[XFREE] Problemen
Ik heb 2 problemen met X
1refreshrate
2 intelli
ik heb met google en de search hier gezocht naar antwoorden
maar niet gevonden
er is wel een intillimouse thread maar die gaat over de instelbare knoppen ( niet mijn probleem)
1 Refreshrate
ik heb een radeon 8500 en een iiyama s900MT1
mij XF86Config voor de monitor&en vga ziet er zo uit
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
# Monitor section
# Any number of monitor sections may be present
Section "Monitor"
    Identifier  "My Monitor"
# HorizSync is in kHz unless units are specified.
# HorizSync may be a comma separated list of discrete values, or a
# comma separated list of ranges of values.
# NOTE: THE VALUES HERE ARE EXAMPLES ONLY.  REFER TO YOUR MONITOR'S
# USER MANUAL FOR THE CORRECT NUMBERS.
    HorizSync   75 - 80
#    HorizSync  30-64         # multisync
#    HorizSync  31.5, 35.2    # multiple fixed sync frequencies
#    HorizSync  15-25, 30-50  # multiple ranges of sync frequencies
# VertRefresh is in Hz unless units are specified.
# VertRefresh may be a comma separated list of discrete values, or a
    VertRefresh 75-85
EndSection
# Graphics device section
# Any number of graphics device sections may be present
Section "Device"
    Identifier  "VESA Framebuffer"
    Driver      "vesa"
    #VideoRam    4096
    # Insert Clocks lines here if appropriate
EndSection
# Screen sections
# Any number of screen sections may be present.  Each describes
# the configuration of a single screen.  A single specific screen section
# may be specified from the X server command line with the "-screen"
# option.
Section "Screen"
    Identifier  "Screen 1"
    Device      "VESA Framebuffer"
    Monitor     "My Monitor"
# If your card can handle it, a higher default color depth (like 24 or 32)
# is highly recommended.
#   DefaultDepth 8
#   DefaultDepth 16
   DefaultDepth 24
#   DefaultDepth 32
# "1024x768" is also a conservative usable default resolution.  If you
# have a better monitor, feel free to try resolutions such as
# "1152x864", "1280x1024", "1600x1200", and "1800x1400" (or whatever your
# card/monitor can produce)
    Subsection "Display"
        Depth       8
        Modes "1024x768" "800x600" "640x480"
    EndSubsection
        Depth       16
    EndSubsection
        Depth       24
        Modes "1800x1400" "1600x1200" "1280x1024"
    EndSubsection
        Depth       32
    EndSubsection
EndSection
ik wil em op 1280x1024 @ 85 hz zetten
ik heb al veel geprobeert met
HorizSync en VertRefresh
maar zonder succes
2 Intellimouse
hij doet het wel klik enz maar de scrollwiel doet helemaal nix m`n config voor de muis ( ik heb dit van die intelii mouse thread)
Section "InputDevice"
# Identifier and driver
    Identifier  "Mouse1"
    Driver  "mouse"
    Option "Protocol"    "IMPS/2"
    Option "Device"      "/dev/psaux"
    Option "ZAxis Mapping"  "4 5"
    Option "Emulate3Buttons"     "yes"
EndSection
alvast bedankt (krijg hoofdpijn van de 60 hz mode:( )
  • intoxicated
intoxicated
Haaaai :w | ALT-S
Heb je de goede HorizSync en VertRefresh uit het boekje van je monitor gehaald, of heb je HorizSync gegokt? En, waarom gebruikt je de Vesa driver en niet de Ati-driver?
En voor je muis moet het zijn:
Option "ZAxisMapping" "4 5"
en niet 'ZAxis Mapping'
"Anyone who does not agree with me is mentally sick, and should be shot I'm afraid to say."
- Pastor Richards @ VCPR
Ik heb ZAxisMapping ook al geprobeert
en ik dacht dat er geen drivers waren voor ati
had wel ergens Aty gezien tussen de andere driver maar dus moet het zijn
Section "Device"
    Driver      "ati"
    #VideoRam    4096
EndSection
oke refreshrate is me nu gelukt ik heb em nu op ati staan en doettie het
maar die muis vind ik tog heel raar
want de config die ik gebruik werkt bij andere mensen wel???
mn lsmod ziet er zo uit .
Module                  Size  Used by    Not tainted
pcmcia_core            40896   0
ide-scsi                7456   0
ne2k-pci                4928   1
8390                    5792   0  [ne2k-pci]
es1371                 27840   1
gameport                1308   0  [es1371]
ac97_codec              9568   0  [es1371]
soundcore               3236   4  [es1371]
ntfs                   48544   2  (autoclean)
geen id of dit iets boeit maargoed .
Emulate3buttons is voor 2 knops muizen, niet voor 5 knops muizen.
  • LollieStick
  • Laatst online: 10-09 11:48
*blaat* }:O
Muis:
Option "Device" "/dev/mouse"
Option "ZAxismapping" "4 5"
Als je de muis op USB hebt, probeer hem eens op PS/2 te gooien en de instellingen zoals hierboven te gebruiken.
hij stond altijd al op ps/2
maar hoe zit het nou met emulate3buttons hoe moet die dan
gewoon # ervoor of op false/no
  • LollieStick
een # :)
k hebbik gedaan
Identifier "Mouse1"
Driver "mouse"
# Option "Emulate3Buttons" "yes"
is het nu ... maar no scroll :(
Je zult hem ook even moeten vertellen dat ie 5 buttons heeft. Dus deze even toevoegen:
Option  "Buttons" "5"
Je kunt ook even alleen 'PS/2' als protocol proberen.
Ik heb alle mogelijke opties gehad nou maar het kreng werkt nog steeds niet
moet er misschien nog andere driverstjes geladen worden ofzo
Niet om het een of ander, maar is je intellimouse toevallig een USB-muis?
[ Voor 0% gewijzigd door Verwijderd op 21-10-2002 21:06 . Reden: /me post vlugger dan hij de thread leest |:( ]
Ja het is een usb muis maar aangesloten op ps/2 met dan verlengstukkie
kweet niet of het wat boeit ???
kan ik em niet proberen op usb te installeren maakt dat wat uit >
ik heb em nu op usb maar nog steeds zonder succes
zijn er hier ook mensen een explorer op usb ?
  • zerok
  • Laatst online: 18-09 14:41
zerok
geen
zo staat die bij mij een logitech dat wel:
    Identifier  "Mouse1"
    Driver      "mouse"
EndSection
"never argue with idiots they drag you down to their level and beat you with experience" dilbert
werkt ook niet hier
zijn er geen andere instellingen behalve die van xfree die bepalend zijn voor de muis ???????
  • imdos
  • Laatst online: 16-09 17:04
imdos
I use FreeNAS and Ubuntu
draait gpm toevallig :? Ik heb hier ook wel eens problemen mee gehad en nadat ik die weghaalde was het opgelost.
[dumb-mode-on]
O, en je restart X toch wel na een config-change
[dumb-mode-off]
pvoutput. Waarom makkelijk doen, als het ook moeilijk kan! Every solution has a new problem
uhm gpm
zie de wel eens staan voor het regeltje
"starting X11 window manager"
was da precies
en hoe zet ik die uit ?
  • Slaiter
Slaiter
Firesnake
man gpm :?
