Cisco Pix 501/506
  • 54 views sinds 30-01-2008
Beste mannen,
Heeft iemand ervaringen met cisco pixjes type 501 en 506
De bedoeling is een VPN te creeren over de ADSL .
Zijn dit echt zulke goede beestjes of hebben jullie andere ervaringen
  • DPG
  • Laatst online: 23-03-2022
DPG
Biertje?
werken prima......
Voorbeeld config:
PIX Version 6.1(3)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password jepass
passwd jepass
hostname JEFIREWALL
domain-name jedomain.nl
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list INBEL permit ip 192.168.16.0 255.255.255.0 10.1.1.0 255.255.255.224
pager lines 24
interface ethernet0 10baset
interface ethernet1 10full
mtu outside 1500
mtu inside 1500
ip address outside x.x.x.x 255.255.255.252
ip address inside 192.168.16.254 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool VPNPOOL 10.1.1.1-10.1.1.30
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list INBEL
nat (inside) 1 192.168.16.0 255.255.255.0 0 0
route outside 0.0.0.0 0.0.0.0 212.203.11.170 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
http server enable
http 192.168.16.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
sysopt connection permit-l2tp
sysopt ipsec pl-compatible
no sysopt route dnat
crypto ipsec transform-set METHODE esp-des esp-md5-hmac
crypto dynamic-map EBO 8 set transform-set METHODE
crypto map partner-map 8 ipsec-isakmp dynamic EBO
crypto map partner-map client configuration address initiate
crypto map partner-map interface outside
isakmp enable outside
isakmp key jekey address 0.0.0.0 netmask 0.0.0.0
isakmp client configuration address-pool local VPNPOOL outside
isakmp policy 8 authentication pre-share
isakmp policy 8 encryption des
isakmp policy 8 hash md5
isakmp policy 8 group 2
isakmp policy 8 lifetime 86400
telnet 192.168.16.250 255.255.255.254 inside
telnet timeout 5
ssh timeout 5
terminal width 80
Cryptochecksum:jechecksum
: end
We work in the dark....We give what we have....Our doubt is our passion....and our passion is our task....The rest is the madness of art.---@ Henry James @---.
  • Predator
  • Laatst online: 10:53
Predator
Suffers from split brain
www.cisco.com, meer dan genoeg config info
en als topicstart kan dit in PNS niet door de beugel:
http://gathering.tweakers.net/forum/faq/forumgedrag#topicstart
Everybody lies | BFD rocks ! | PC-specs
