DPC OGR25-hitparade van 11 oktober Vorige deel Overzicht Volgende deel Laatste deel
  • 161 views sinds 30-01-2008
  • Blistimo
  • Laatst online: 28-05-2021
Blistimo
Pestcontrol
Pfff.. wat flauw zeg.. zo dichtbij.. [insert random 'irri2k' joke here] :P
Are you OGR,RC5=0,DES=0,CSC=0'ized yet? }:O
DPC top 30 van 11 oktober 2002
1.(43)90.485Graasland5.133.333(6)
2.(1)40.744EliteHackers.com19.905.039(2)
3.(49)36.097Opperkoe205.855(118)
4.(91)29.416De Unie's187.446(126)
5.(3)28.257Digital Pizza Crew1.391.008(27)
6.(27)27.639Rulende_Bikkels1.868.883(18)
7.(3)27.492Team BVD1.639.087(21)
8.(3)23.962Division Eindhoven1.812.424(19)
9.(8)19.955The Fonz23.875.543(1)
10.(4)16.882JiveY1.105.686(38)
11.(4)14.810#marijse OGR Team3.633.538(12)
12.(5)12.646Stappel7.615.734(3)
13.(10)11.696brum103 2.744.633(14)
14.(2)10.663DTC Computershops332.407(91)
15.(6)9.995Burnin'Cows1.625.963(22)
16.(3)8.147Team Supercows.nl: Let's Moowh!1.680.837(20)
17.()8.145Pallas Athene CSHH128.349(169)
18.(4)7.363-Killemall asks: When does this all end :?287.551(103)
19.()7.353Joost van den Berg29.465(412)
20.()6.974Thugbear with [Vengeance]20.913(496)
21.()6.700The Holy Cows go AttiX87.595(218)
22.(4)6.459100% TGA, and D.net still owes us 2P nodes!!!!!!!!7.412.998(4)
23.(4)6.412Theetjuh1.016.982(43)
24.()6.248nicoclown 7.080(773)
25.(16)5.699Bobco1.198.583(32)
26.(6)5.626van Bekkum Clan Unite With Bouwpub !41.646(335)
27.()5.337darknite 64.774(252)
28.(1)5.169Zaandam Posse4.396.893(9)
29.(4)4.623Jan van Loenen56.225(276)
30.()4.525Shadow_47_ 116.083(184)
Top 15 teams
1.()668.861iri2K [Fr]6.254.418(82)
2.()650.696Dutch Power Cows207.054.995(1)
3.()538.735HZTeam. United power of Russia and other xUSSR countries.37.297.366(16)
4.(9)375.578Team Win32 (Windows)45.471.552(11)
5.()303.800Russian Team71.261.341(5)
6.(2)300.160Team Depaul66.318.129(6)
7.(1)252.772The Amiga RC5 Team effort82.157.656(4)
8.(2)252.358AnandTech160.155.347(2)
9.(2)208.018Slashdot.org109.401.098(3)
10.(1)186.751Team Warped (OS/2)44.307.005(12)
11.(1)153.568moomin35.876.606(17)
12.(24)140.327Japan Linux Users Group25.914.789(23)
13.(3)135.771Ars Technica Team Beef Roast34.804.224(18)
14.()131.813German Hardware Network2.297.783(220)
15.(6)121.616Team EvangeLista (Macs Rule! :-)60.281.999(7)
Mijlpalen
Division Eindhoven1.800.000
ScoutLink DPC-Force400.000
Opperkoe200.000
De Unie's180.000
HeinZ120.000
darknite 60.000
Westwood DC60.000
van Bekkum Clan Unite With Bouwpub !40.000
Thugbear with [Vengeance]20.000
Leden
Aantal leden1.832
Verschil met vorige dag4
Nieuwe leden4
Retirements0
Welkom bij DPC J?RR?N G , DPC NoW, Dr. Flash, alper !
D3 char(s)
Uhmm Jahaa ... Graasland roelt ! >:)
WHOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOT
hahahaha
beetje jammer dat we deze output niet bij seti hebben ;)
Woei alweer een mijlpaaltje en we gaan lekker zo :)
O ja, waar kan je trouwens zien hoelang dit project nog duurt :?
  • JustMe
  • Laatst online: 06-11-2022
JustMe
#1 R@H
Verwijderd schreef op 12 oktober 2002 @ 08:30:
Dat kan niet 8)7
Cureseekers | There's something wrong with this yogurt
  • CBA
  • Laatst online: 22-11 18:30
CBA
een vat, een vat, een vat !
argh weeral net niet in de top30 :(
en niet eerste, hmm HZ gaat ook hard
Diablo 3 Profiel - WoW Warrior
  • bigbakkus
  • Registratie: September 1999
  • Laatst online: 26-05-2009
bigbakkus
Moehoehoe
wel weer in de top 30 :) van Bekkum Clan to the rescueeeee 8)7
vanbekkumclan is trots www.losalcoholicos.nl member
  • NightBird
  • Laatst online: 09:49
NightBird
DPC-Crew Coding
Doe nou niet RC5=0 .. straks is OGR afgelopen, zitten we weer met al die nutteloze clients opgescheept :)
WatHoorJeWaar · Asobakken
Eerdere projecten: Leading Courses · Brandstof-zoeker.nl · Voertuig-zoeker.nl
  • Gulpener
  • Laatst online: 22-08-2024
Gulpener
zelluf!
I have posted the status of OGR to this list in the past, but perhaps
it's time for a restatement.
Status of OGR
* The OGR client has a bug which weakens the accuracy of our results.
A truncation error causes rulers with many segments to be aborted
incorrectly. We were making some good progress towards fixing this bug
and releasing new clients when we solved RC5-64. At that point, all OGR
development was put on hold in favor of RC5-72.
Because of the verification plan we are using, we do not expect to have
to discard work done with current buggy clients unless the bug affected
the results for a given stub. Our original plan was to require two
identical results for the same stub from different participants. Now we
will be revising that to say that one of the results must also come from
a "fixed" client. If the buggy client gives the same results as the
fixed client, the bug was not a factor. If the buggy client gives a
different result, then we wait for a confirmation from a different
participant using the fixed client.
Status of OGR stats
* Progress is very hard to compute for OGR, relative to the RC5
projects. For RC5, we only need to track whether the work was completed
or not (a single bit of information). For OGR, it is necessary to track
what participant completed each stub (and now, we must also track
whether the client was pre-fix or post-fix). We also keep track of how
many nodes were found in each stub, to verify that the participants got
the same results. In all, the storage requirement per workunit is
orders of magnitude greater than RC5-64 - we go from one bit (1/8 of a
byte) per workunit to about 50 bytes. This is just the beginning.
In order to report on the progress of the project, we have to determine
which stubs have been completed once, and which have been completed
twice. This means verifying that the second submitter is different from
the first, and got the same result. While we had a mechanism in place
early in the project for calculating this, it was highly
manual-intensive, and took a long time to run. Somewhere along the
line, the database where these calculations were created has been lost
(I think I heard it was lost through disk failure, but that could be
wrong). Some work has been put into recreating this database and the
process that went into it, but this is not simple work, and the ones
with the specific knowledge have had very limited time. Again, the end
of RC5-64 drew our attention away from OGR stats.
Aldus Bruce Wilson op de distributed.net mailing list.
http://lists.distributed.net/hypermail/rc5.Oct2002/0061.html
Haal diep adem. telt tot 10.. en gewoon door grazen. }:O
  • stok
Woei!
And Opperkoe is back :P
IP/DNS problemen zijn als het goed is voorgoed geschiedenis.
/edit:
En we zijn hard op weg naar de top100 overall binnen DPC :)
/edit2:
En een mijlpaal (200k :P)
/edit3:
naah, laat maar :o
NightBird schreef op 12 oktober 2002 @ 10:25:
Straks? Geoloog zeker? ("Mag het een miljoen jaar meer of minder zijn mevrouw?") Nee als OGR25 afgelopen is neem ik aan dat we vrolijk met OGR26 beginnen. Toch?
Enne, voor RC5-72 had je toch een nieuwe client nodig?
  • CBA
CBA
Verwijderd schreef op 12 oktober 2002 @ 12:38:
Dat dacht ik ook
stokkie schreef op 12 oktober 2002 @ 11:19:
Woei!
/edit:
/edit2:
/edit3:
naah, laat maar :o
_/-\o_
