[F@H] Electron Microscope III v2.0.0 (New)
Genome 2 Tracking
Extra Launch Commands
Project Number Display Added
Server Info Display Added
Number of Amino Acids Display Added
Several new features added and a jump in major versions. This first release is a beta. Genome tracking is now enabled in EM III. EM III will currently only track Genome work units when using the F@H3 client. Genome Classic is not currently supported. The feature will enable automatically when a Genome work unit is downloaded and run.
Because some extra features can be enabled when launching the client, you can now add extra commands. These commands will only be added when launching local instances of the client. The extra commands currently are:
-forceasm (Force core assembly optimizations to be used if available)
-advmethods (Use new advanced scientific cores and/or work units)
The -local command is not necessary or needed as EM III adds that automatically when you select to use EM III to launch the client(s). Do not add the -local command!
The Project Number, Work Unit Server, and Amino Acid info (Only applies to Genome Work Units) is now displayed along with the Run/Clone/Generation info.
The F@H info will be displayed like this:
(Project) Run/Clone/Generation [Server]
The G@H info will be displayed like this:
(Project) Amino Acids [Server]
Get it here: http://www.em-dc.com
Afbeeldingslocatie: http://www.em-dc.com/images/latestem.jpg
Wow :9~
kep um gedownload en ze um aan als mijn huidige ogr25 pakketjes klaar zijn
  • Crack
  • Laatst online: 27-07 00:14
Crack
...ehh.......Mooh?!?
Thanks Larry,
The G@H-support is just what I needed.
Keep up the good work.
Wereldrecord voor ChicaneLinacB90 Badges
Ik kan me nog herinneren dat MrGuide ook ooit zoiets in elkaar wilde klussen: Folding@Home Feature Requests Nieuwe front-end Hoe staat het daarmee?
Verwijderd schreef op 07 oktober 2002 @ 13:01:
Dat klopt helemaal. Op dit moment wordt er gewerkt aan het server-deel van de front-end. De front-end zal namelijk bestaan uit een server- en client-deel. Op die manier zal het mogelijk zijn om de f@h client vanaf afstand te kunnen beheren en monitoren. Het programma wordt dan ook een stuk uitgebreider dan ik had voorzien, dus vandaar duur het zo lang. De huidige verwachting is dat er zo tussen 1 á 2 maanden een resultaat beschikbaar is
