[RH7.1] EXT2-fs error
  • I_stealth_I
  • Laatst online: 18-09 19:07
I_stealth_I
Tweak It OR leave it!
Vandaag keek ik eens in me messages log en daar zag ik een log staan die er naar mij inzien nogal ernstig uitziet. Ik kijk niet zo vaak in logs, bak draait 87 dagen.
Oct 20 06:03:07 stealthnet kernel: init_special_inode: bogus imode (35070)
Oct 20 06:04:49 stealthnet kernel: hdc: dma_intr: status=0x51 { DriveReady SeekComplete Error }
Oct 20 06:04:49 stealthnet kernel: hdc: dma_intr: error=0x40 { UncorrectableError }, LBAsect=44040374, sector=44040248
Oct 20 06:04:49 stealthnet kernel: end_request: I/O error, dev 16:05 (hdc), sector 44040248
Oct 20 06:04:49 stealthnet kernel: EXT2-fs error (device ide1(22,5)): ext2_read_inode: unable to read inode block - inode=2752513, block=5505031
Oct 20 06:05:41 stealthnet kernel: hdc: dma_intr: status=0x51 { DriveReady SeekComplete Error }
Oct 20 06:05:41 stealthnet kernel: hdc: dma_intr: error=0x40 { UncorrectableError }, LBAsect=44040374, sector=44040248
Oct 20 06:05:41 stealthnet kernel: end_request: I/O error, dev 16:05 (hdc), sector 44040248
Oct 20 06:05:41 stealthnet kernel: EXT2-fs error (device ide1(22,5)): ext2_read_inode: unable to read inode block - inode=2752530, block=5505031
Oct 20 06:05:45 stealthnet kernel: hdc: dma_intr: status=0x51 { DriveReady SeekComplete Error }
Oct 20 06:05:45 stealthnet kernel: hdc: dma_intr: error=0x40 { UncorrectableError }, LBAsect=44040374, sector=44040248
Oct 20 06:05:45 stealthnet kernel: end_request: I/O error, dev 16:05 (hdc), sector 44040248
Oct 20 06:05:46 stealthnet kernel: EXT2-fs error (device ide1(22,5)): ext2_read_inode: unable to read inode block - inode=2752538, block=5505031
Oct 20 06:05:51 stealthnet kernel: hdc: dma_intr: status=0x51 { DriveReady SeekComplete Error }
Oct 20 06:05:51 stealthnet kernel: hdc: dma_intr: error=0x40 { UncorrectableError }, LBAsect=44040374, sector=44040248
Oct 20 06:05:51 stealthnet kernel: end_request: I/O error, dev 16:05 (hdc), sector 44040248
Oct 20 06:05:51 stealthnet kernel: EXT2-fs error (device ide1(22,5)): ext2_read_inode: unable to read inode block - inode=2752532, block=5505031
Oct 20 06:05:55 stealthnet kernel: hdc: dma_intr: status=0x51 { DriveReady SeekComplete Error }
Oct 20 06:05:55 stealthnet kernel: hdc: dma_intr: error=0x40 { UncorrectableError }, LBAsect=44040374, sector=44040248
Oct 20 06:05:55 stealthnet kernel: end_request: I/O error, dev 16:05 (hdc), sector 44040248
Oct 20 06:05:55 stealthnet kernel: EXT2-fs error (device ide1(22,5)): ext2_read_inode: unable to read inode block - inode=2752535, block=5505031
Betekend dit dat mijn jaar oude HD totaal gaar aan het worden is of is er iets anders aan de hand. Ziet er heel erg dramatisch uit 'UncorrectableError' Iemand die hier mij wat uitsluitsel over kan geven?
/dev/null
Als ik jou was zou ik zsm backups maken van belangrijke dingen, daarna rebooten in singleuser mode en met fsck je schijf nalopen.
Heb je toevallig recentelijk met hdparm zitten spelen?
Het lijkt er een beetje op dat je disk naar z'n galemiezen is.
  • deadinspace
  • Laatst online: 20-09 13:27
deadinspace
The what goes where now?
Ziet er niet jofel uit... Is hdc je HD?
Is dit zo uit de lucht komen vallen, of heb je zelf iets gedaan (herinstall, andere kernel bijv)?
  • I_stealth_I
I_stealth_I
Verwijderd schreef op 20 oktober 2002 @ 21:47:
Ik heb nergens mee zitten spelen. Machine draait bijna 90 dagen op deze kernel met 90 dagen uptime.
/dev/null
  • deadinspace
deadinspace
Dan is het waarschijnlijk hardware.
Het betreft in deze errors alleen sector 44040248. Kijk anders eens goed in je logs (evt mbv grep) of andere sectors ook problemen hebben gegeven, of draai het programmaatje badblocks eens op je HD (eerst manpage lezen!) en kijk welke sectors die niet kan lezen.
Je kunt eventueel met een DOS bootdisk met tooltjes van je harddisk fabrikant nog wat fixen (het is mogelijk dat die die slechte sector kan remappen naar een reserve-sector).
  • I_stealth_I
I_stealth_I
deadinspace schreef op 20 oktober 2002 @ 22:25:
periode 23-09 t/m 06-10 kwam het nog niet voor, heb even logs terug gekeken. Maar in hoeverre is dit nadelig zo'n bad block? Komen er meerdere is de harde schijf bijna aan het einde van z'n latijn?
/dev/null
  • deadinspace
deadinspace
Mja, het kan gewoon slijtage zijn, of door een plotselinge schok komen.
Het kan zijn dat er meer volgen, maar het kan ook zijn dat het hier bij blijft...
Ik had er een paar (aaneengesloten) op mijn laptop... Later waren ze weer pleite :?
hmmm hd is interdaad gaar aan het worden ik zou een nieuwe mounten en overzetten
