The tag: "td" doesn't have an attribute: "background" in currently active versions.
133 in tag: img the following required attributes are missing: alt
133 Nesting error, "img" should be closed before closing "td"
134 The tag: TD does not conform to upper/lower case requirements.
134 The tag: "td" doesn't have an attribute: "background" in currently active versions.
134 in tag: img the following required attributes are missing: alt
134 Nesting error, "img" should be closed before closing "td"
136 The tag: TD does not conform to upper/lower case requirements.
136 The tag: IMG does not conform to upper/lower case requirements.
136 in tag: img the following required attributes are missing: alt
136 Nesting error, "img" should be closed before closing "a"
137 The tag: TD does not conform to upper/lower case requirements.
137 The tag: IMG does not conform to upper/lower case requirements.
137 in tag: img the following required attributes are missing: alt
137 Nesting error, "img" should be closed before closing "td"
138 The tag: TD does not conform to upper/lower case requirements.
138 The tag: IMG does not conform to upper/lower case requirements.
138 in tag: img the following required attributes are missing: alt
138 Nesting error, "img" should be closed before closing "td"
139 The tag: TD does not conform to upper/lower case requirements.
140 The tag: IMG does not conform to upper/lower case requirements.
140 in tag: img the following required attributes are missing: alt
140 Nesting error, "img" should be closed before closing "a"
140 The tag: TD does not conform to upper/lower case requirements.
142 The tag: TD does not conform to upper/lower case requirements.
142 The tag: "td" doesn't have an attribute: "background" in currently active versions.
142 in tag: img the following required attributes are missing: alt
142 Nesting error, "img" should be closed before closing "td"
143 The tag: TD does not conform to upper/lower case requirements.
143 in tag: img the following required attributes are missing: alt
143 Nesting error, "img" should be closed before closing "td"
144 The tag: TR does not conform to upper/lower case requirements.
145 The tag: TABLE does not conform to upper/lower case requirements.
148 The tag: "td" doesn't have an attribute: "background" in currently active versions.
148 in tag: img the following required attributes are missing: alt
149 Nesting error, "img" should be closed before closing "td"
152 The tag: "table" doesn't have an attribute: "height" in currently active versions.
154 The tag: "td" doesn't have an attribute: "background" in currently active versions.
164 The value TEKST_POST is not valid for the "class" attribute in HTML4. The value is valid if double quoted.
164 The value TEKST_POST is not valid for the "class" attribute in XHTML10S. The value is valid if double or single quoted.
164 TEKST_POST is not a valid value for the "class" attribute in any of the currently active versions. See the above warnings for more details.
167 in tag: img the following required attributes are missing: alt
167 "left" is not a valid value for the "align" attribute in HTML20. Valid values for this attribute are: Dynamic expression, bottom, middle, top.
167 Nesting error, "img" should be closed before closing "td"
172 The tag: IMG does not conform to upper/lower case requirements.
172 The tag:"br" is not allowed within: "img" It is only allowed within: a, abbr, acronym, address, b, bdo, big, button, caption, cite, code, dd, del, dfn, div, dt, em, fieldset, h1, h2, h3, h4, h5, h6. . ..
173 The tag:"table" is not allowed within: "br" It is only allowed within: blockquote, body, button, dd, del, div, fieldset, form, ins, li, map, noscript, object, td, th.
182 The tag:"table" is not allowed within: "br" It is only allowed within: blockquote, body, button, dd, del, div, fieldset, form, ins, li, map, noscript, object, td, th.
230 The tag:"p" is not allowed within: "br" It is only allowed within: blockquote, body, button, dd, del, div, fieldset, form, ins, li, map, noscript, object, td, th.
230 The tag: IMG does not conform to upper/lower case requirements.
230 The tag:"img" is not allowed within: "br" It is only allowed within: a, abbr, acronym, address, b, bdo, big, button, caption, cite, code, dd, del, dfn, div, dt, em, fieldset, h1, h2, h3, h4, h5, h6. . ..
230 The tag:"table" is not allowed within: "img" It is only allowed within: blockquote, body, button, dd, del, div, fieldset, form, ins, li, map, noscript, object, td, th.
235 The value TEKST_POST is not valid for the "class" attribute in HTML4. The value is valid if double quoted.
235 The value TEKST_POST is not valid for the "class" attribute in XHTML10S. The value is valid if double or single quoted.
235 TEKST_POST is not a valid value for the "class" attribute in any of the currently active versions. See the above warnings for more details.
238 The tag: P does not conform to upper/lower case requirements.
238 The tag: A does not conform to upper/lower case requirements.
238 The value _BLACK is not valid for the "target" attribute in HTML4. The value is valid if double quoted.
238 _BLACK is not a valid value for the "target" attribute in any of the currently active versions. See the above warnings for more details.
241 The tag: IMG does not conform to upper/lower case requirements.
241 The tag:"img" is not allowed within: "br" It is only allowed within: a, abbr, acronym, address, b, bdo, big, button, caption, cite, code, dd, del, dfn, div, dt, em, fieldset, h1, h2, h3, h4, h5, h6. . ..
241 Nesting error, "img" should be closed before closing "td"
241 Nesting error, "br" should be closed before closing "td"
243 The tag:"table" is not allowed within: "img" It is only allowed within: blockquote, body, button, dd, del, div, fieldset, form, ins, li, map, noscript, object, td, th.
248 The value TEKST_POST is not valid for the "class" attribute in HTML4. The value is valid if double quoted.
248 The value TEKST_POST is not valid for the "class" attribute in XHTML10S. The value is valid if double or single quoted.
248 TEKST_POST is not a valid value for the "class" attribute in any of the currently active versions. See the above warnings for more details.
251 The tag: BR does not conform to upper/lower case requirements.
251 Nesting error, "br" should be closed before closing "td"
254 The tag: IMG does not conform to upper/lower case requirements.
254 The tag:"img" is not allowed within: "br" It is only allowed within: a, abbr, acronym, address, b, bdo, big, button, caption, cite, code, dd, del, dfn, div, dt, em, fieldset, h1, h2, h3, h4, h5, h6. . ..
254 Nesting error, "img" should be closed before closing "td"
254 Nesting error, "br" should be closed before closing "td"
257 Nesting error, "img" should be closed before closing "td"
257 Nesting error, "br" should be closed before closing "td"
266 The tag:"a" is not allowed within: "br" It is only allowed within: abbr, acronym, address, b, bdo, big, caption, cite, code, dd, del, dfn, div, dt, em, fieldset, h1, h2, h3, h4, h5, h6, i, ins, k. . ..
266 The tag:"br" is not allowed within: "br" It is only allowed within: a, abbr, acronym, address, b, bdo, big, button, caption, cite, code, dd, del, dfn, div, dt, em, fieldset, h1, h2, h3, h4, h5, h6. . ..
267 The tag:"a" is not allowed within: "br" It is only allowed within: abbr, acronym, address, b, bdo, big, caption, cite, code, dd, del, dfn, div, dt, em, fieldset, h1, h2, h3, h4, h5, h6, i, ins, k. . ..
267 The tag:"br" is not allowed within: "br" It is only allowed within: a, abbr, acronym, address, b, bdo, big, button, caption, cite, code, dd, del, dfn, div, dt, em, fieldset, h1, h2, h3, h4, h5, h6. . ..
268 Nesting error, "br" should be closed before closing "td"
276 The tag:"a" is not allowed within: "br" It is only allowed within: abbr, acronym, address, b, bdo, big, caption, cite, code, dd, del, dfn, div, dt, em, fieldset, h1, h2, h3, h4, h5, h6, i, ins, k. . ..
276 The tag:"br" is not allowed within: "br" It is only allowed within: a, abbr, acronym, address, b, bdo, big, button, caption, cite, code, dd, del, dfn, div, dt, em, fieldset, h1, h2, h3, h4, h5, h6. . ..
277 Nesting error, "br" should be closed before closing "td"
285 The tag: TD does not conform to upper/lower case requirements.
288 The tag: TABLE does not conform to upper/lower case requirements.
290 The tag: "td" doesn't have an attribute: "background" in currently active versions.
238 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
251 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using &#euml; instead. |
