ik heb een cisco 800 die elke dag blijft uitbellen. Volgens mij is dit een DNS request oid.
Hoe kom ik hier vanaf??
Router cisco 800 hangt aan een proxyserver (windows 2000 pro sp3)
routerconfig:
Current configuration:
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname router
enable secret 5
enable password 7
username ikke password
no ip subnet-zero
no ip source-route
no ip domain-lookup
isdn switch-type basic-net3
call-history-mib max-size 50
interface Ethernet0
description connected to EthernetLAN
ip address 192.168.1.2 255.255.255.0
ip access-group 121 in
no ip proxy-arp
ip nat inside
interface BRI0
description connected to Internet,Dial-inPCs(ISDN)
no ip address
ip nat outside
encapsulation ppp
dialer pool-member 1
dialer pool-member 2
isdn tei-negotiation first-call
isdn send-alerting
ppp authentication chap pap callin
ppp multilink
interface Dialer1
description ISP
ip address ip provider 255.255.255.248
no ip proxy-arp
ip nat outside
encapsulation ppp
no ip split-horizon
dialer remote-name Cisco1
dialer pool 1
dialer idle-timeout 300
dialer string 0676011830 class DialClass
dialer string 00676011830 class DialClass
dialer caller xxxxxxxxxxx callback
dialer hold-queue 10
dialer load-threshold 10 either
dialer-group 1
pulse-time 0
no cdp enable
ppp chap hostname Idewier1
ppp chap password 7 xxxxxxxxxxxxxxxxxxxx
ppp pap sent-username Idewier1 password 7 xxxxxxxxxxxxxx
ppp multilink
interface Dialer2
description to
ip unnumbered Ethernet0
ip nat inside
encapsulation ppp
dialer remote-name Dail-inpcs(ISDN)
dialer pool 2
dialer-group 1
peer default ip address pool INETWEB-Group-2
no cdp enable
ppp multilink
ip local pool INETWEB-Group-2 172.16.2.252 172.16.2.253
ip nat pool ISPNATPool 193.67.30.131 193.67.30.135 netmask 255.255.255.248
ip nat pool INETWEB-natpool-1 193.67.30.128 193.67.30.135 netmask 255.255.255.248
ip nat inside source list 1 pool INETWEB-natpool-1 overload
ip nat inside source list 18 pool ISPNATPool
ip nat inside source static tcp 192.168.1.1 25 193.67.30.130 25 extendable
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
map-class dialer DialClass
access-list 1 permit 172.16.2.0 0.0.0.255
access-list 18 permit 192.168.1.0 0.0.0.255
access-list 121 deny udp any eq netbios-dgm any
access-list 121 deny udp any eq netbios-ns any
access-list 121 deny udp any eq netbios-ss any
access-list 121 deny tcp any eq 137 any
access-list 121 deny tcp any eq 138 any
access-list 121 deny tcp any eq 139 any
access-list 121 permit ip any any time-range TIME
dialer-list 1 protocol ip permit
line con 0
exec-timeout 120 0
password 7
login
transport input none
stopbits 1
line vty 0 4
exec-timeout 0 0
password 7
login local
no rcapi server
time-range Internetverkeer
periodic daily 9:00 to 18:00
end
routerconfig:
version 12.1
no service pad
hostname router
enable secret 5
enable password 7
no ip subnet-zero
no ip source-route
no ip domain-lookup
interface Ethernet0
no ip proxy-arp
ip nat inside
interface BRI0
no ip address
ip nat outside
encapsulation ppp
isdn send-alerting
ppp multilink
interface Dialer1
description ISP
no ip proxy-arp
ip nat outside
encapsulation ppp
no ip split-horizon
dialer pool 1
dialer-group 1
pulse-time 0
no cdp enable
ppp multilink
interface Dialer2
description to
ip nat inside
encapsulation ppp
dialer pool 2
dialer-group 1
no cdp enable
ppp multilink
no ip http server
ip classless
line con 0
exec-timeout 120 0
password 7
login
stopbits 1
line vty 0 4
exec-timeout 0 0
password 7
login local
no rcapi server
end
