ABIT BE7 (RAID) ervaringen
  • 49 views sinds 30-01-2008
  • ou812
  • Laatst online: 18:12
Iemand al ervaringen hiermee?
CPU
. Supports Intel Pentium 4 Socket 478 processors with 400/533 MHz Front Side Bus
Chipset
. Intel 845PE / ICH4
. Supports Ultra DMA 33/66/100
. Accelerated Graphics Port connector supports AGP 4X Interface (1.5V only)
Memory
. Three 184-pin DIMM sockets (unbuffered Non-ECC DIMM)
. Supports 2 DIMM DDR 200/266/333 or 3 DIMM DDR 200/266 (Max. 2GB)
ATA133 RAID
. On board High Point HPT372 IDE RAID controller, Supports ATA133 HDDs with RAID 0/1/0+1
Audio
. On board ALC650 6-Channel CODEC
USB 2.0
. Supports 6 Ports USB 2.0 at 480 Mb/sec transfer rate
LAN
. On board RTL8100B 10/100M PCI Fast Ethernet Controller
System BIOS
. SoftMenu™ Technology to set CPU parameters
. Supports Plug-and-Play (PNP)
. Supports Advanced Configuration Power Interface (ACPI)
Internal I/O Connectors
. 1 AGP slot, 5 PCI slots
. 1 x Floppy Port supports up to 2.88MB
. 2 x Ultra DMA 33/66/100 Connectors
. 2 x USB headers, 1 x IrDA header
. 1 x CD-IN, 1 x AUX-IN
Back Panel I/O
. 1 x PS/2 Keyboard, 1 x PS/2 mouse
. 2 x Serial Port connectors, 1 x Parallel Port connector
. 1 x S/PDIF Out connector
. Audio connectors (Center/Sub, Surround Speaker)
. Audio connectors (Front Speaker, Line-in, Mic-in)
. 2 x USB, 1 x RJ-45 LAN Connector
Miscellaneous
. ATX form factor
. Hardware monitoring - Including Fan speeds, Voltages, CPU and System environment temper
  • BalusC
BalusC
Carpe diem
Voor alle "M'n PC doet het niet" en "Ervaringen" topics!
Alléén specs is niet genoeg en vragen ernaar ook niet echt.. Neem gewoon dat bord en post dan hier je eigen ervaringen neer :)
