Even een lap txt, mijn instellingen Mocht ik dit ook elders kunnen uploaden, hou ik me aanbevolen
FREESCO v0.2.7 System Report. Generated - Tue Oct 15 19:07:54 2002
----- clock -----
Tue Oct 15 19:07:56 2002
----- cat /etc/system.cfg -----
# [System]
ROUTER=ethernet # 0.dialup/leased/ethernet/bridge
HOSTNAME=ipc #711.Router name
DOMAIN=*** #712.(Local) domain name
ENAMSQ=y # 11.Enable NAT and firewall
ENABRG=n # 12.Enable bridging mode? DONT OUCH!!!
BIGMEM=y # 13.If 16+MB RAM start ppp bsd compression
SAVERS=5,24 # 14.Savers - screen(min),hdd(x5 sec) 0 -off
SWPSIZE=0 # 15.Swap size in Kb on boot device. 0 - off
LOGSIZE=50000,5000 # 16.System_log,logins_log sizes (bytes)
DEFISP= # 6.Default dialup ISP
# [Services] # y - worldwide/s - local/n - disable
ENADNS=s #411.Enable caching DNS server
LOGDNS=y #412.Enable debug info
ENADHCP=s #421.Enable DHCP server
WINSADDR= #422. WINS address (for DHCP server)
LIZTIME=604800,604800 #423. default-lease-time,max-lease-time
ENAWWW=s #431.Enable Public HTTP Server
WWWPORT=80 #432. on port
ENAWWA=s #441.Enable Time Server and control via HTTP
WWAPORT=82 #442. on port
TIMADDR=www.clock.org #443.Host timeserver address, empty - disable
TIMZONE=+0100 #444. Offset to UTC (-1200 -:- +1200)
ENALPD=n #451.Enable Print Server
LPPORT1=515 #452. on port
LPDEV1=lp1 #453. on output device
LPPORT2=516 #454.Second lp server on port, empty - disable
LPDEV2=lp2 #455. on output device
ENATEL=s # 46.Enable telnet server
# [Security]
TRUSTLN=p #211.Trust local nets y/n/p{artual}
TRUSTMD=y #212.Modem links have access to local networks
RINGS=2,7 #220.Rings before answer at login,nologin time
MonTIM="" #221.Nologin times for modem users
TueTIM="" #222
WedTIM="" #223
ThuTIM="" #224
FriTIM="" #225
SatTIM="" #226
SunTIM="" #227
# [Modems]
MODEM0= # 51.1st modem
MSPEED0= # 52.port's speed
MINIT0="" # 53.init string
MTU0= #541.Maximum Transmit Unit
MRU0= #542.Maximum Receive Unit
MADDR0=192.168.168.2 # 55.ppp link remote addr (for dialin purpose)
MODEM1= # 61
MSPEED1= # 62
MINIT1="" # 63
MTU1= #641
MRU1= #642
MADDR1=192.168.168.3 # 65.I said for dialin purpose.
# [leased line router]
ADRTYPE=dynamic #921.if ISP supplies us with dynamic IP, then:
LOCAL=127.0.0.2 #922.fake local side ppp IP addr
REMOTE=127.0.0.3 #923.fake remote addr
# [ethernet/leased/printer/ras router]
GATEWAY=***.**.***.* #911.Default gateway, if exist.
DNSADDR=*** #912.Primary DNS address for ethernet connection
DNSADDR1=*** #913.Secondary DNS address for ethernet connection
PROXY="proxy.arnhem.chello.nl:8080" #914.HTTP proxy addr[:port]
# [Hardware]
IO0=0 #811.1st ethernet card I/O address
IRQ0=11 #812.IRQ line
IO1=0 #821
IRQ1=0 #822
IO2=0 #831
IRQ2=0 #832
# [Networks]
USEDHCP0=n #720.Use DHCP client to config this interface
INTNAME0=eth0 #721.Interface name (eth0|arc0e|arc0)
DHCPLOG=y #722.Enable DHCP client messages in the log
DHCPDNS=y #723 Enable auto configuration of DNS via DHCP
IPADDR0=*** #724.IP adress of this interface
NETMASK0=255.255.255.0 #725.Network mask
NETWORK0=*** # Network address
BRDCAST0=*** # Broadcast address
#726.IP pool, empty disables DHCP on this interface
IPRANGE0=""
INTNAME1=eth1 #731.Interface name (eth1|eth0:1|arc0e|arc0 etc)
IPADDR1=192.168.0.1 #732. Second network
NETMASK1=255.255.255.0
NETWORK1=192.168.0.0
BRDCAST1=192.168.0.255
IPRANGE1="192.168.0.100 192.168.0.110"
INTNAME2= #74x. Third network
IPADDR2=
NETMASK2=
NETWORK2=
BRDCAST2=
IPRANGE2=""
----- cat /etc/live.cfg -----
VER=0.2.7
bootdev=fd0
UPTIME="Tue Oct 15 19:00:05 2002"
DONE="echo Done"
----- cat /etc/dhcpc/dhcpcd-eth0.info -----
----- cat /etc/forward.cfg -----
#_47x._[Port_forwarding_AKA_export_services]
#_
#_tcp|udp,incoming_port,local_computer_IP_addr/port
#_
#_Example:_t,80,192.168.168.2/80
#_this_will_open_worldwide_web_server_on_local_computer_192.168.168.2
#_
#_Example:_t,21,192.168.168.3/21
#_this_will_open_worldwide_ftp_server_on_local_computer_192.168.168.2
#_
#_Comment_must_be_on_separate_line_start_with_"#_"_and_should_not_have_spaces
----- cat /etc/banlist.cfg -----
#_23._[List_of_banned_hosts/nets_one_record_per_line]
#_
#_local|external,IP_addr[/netmask_or_netbits_if_baning_a_whole_net]
#_
#_Example:_l,123.124.125.0/24_ban_local_net
#_Example:_e,123.124.125.0/255.255.255.0_ban_external_net
#_Example:_l,10.0.0.123_ban_local_host
#_
#_Comment_must_be_on_separat_lines_start_with_"#_"_and_should_not_have_spaces
----- sed -n 1,/AUTH/P /etc/chat.pwd -----
----- lsmod -----
Module Pages Used by
/tmp/net/rtl8139.o.C 3 2
new_tunnel 1 0
ipip 1 0
ip_masq_ftp 1 0
ip_masq_irc 1 0
ip_masq_quake 1 0
ip_masq_vdolive 1 0
ip_masq_raudio 1 0
ip_masq_icq 1 0
ip_masq_cuseeme 1 0
8390 2 0
----- dmesg | grep eth -----
eth0: RealTek RTL8139 Fast Ethernet at 0x6200, IRQ 11, 00:50:bf:1c:31:9a.
eth1: RealTek RTL8139 Fast Ethernet at 0x6300, IRQ 10, 00:50:bf:1c:38:af.
----- ifconfig -----
lo Link encap:Local Loopback
inet addr:127.0.0.1 Bcast:127.255.255.255 Mask:255.0.0.0
UP BROADCAST LOOPBACK RUNNING MTU:3584 Metric:1
RX packets:63 errors:0 dropped:0 overruns:0
TX packets:63 errors:0 dropped:0 overruns:0
eth0 Link encap:10Mbps Ethernet HWaddr 00:50:BF:1C:31:9A
inet addr:***** Bcast:****Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0
TX packets:11 errors:0 dropped:0 overruns:0
Interrupt:11 Base address:0x6200
eth1 Link encap:10Mbps Ethernet HWaddr 00:50:BF:1C:38:AF
inet addr:192.168.0.1 Bcast:192.168.0.255 Mask:255.255.255.0
TX packets:0 errors:0 dropped:0 overruns:0
Interrupt:10 Base address:0x6300
----- cat /proc/interrupts -----
0: 49221 timer
1: 697 keyboard
2: 0 cascade
6: 100 + floppy
8: 1 + rtc
10: 0 eth1
11: 11 eth0
13: 0 math error
----- cat /proc/ioports -----
0000-001f : dma1
0020-003f : pic1
0040-005f : timer
0060-006f : keyboard
0070-007f : rtc
0080-009f : dma page reg
00a0-00bf : pic2
00c0-00df : dma2
00f0-00ff : npu
0378-037f : lp
03c0-03df : vga+
03f0-03f5 : floppy
03f7-03f7 : floppy DIR
03f8-03ff : serial(auto)
6200-627f : eth0
6300-637f : eth1
----- route -n -----
Kernel routing table
Destination Gateway Genmask Flags MSS Window Use Iface
255.255.255.255 * 255.255.255.255 UH 1500 0 0 eth1
255.255.255.255 * 255.255.255.255 UH 1500 0 0 eth0
***** * 255.255.255.0 U 1500 0 1 eth0
192.168.0.0 * 255.255.255.0 U 1500 0 0 eth1
127.0.0.0 * 255.0.0.0 U 3584 0 2 lo
default 213.93.176.1 * UG 1500 0 2 eth0
----- cat /etc/dhcpd.leases -----
lease 192.168.0.101 {
starts 0 2001/12/02 13:47:14;
ends 0 2001/12/09 13:47:14;
hardware ethernet 00:50:bf:1c:31:9a;
uid 01:00:50:bf:1c:31:9a;
lease 192.168.0.100 {
starts 6 2001/12/01 10:51:04;
ends 6 2001/12/08 10:51:04;
hardware ethernet 00:50:bf:1c:39:39;
uid 01:00:50:bf:1c:39:39;
client-hostname "Lennart";
----- free -----
total: used: free: shared: buffers: cached:
Mem: 48250880 9662464 38588416 4403200 2985984 1134592
Swap: 0 0 0
MemTotal: 47120 kB
MemFree: 37684 kB
MemShared: 4300 kB
Buffers: 2916 kB
Cached: 1108 kB
SwapTotal: 0 kB
SwapFree: 0 kB
Mounted FS:
/dev/root / ext2 rw 0 0
/proc /proc proc rw 0 0
/dev/fd0 /mnt umsdos rw 0 0
Filesystem 1024-blocks Used Available Capacity Mounted on
/dev/ram0 2548 1554 994 61% /
/dev/fd0 1424 1382 42 97% /mnt
----- ps -----
Pid Stat Parent Name Command
1 S 0 init initauto
2 S 1 kflushd
3 S 1 kswapd
4 S 1 logrotate sh/bin/logrotate
6 S 1 syslogd syslogd-r-h-m0
8 S 1 klogd klogd
19 S 1 daemon sh/bin/daemon-agetty 9600 tty2
21 S 19 agetty agetty9600tty2
167 S 1 named named
192 S 1 dhcpd dhcpd-qeth1
334 S 1 thttpd thttpd-p82-uroot-d/wwa-l/dev/null
338 S 1 thttpd thttpd-p80-unobody-d/www-l/dev/null
341 S 1 daemon sh/bin/daemon-synctimesleep 180002>/dev/null
343 S 1 daemon sh/bin/daemon-telnetd -debug
345 S 343 telnetd telnetd-debug
375 S 1 daemon sh/bin/daemon-agetty 9600 tty1
431 S 341 sleep sleep180002>/dev/null
604 S 375 ile ile
617 S 604 sh sh
629 S 4 sleep sleep10
630 S 617 report sh/bin/report
657 R 630 ps sh/bin/ps
----- cat /etc/ppp/opt* -----
asyncmap 0
----- setserial -bg /dev/cua? -----
/dev/cua0 at 0x03f8 (irq = 4) is a 16550A
hoi
