vanavond krijg ik voor de 2e keer het volgende error bij het opstarten van win2000:
windows 2000 could not start because the folloing file missing or corrupt:
\winnt\system32\config\systemced startup option for windows 2000, press F8
You can attempt to repair this file by starting windows 2000 setup using the original setup floppy disk or cd-rom.
Select 'r' at the first screen to start repair
Wat vervelend is dat ik vergeet om ERD te maken, dus maak ik eentje van ander PC.
Maar het mocht niet baten. Moet ik echt ERD van desbetrefeende PC maken?
Iemand hetzelfde probleem meegemaakt ?
O ja, effe bij technet geweest, er staat voor de recovery console:
1. Press R to choose the Repair a Windows 2000 Installation option.
2. When the Windows 2000 Repair Options dialog box is displayed, press C to start Recovery Console.
3. The next dialog box displays a list of operating systems that are installed. Type the number of the Windows 2000 installation that you want to select.
4. Type the local Administrator password, and then press ENTER.
Note Recovery Console requires that you type the local Administrator password to gain access to the system volume. You are given three chances to type the correct password before the computer is restarted. However, if the computer does not contain any Windows 2000 computer files, a command prompt is automatically displayed.
5. When the password is validated, a command prompt is displayed at the SystemRoot folder of the installation that you selected (for example, C:\Winnt).
wat betekent : Type the number of the Windows 2000 installation that you want to select.
Cigarette + Coffee = Breakfast of champion
