Wat voor geheugen op deze mobo's
  • 45 views sinds 30-01-2008
Nu de geheugenprijsjes weer lekker laag zijn ga ik maar ff geheugen inkopen, maar weet niet wat voor soort geheugen er in deze mobo's moet:
Abit BH6 rev. 1.2
In de handleiding staat:
(5) Installing System Memory
The motherboard provides three 168-pin DIMM sites for memory expansion. The DIMM socket supports 1Mx64(8MB), 2Mx64(16MB), 4Mx64(32MB), 8Mx64(64MB), 16Mx64(128MB), 32Mx64(256MB) or double sided DIMM modules. Minimum memory size is 8MB and maximum memory size is 768MB SDRAM.
There are three Memory module sockets on the system board. (Total six banks)
In order to create a memory array, certain rules must be followed. The following set of rules allows for optimum configurations.
- The memory array is 64 or 72 bits wide. (Without parity or with parity)
- Those modules can be populated in any order.
- Support single and double density DIMMS.
The following is the valid memory configuration:
| Bank      | Memory Module      | Total Memory |
| Bank 0, 1 | 8MB, 16 MB, 32MB   | 8MB ~ 256MB  |
| (DIMM1)   | 64MB, 128MB, 256MB |              |
| Bank 2, 3 | 8MB, 16 MB, 32MB   | 8MB ~ 256MB  |
| (DIMM2)   | 64MB, 128MB, 256MB |              |
| Bank 4, 5 | 8MB, 16 MB, 32MB   | 8MB ~ 256MB  |
| (DIMM3)   | 64MB, 128MB, 256MB |              |
| Total System Memory            | 8MB ~ 768MB  |
Supported SDRAM Memory Configurations:
29
30
31
32
33
34
35
36
37
| DRAM  | DRAM   | DRAM  | DRAM  | DRAM DIMM | DRAM       | MA                | DRAM              |
|       |        |       |       |           |            |                   | Size              |
| Type  | Tech   | Depth | Width | SS  | DS  | Addressing | Row | Col | Banks | Min     | Max     |
|       |        |       |       | x64 | x64 |            |     |     |       | (1 row) | (2 row) |
| SDRAM | 16 M   | 1M    | 16    | 1M  | 2M  | Asymmetric | 12  | 8   | 2     | 8MB     | 16MB    |
|       |        | 2M    | 8     | 2M  | 4M  | Asymmetric | 12  | 9   | 2     | 16MB    | 32MB    |
|       |        | 2M    | 8     | 2M  | 4M  | Asymmetric | 13  | 8   | 2     | 16MB    | 32MB    |
|       |        | 4M    | 4     | 4M  | 8M  | Asymmetric | 12  | 10  | 2     | 32MB    | 64MB    |
|       |        | 4M    | 4     | 4M  | 8M  | Asymmetric | 14  | 8   | 2     | 32MB    | 64MB    |
| SDRAM | 64 M   | 2M    | 32    | 2M  | 4M  | Asymmetric | 12  | 9   | 2     | 16MB    | 32MB    |
|       | 2 Bank | 2M    | 32    | 2M  | 4M  | Asymmetric | 13  | 8   | 2     | 16MB    | 32MB    |
|       |        | 4M    | 16    | 4M  | 8M  | Asymmetric | 12  | 10  | 2     | 32MB    | 64MB    |
|       |        | 4M    | 16    | 4M  | 8M  | Asymmetric | 14  | 8   | 2     | 32MB    | 64MB    |
|       |        | 8M    | 8     | 8M  | 16M | Asymmetric | 14  | 9   | 2     | 64MB    | 128MB   |
|       |        | 16M   | 4     | 16M | 32M | Asymmetric | 14  | 10  | 2     | 128MB   | 256MB   |
| SDRAM | 64 M   | 2M    | 32    | 2M  | 4M  | Asymmetric | 13  | 8   | 4     | 16MB    | 32MB    |
|       | 4 Bank | 4M    | 16    | 4M  | 8M  | Asymmetric | 14  | 8   | 4     | 32MB    | 64MB    |
|       |        | 8M    | 8     | 8M  | 16M | Asymmetric | 14  | 9   | 4     | 64MB    | 128MB   |
|       |        | 16M   | 4     | 16M | 32M | Asymmetric | 14  | 10  | 4     | 128MB   | 256MB   |
Het is niet bepaald Excel, maar de tabel staat er :*)
Kan iemand mij deze tabel ff uitleggen, want snap er eerlijk gezegd weinig tot niks van. 8)7 Het enige dat ik weet dat een single sided DIMM 64 datalijnen heeft en een double sided DIMM 128, maar van deze tabel snap ik niets :?
Gateway mobo:
Ik heb geen naam bij dit mobo dan Pentium II LX systeemplaat (staat op de voorkant van het boekje) en dat deze uit een Gateway2000 komt.
Verder staat er in het boekje:
Geheugen installeren
De systeemplaat van uw computer ondersteunt SDRAM (Synchronous Dynamic Random Access Memory) en DIMM's (Dual In-line Memory Modules).
DIMM's betekenen een verbetering van de geheugencapaciteit, omdat ze een 64-bits datapad bieden waarmee een grotere hoeveelheid gegevens over de systeemplaat kan worden uitgewisseld. Het tot dusver gebruikelijke geheugentype was SIMM (met een enkele rij aansluitpennen) kwam niet verder dan een 32-bits datapad.
De systeemplaat bevat drie DIMM-voetjes, aangeduid als bank 0, bank 1 en bank 2.
U kunt bank 0, bank 1 of bank 2, danwel elke mogelijke combinatie van banken vullen met DIMM's. Er zijn geen jumperinstellingen vereist voor de grootte of het type van het geheugen. Deze informatie wordt automatisch vastgesteld door het BIOS. U kunt gebruikmaken van 8, 16, 32, 64 en 128 MB DIMM's in elke mogelijke combinatie, bank of volgorde om het SDRAM uit te breiden tot 384 MB.
Moet ik hier nu single of double sided geheugen van 128 MB in stoppen? :?
  • Abbadon
  • Laatst online: 12:58
Zie de RAM FAQ, daar wordt het wel in uitgelegd wat die tabel betekent.
Wat jouw bord betreft, da's een BX en daar kunnen maximaal 128Mbit chips in van het formaat 16Mx8. Dus zijn double-sided 256MB DIMM's de max. Als je een 128MB DIMM wilt gebruiken moet je er een nemen met of 8 (16Mx8) of 16 (8Mx8) chips. Check ook de search, dit is al héél vaak langs gekomen ;) Oh, er staan ook xMx4 chips in de tabel, maar die mogen alleen als ze op een registered DIMM zitten.
