[E-smith] inbellen naar zonnet werkt niet
  • sko
  • Laatst online: 06-06 16:00
hallo,
zodra ik mijn e-smith server heb ingesteld op zonnet kan ik niet inbellen, op tmfweb of iets anders lukt het wel, ook kan ik op windows xp inbellen op zonnet.
dit komt uit /var/log/messages:
TMFweb: (de werkende)
Oct 21 06:30:45 dozer ipppd[873]: rcvd [1][PAP AuthAck id=0x11msg=""]
Oct 21 06:30:45 dozer ipppd[873]: Remote message:
Oct 21 06:30:45 dozer ipppd[873]: MPPP negotiation, He: No We: No
Oct 21 06:30:45 dozer ipppd[873]: sent [1][IPCP ConfReq id=0x1 <addr 0.0.0.0>]
Oct 21 06:30:45 dozer ipppd[873]: CCP enabled! Trying CCP.
Oct 21 06:30:45 dozer ipppd[873]: CCP: got ccp-unit 0 for link 1 (Compression Control Protocol)
Oct 21 06:30:45 dozer ipppd[873]: ccp_resetci!
Oct 21 06:30:45 dozer ipppd[873]: rcvd [1][IPCP ConfReq id=0x8a <addr 195.18.127.6>]
Oct 21 06:30:45 dozer ipppd[873]: sent [1][IPCP ConfAck id=0x8a <addr 195.18.127.6>]
Oct 21 06:30:45 dozer ipppd[873]: rcvd [1][proto=0xc02b] 01 70 00 0a 01 06 44 98 fc 82
Oct 21 06:30:45 dozer ipppd[873]: Unsupported protocol 'BACP Bandwidth Allocation Control Protocol' (0xc02b) received
Oct 21 06:30:45 dozer ipppd[873]: sent [1][LCP ProtRej id=0x2 c0 2b 01 70 00 0a 01 06 44 98 fc 82]
Oct 21 06:30:45 dozer ipppd[873]: rcvd [1][IPCP ConfNak id=0x1 <addr 195.18.79.203>]
Oct 21 06:30:45 dozer ipppd[873]: sent [1][IPCP ConfReq id=0x2 <addr 195.18.79.203>]
Oct 21 06:30:45 dozer ipppd[873]: rcvd [1][IPCP ConfAck id=0x2 <addr 195.18.79.203>]
Oct 21 06:30:45 dozer ipppd[873]: local IP address 195.18.79.203
Oct 21 06:30:45 dozer ipppd[873]: remote IP address 195.18.127.6
Oct 21 06:30:45 dozer diald[919]: connector: Interface up: host indeterminate
Oct 21 06:30:45 dozer diald[919]: Connected to site 62.100.13.2
Oct 21 06:30:45 dozer diald[919]: Open device ippp0
Zonnet:
Oct 18 21:20:17 dozer ipppd[876]: rcvd [0][PAP AuthAck id=0x12msg=""]
Oct 18 21:20:17 dozer ipppd[876]: Remote message:
Oct 18 21:20:17 dozer ipppd[876]: MPPP negotiation, He: No We: No
Oct 18 21:20:17 dozer ipppd[876]: sent [0][IPCP ConfReq id=0x1 <addr 0.0.0.0>]
Oct 18 21:20:17 dozer ipppd[876]: CCP enabled! Trying CCP.
Oct 18 21:20:17 dozer ipppd[876]: CCP: got ccp-unit 0 for link 0 (Compression Control Protocol)
Oct 18 21:20:17 dozer ipppd[876]: ccp_resetci!
Oct 18 21:20:17 dozer ipppd[876]: rcvd [0][IPCP ConfReq id=0x1 <compress VJ 0f 00>]
Oct 18 21:20:17 dozer ipppd[876]: sent [0][IPCP ConfRej id=0x1 <compress VJ 0f 00>]
Oct 18 21:20:17 dozer ipppd[876]: rcvd [0][IPCP ConfNak id=0x1 <addr 62.59.0.217>]
Oct 18 21:20:17 dozer ipppd[876]: sent [0][IPCP ConfReq id=0x2 <addr 62.59.0.217>]
Oct 18 21:20:17 dozer ipppd[876]: rcvd [0][IPCP ConfReq id=0x2]
Oct 18 21:20:17 dozer ipppd[876]: sent [0][IPCP ConfNak id=0x2 <addr 0.0.0.0>]
Oct 18 21:20:17 dozer ipppd[876]: rcvd [0][IPCP ConfAck id=0x2 <addr 62.59.0.217>]
Oct 18 21:20:17 dozer ipppd[876]: rcvd [0][IPCP ConfReq id=0x3]
Oct 18 21:20:17 dozer ipppd[876]: sent [0][IPCP ConfAck id=0x3]
Oct 18 21:20:17 dozer ipppd[876]: Could not determine remote IP address
Oct 18 21:20:17 dozer ipppd[876]: sent [0][IPCP TermReq id=0x3 "Could not determine remote IP address"]
Oct 18 21:20:17 dozer ipppd[876]: rcvd [0][IPCP TermAck id=0x3]
Oct 18 21:20:17 dozer kernel: Received CCP frame from peer
zoals je ziet stuurt zonnet ineens
waarna mijn server opnieuw een ip-adres vraagt, wat is hier aan de hand?
thnx, sko
  • sko
^schop^
vergelijk de gevraagde instellingen van beide providers eens. Soms wordt er een gateway vereist bij anderen juist niet. Ook dat kan een reden zin hiervoor (bij Chello kabel moet ik ook een gateway onder Linux invullen terwil dat onder Windows niet hoeft...)
  • sko
volgens mij gaat er gewoon iets fout met dhcp.. (?) of noem je het niet zo met ppp? ik heb ook nog een ander nummer van zonnet geprobeerd (zon gratis) maar dat werkt ook niet, ook niet met een andere distro.. zijn er hier mensen die inbellen met linux bij zon (kwadraat)? en hoe hebben die dat geconfigd?
