29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
| Line Message
8 The tag: "body" doesn't have an attribute: "leftmargin" in currently active versions.
8 The tag: "body" doesn't have an attribute: "topmargin" in currently active versions.
8 The tag: "body" doesn't have an attribute: "marginwidth" in currently active versions.
8 The tag: "body" doesn't have an attribute: "marginheight" in currently active versions.
20 The value TEXT/JAVASCRIPT is not valid for the "type" attribute in HTML4. The value is valid if double quoted.
20 TEXT/JAVASCRIPT is not a valid value for the "type" attribute in any of the currently active versions. See the above warnings for more details.
24 The value TEXT/JAVASCRIPT is not valid for the "type" attribute in HTML4. The value is valid if double quoted.
24 TEXT/JAVASCRIPT is not a valid value for the "type" attribute in any of the currently active versions. See the above warnings for more details.
28 The value TEXT/JAVASCRIPT is not valid for the "type" attribute in HTML4. The value is valid if double quoted.
28 TEXT/JAVASCRIPT is not a valid value for the "type" attribute in any of the currently active versions. See the above warnings for more details.
30 The tag: "table" doesn't have an attribute: "height" in currently active versions.
30 The tag: "table" doesn't have an attribute: "cellpading" in currently active versions.
53 The tag: "table" doesn't have an attribute: "height" in currently active versions.
67 The tag: "table" doesn't have an attribute: "valign" in currently active versions.
70 The tag: "td" doesn't have an attribute: "background" in currently active versions.
74 The tag: "td" doesn't have an attribute: "background" in currently active versions.
83 The value #CFCFCF is not valid for the "value" attribute in HTML32. The value is valid if double quoted.
83 #CFCFCF is not a valid value for the "value" attribute in any of the currently active versions. See the above warnings for more details.
86 The tag name: "EMBED" not found in currently active versions
90 The tag: "td" doesn't have an attribute: "background" in currently active versions.
103 The tag: " table" is invalid inside tag: "p". The "p" end tag is optional. Validation will proceed as if the tag were ended.
103 The tag: "table" doesn't have an attribute: "valign" in currently active versions.
106 The tag: "td" doesn't have an attribute: "background" in currently active versions.
110 The tag: "td" doesn't have an attribute: "background" in currently active versions.
120 The value #CFCFCF is not valid for the "value" attribute in HTML32. The value is valid if double quoted.
120 #CFCFCF is not a valid value for the "value" attribute in any of the currently active versions. See the above warnings for more details.
123 The tag name: "EMBED" not found in currently active versions
127 The tag:"td" is not allowed within: "div". No valid contexts are specified for this element in currently active versions.
127 The tag: "td" doesn't have an attribute: "background" in currently active versions.
129 The tag:"tr" is not allowed within: "div" It is only allowed within: table, tbody, tfoot, thead.
133 No starting tag found for: "td", or it was closed too many times
135 Nesting error, "div" should be closed before closing "table"
139 The tag:"td" is not allowed within: "div". No valid contexts are specified for this element in currently active versions.
139 The tag: "td" doesn't have an attribute: "border" in currently active versions.
141 The tag:"td" is not allowed within: "div". No valid contexts are specified for this element in currently active versions.
143 The tag: "table" doesn't have an attribute: "height" in currently active versions.
143 The tag: "table" doesn't have an attribute: "valign" in currently active versions.
146 The tag: "td" doesn't have an attribute: "background" in currently active versions.
150 The tag: "td" doesn't have an attribute: "background" in currently active versions.
161 In HTML 4.0, CENTER is deprecated.
176 In HTML 4.0, FONT is deprecated. It may become obsolete in future versions, consider using style sheets instead.
181 The tag:"td" is not allowed within: "font". No valid contexts are specified for this element in currently active versions.
181 The tag: "td" doesn't have an attribute: "background" in currently active versions.
183 The tag:"tr" is not allowed within: "font" It is only allowed within: table, tbody, tfoot, thead.
189 Nesting error, "font" should be closed before closing "table"
189 The tag: " p" allows optional end tag. End tag: "table" closes "p" context. Validation will proceed as if the tag were ended.
189 The tag: " p" allows optional end tag. End tag: "table" closes "p" context. Validation will proceed as if the tag were ended.Nesting error, "div" should be closed before closing "table"
189 Nesting error, "div" should be closed before closing "table"
189 Nesting error, "center" should be closed before closing "table"
190 Nesting error, "div" should be closed before closing "table"
190 The tag: " tr" allows optional end tag. End tag: "table" closes "tr" context. Validation will proceed as if the tag were ended.
193 In HTML 4.0, CENTER is deprecated.
196 The tag:"link" is not allowed within: "center" It is only allowed within: head.
198 The tag: "table" doesn't have an attribute: "height" in currently active versions.
201 In HTML 4.0, FONT is deprecated. It may become obsolete in future versions, consider using style sheets instead.
202 In HTML 4.0, CENTER is deprecated.
202 The tag:"center" is not allowed within: "font" It is only allowed within: button, del, fieldset, iframe, ins, noframes, noscript, object, td, th.
207 The tag:"td" is not allowed within: "center". No valid contexts are specified for this element in currently active versions.
208 In HTML 4.0, FONT is deprecated. It may become obsolete in future versions, consider using style sheets instead.
211 The tag:"td" is not allowed within: "font". No valid contexts are specified for this element in currently active versions.
217 Nesting error, "font" should be closed before closing "table"
217 Nesting error, "div" should be closed before closing "table"
217 The tag: " td" allows optional end tag. End tag: "table" closes "td" context. Validation will proceed as if the tag were ended.
217 The tag: " td" allows optional end tag. End tag: "table" closes "td" context. Validation will proceed as if the tag were ended.Nesting error, "center" should be closed before closing "table"
193 No closing tag was found for the "center" tag, which must be closed. |
