[freebsd] dhcp probleem
Ik probeer van een server met Freebsd 4.5 een dhcp server te maken voor mijn interne netwerk. Daarop zitten pc's aangesloten met Windows 98.
Als ik in win98 zeg dat het ipnummer automatisch moet worden gezocht en DNS uit wordt gezet werkt ut niet :( Het werkt wel als ze een vast ip nummer krijgen
Hieronder staat mijn dhcpd.conf
# dhcpd.conf
# Sample configuration file for ISC dhcpd
# option definitions common to all supported networks...
option domain-name "example.org";
option domain-name-servers 192.168.0.1;
default-lease-time 600;
max-lease-time 7200;
# If this DHCP server is the official DHCP server for the local
# network, the authoritative directive should be uncommented.
#authoritative;
# ad-hoc DNS update scheme - set to "none" to disable dynamic DNS updates.
ddns-update-style ad-hoc;
# Use this to send dhcp log messages to a different log file (you also
# have to hack syslog.conf to complete the redirection).
#log-facility local7;
# No service will be given on this subnet, but declaring it helps the
# DHCP server to understand the network topology.
#subnet 10.152.187.0 netmask 255.255.255.0 {
#subnet 217.120.0.0 netmask 255.255.254.0 {
# This is a very basic subnet declaration.
subnet 192.168.0.0 netmask 255.255.255.0 {
range 192.168.0.2 192.168.0.255;
option routers 192.168.0.1;
# This declaration allows BOOTP clients to get dynamic addresses,
# which we don't really recommend.
#subnet 10.254.239.32 netmask 255.255.255.224 {
# range dynamic-bootp 10.254.239.40 10.254.239.60;
# option broadcast-address 10.254.239.31;
# option routers rtr-239-32-1.example.org;
# A slightly different configuration for an internal subnet.
#subnet 10.5.5.0 netmask 255.255.255.224 {
# range 10.5.5.26 10.5.5.30;
# option domain-name-servers ns1.internal.example.org;
# option domain-name "internal.example.org";
# option routers 10.5.5.1;
# option broadcast-address 10.5.5.31;
# default-lease-time 600;
# max-lease-time 7200;
# Hosts which require special configuration options can be listed in
# host statements. If no address is specified, the address will be
# allocated dynamically (if possible), but the host-specific information
# will still come from the host declaration.
#host passacaglia {
# hardware ethernet 0:0:c0:5d:bd:95;
# filename "vmunix.passacaglia";
# server-name "toccata.fugue.com";
# Fixed IP addresses can also be specified for hosts. These addresses
# should not also be listed as being available for dynamic assignment.
# Hosts for which fixed IP addresses have been specified can boot using
# BOOTP or DHCP. Hosts for which no fixed address is specified can only
# be booted with DHCP, unless there is an address range on the subnet
# to which a BOOTP client is connected which has the dynamic-bootp flag
# set.
#host fantasia {
# hardware ethernet 08:00:07:26:c0:a5;
# fixed-address fantasia.fugue.com;
# You can declare a class of clients and then do address allocation
# based on that. The example below shows a case where all clients
# in a certain class get addresses on the 10.17.224/24 subnet, and all
# other clients get addresses on the 10.0.29/24 subnet.
#class "foo" {
# match if substring (option vendor-class-identifier, 0, 4) = "SUNW";
#shared-network 224-29 {
# subnet 10.17.224.0 netmask 255.255.255.0 {
# option routers rtr-224.example.org;
# subnet 10.0.29.0 netmask 255.255.255.0 {
# option routers rtr-29.example.org;
# pool {
# allow members of "foo";
# range 10.17.224.10 10.17.224.250;
# pool {
# deny members of "foo";
# range 10.0.29.10 10.0.29.230;
Dit lijkt me allemaal goed maar toch geeft mijn dhcp server dus geen ipnummer aan pc;s in het lokale netwerk
  • RdeTuinman
  • Registratie: Mei 2001
  • Laatst online: 16-08 07:25
ff een wilde gok: houd je evt. firewall de dhcpcd en/of bootp poorten niet dicht toevallig? Verder weet ik niets van deze configfile, sorry.
nee, mijn firewall houdt niks dicht
  • Leon
  • Laatst online: 19-08 12:12
Leon
Rise Of The Robots
wat geeft dhcpd als melding als je hem start :?
Eeuwige n00b
