[wineX] CS
  • 122 views sinds 30-01-2008
ik heb dus wine geinstalled
maar als ik nu de cs setup wil doen
(ik ga naar /mnt/cdrom)
en doe dan 'wine setup.exe' krijg ik dit[
29
30
31
32
33
34
35
36
37
38
39
40
root@huski cdrom2]# wine setup.exe
fixme:ttydrv:TTYDRV_BITMAP_SetDIBits (0x40392084, 0x40391efc, 0, 32, 0x407fbb94, 0x4039204c, 0, 0x0050): stub
fixme:ttydrv:TTYDRV_BITMAP_SetDIBits (0x403920c4, 0x40391efc, 0, 32, 0x407fbc14, 0x4039204c, 0, 0x0054): stub
fixme:ttydrv:TTYDRV_BITMAP_SetDIBits (0x40392348, 0x40391efc, 0, 32, 0x407fbcd4, 0x40392310, 0, 0x0058): stub
fixme:ttydrv:TTYDRV_BITMAP_SetDIBits (0x40392388, 0x40391efc, 0, 32, 0x407fbd54, 0x40392310, 0, 0x005c): stub
fixme:ttydrv:TTYDRV_BITMAP_SetDIBits (0x40392658, 0x40391efc, 0, 11, 0x407fd710, 0x40392620, 0, 0x0064): stub
fixme:ttydrv:TTYDR_BITMAP_SetDIBits (0x40392708, 0x40391efc, 0, 18, 0x407fe6e8, 0x40392698, 0, 0x0068): stub
fixme:ttydrv:TTYDRV_CreateWindow (10020): stub
fixme:ttydrv:TTYDRV_BITMAP_SetDIBits (0x40392acc, 0x40391efc, 0, 32, 0x406158, 0x40392a5c, 0, 0x0074): stub
fixme:ttydrv:TTYDRV_BITMAP_SetDIBits (0x40392b0c, 0x40391efc, 0, 32, 0x406358, 0x40392a5c, 0, 0x0078): stub
fixme:ttydrv:TTYDRV_BITMAP_SetDIBits (0x403afa1c, 0x403af674, 0, 32, 0x406158, 0x40392ac8, 0, 0x0088): stub
fixme:ttydrv:TTYDRV_DC_StretchBlt (0x403af674, 0, 0, 16, 16, 0x403af814, 0, 0, 32, 32, 13369376): stub
fixme:ttydrv:TTYDRV_BITMAP_SetDIBits (0x403afaa4, 0x403af674, 0, 32, 0x406358, 0x40392ac8, 0, 0x0094): stub
fixme:ttydrv:TTYDRV_DC_StretchBlt (0x403af674, 0, 0, 16, 16, 0x403af97c, 0, 0, 32, 32, 13369376): stub
fixme:ttydrv:TTYDRV_DC_GetBitmapBits (0x403af814, 0x40392ad4, 32): stub
fixme:ttydrv:TTYDRV_DC_GetBitmapBits (0x40392b38, 0x40392af4, 32): stub
fixme:ttydrv:TTYDRV_CreateWindow (10021): stub
fixme:ttydrv:TTYDRV_CreateWindow (10022): stub
fixme:ttydrv:TTYDRV_PALETTE_SetMapping (0x4037251a, 0, 16, 0): stub
fixme:ttydrv:TTYDRV_BITMAP_SetDIBits (0x403b016c, 0x403af97c, 0, 110, 0x403ab3f0, 0x403ab388, 0, 0x00a4): stub
fixme:ttydrv:TTYDRV_DC_StretchBlt (0x403af97c, 0, 0, 300, 110, 0x403b0044, 0, 0, 300, 110, 13369376): stub
fixme:ttydrv:TTYDRV_DC_ExtTextOut (0x403af97c, 8, 6, 0x00000000, (nil), L"Half-Life: Counter-Strike Autorun", 33, (nil)): stub
fixme:ttydrv:TTYDRV_DC_ExtTextOut (0x403af97c, 30, 55, 0x00000004, 0x406c26c8, L"Initializing Wise Installation"..., 30, (nil)): stub
fixme:ttydrv:TTYDRV_DC_ExtTextOut (0x403af97c, 114, 63, 0x00000004, 0x406c26c8, L"Wizard..."..., 9, (nil)): stub
fixme:ttydrv:TTYDRV_BITMAP_SetDIBits (0x403b0e00, 0x40391efc, 0, 11, 0x407fd710, 0x403b0dc8, 0, 0x00b0): stub
fixme:ttydrv:TTYDRV_BITMAP_SetDIBits (0x403b0f6c, 0x40391efc, 0, 18, 0x407fe6e8, 0x403b0e40, 0, 0x00b4): stub
fixme:ttydrv:TTYDRV_CreateWindow (10023): stub
fixme:ttydrv:TTYDRV_CreateWindow (10024): stub
fixme:ttydrv:TTYDRV_CreateWindow (10025): stub
fixme:ttydrv:TTYDRV_CreateWindow (10026): stub
fixme:ttydrv:TTYDRV_BITMAP_SetDIBits (0x403b2368, 0x40391efc, 0, 39, 0x407fea90, 0x403b2330, 0, 0x00c0): stub
fixme:ttydrv:TTYDRV_CreateWindow (10027): stub
fixme:ttydrv:TTYDRV_CreateWindow (10028): stub
fixme:ttydrv:TTYDRV_CreateWindow (10029): stub
fixme:ttydrv:TTYDRV_CreateWindow (1002a): stub
fixme:ttydrv:TTYDRV_CreateWindow (1002b): stub
fixme:ttydrv:TTYDRV_CreateWindow (1002c): stub
fixme:win:SetWindowTextA cannot set text "Could not initialize installation. System DLLs corrupt or missing. DLL init fail"... of other process window 0
Segmentatie fout
mijn config ziet erzo uit
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
WINE REGISTRY Version 2
;; All keys relative to \\Machine\\Software\\Wine\\Wine\\Config
;; If you think it is nescessary to show others your complete config for a
;; bug report, filter out empty lines and comments with
;; grep -v "^;" ~/.wine/config | grep '.'
;; MS-DOS drives configuration
;; Each section has the following format:
;; [Drive X]
;; "Path"="xxx"       (Unix path for drive root)
;; "Type"="xxx"       (supported types are 'floppy', 'hd', 'cdrom' and 'network')
;; "Label"="xxx"      (drive label, at most 11 characters)
;; "Serial"="xxx"     (serial number, 8 characters hexadecimal number)
;; "Filesystem"="xxx" (supported types are 'msdos'/'dos'/'fat', 'win95'/'vfat', 'unix')
;;   This is the FS Wine is supposed to emulate on a certain
;;   directory structure.
;;   Recommended:
;;   - "win95" for ext2fs, VFAT and FAT32
;;   - "msdos" for FAT16 (ugly, upgrading to VFAT driver strongly recommended)
;;   DON'T use "unix" unless you intend to port programs using Winelib !
;; "Device"="/dev/xx" (only if you want to allow raw device access)
[Drive C]
"Path" = "/c"
"Type" = "hd"
"Label" = "Dos Drive"
"Filesystem" = "win95"
[Drive D]
"Path" = "${HOME}"
"Type" = "hd"
"Label" = "My Home"
[Drive E]
"Path" = "/tmp"
"Type" = "hd"
"Label" = "tmp"
[Drive G]
"Path" = "/"
"Type" = "hd"
"Label" = "root"
[wine]
"Windows" = "c:\\windows"
"System" = "c:\\windows\\system\\"
"Temp" = "e:\\"
"Path" = "c:\\windows\\;c:\\windows\\system\\"
"GraphicsDriver" = "ttydrv"
; Wine doesn't pass directory symlinks to Windows programs by default.
; Enabling this may crash some programs that do recursive lookups of a whole
; subdir tree in case of a symlink pointing back to itself.
;"ShowDirSymlinks" = "1"
"ShellLinker" = "/usr/lib/transgaming/winex/bin/wineshelllink"
# <wineconf>
[DllDefaults]
"DefaultLoadOrder" = "native, builtin, so"
[DllOverrides]
"commdlg"      = "builtin, native"
"comdlg32"     = "builtin, native"
"ver"          = "builtin, native"
"version"      = "builtin, native"
"shell"        = "builtin, native"
"shell32"      = "builtin, native"
"shfolder"     = "builtin, native"
"shlwapi"      = "builtin, native"
"shdocvw"      = "builtin, native"
"lzexpand"     = "builtin, native"
"lz32"         = "builtin, native"
"comctl32"     = "builtin, native"
"commctrl"     = "builtin, native"
"advapi32"     = "builtin, native"
"crtdll"       = "builtin, native"
"mpr"          = "builtin, native"
"winspool.drv" = "builtin, native"
"d3d8"         = "builtin, native"
"ddraw"        = "builtin, native"
"dinput"       = "builtin, native"
"dinput8"      = "builtin, native"
"dmusic"       = "builtin, native"
"dsound"       = "builtin, native"
"opengl32"     = "builtin, native"
"msvcrt"       = "native, builtin"
"rpcrt4"       = "native, builtin"
"msvideo"      = "builtin, native"
"msvfw32"      = "builtin, native"
"mcicda.drv"   = "builtin, native"
"mciseq.drv"   = "builtin, native"
"mciwave.drv"  = "builtin, native"
"mciavi.drv"   = "native, builtin"
"mcianim.drv"  = "native, builtin"
"msacm.drv"    = "builtin, native"
"msacm"        = "builtin, native"
"msacm32"      = "builtin, native"
"midimap.drv"  = "builtin, native"
[x11drv]
; Number of colors to allocate from the system palette
"AllocSystemColors" = "100"
; Number of colors to copy from the default palette
"CopyDefaultColors" = "0"
; Use a private color map
"PrivateColorMap" = "N"
; Favor correctness over speed in some graphics operations
"PerfectGraphics" = "N"
; Color depth to use on multi-depth screens
;;"ScreenDepth" = "16"
; Name of X11 display to use
;;"Display" = ":0.0"
; Allow the window manager to manage created windows
"Managed" = "Y"
; Use a desktop window of 640x480 for Wine
;"Desktop" = "800x600"
; Use XFree86 DGA extension if present
; (make sure /dev/mem is accessible by you !)
"UseDGA" = "N"
; Use XShm extension if present
"UseXShm" = "Y"
; Enable DirectX mouse grab
"DXGrab" = "Y"
; Use XVidMode extension if present
"UseXVidMode" = "Y"
; Create the desktop window with a double-buffered visual
; (useful to play OpenGL games)
"DesktopDoubleBuffered" = "Y"
; Code page used for captions in managed mode
; 0 means default ANSI code page (CP_ACP == 0)
"TextCP" = "0"
; Use this if you have more than one port for video on your setup
; (Wine uses for now the first 'input image' it finds).
;; "XVideoPort" = "43"
[fonts]
;Read documentation/fonts before adding aliases
"Resolution" = "96"
"Default" = "-adobe-times-"
[FontPatterns]
"Pattern0" = "-adobe-times*"
"Pattern1" = "-adobe-helvetica*"
"Pattern2" = "-adobe-courier*"
"Pattern3" = "-misc-fixed*"
[serialports]
"Com1" = "/dev/ttyS0"
"Com2" = "/dev/ttyS1"
"Com3" = "/dev/ttyS2"
"Com4" = "/dev/modem"
[parallelports]
"Lpt1" = "/dev/lp0"
[spooler]
"LPT1:" = "|lpr"
"LPT2:" = "|gs -sDEVICE=bj200 -sOutputFile=/tmp/fred -q -"
"LPT3:" = "/dev/lp3"
[ports]
;"read" = "0x779,0x379,0x280-0x2a0"
; "write" = "0x779,0x379,0x280-0x2a0"
[spy]
"Exclude" = "WM_SIZE;WM_TIMER;"
[registry]
;These are all booleans.  Y/y/T/t/1 are true, N/n/F/f/0 are false.
;Defaults are read all, write to Home
; Global registries (stored in /etc)
"LoadGlobalRegistryFiles" = "n"
; Home registries (stored in ~user/.wine/)
"LoadHomeRegistryFiles" = "Y"
; Load Windows registries from the Windows directory
"LoadWindowsRegistryFiles" = "n"
; TRY to write all changes to home registries
"WritetoHomeRegistryFiles" = "Y"
; Registry periodic save timeout in seconds
; "PeriodicSave" = "600"
; Save only modified keys
"SaveOnlyUpdatedKeys" = "Y"
[Tweak.Layout]
;; supported styles are 'Win31'(default), 'Win95', 'Win98'
"WineLook" = "Win98"
[Console]
"Drivers" = "xterm"
;"Drivers" = "tty"
"XtermProg" = "konsole"
;"InitialRows" = "25"
;"InitialColumns" = "80"
;"TerminalType" = "nxterm"
[Clipboard]
"ClearAllSelections" = "0"
"PersistentSelection" = "1"
; List of all directories directly contain .AFM files
[afmdirs]
;"1" = "/usr/share/ghostscript/fonts"
;"2" = "/usr/share/a2ps/afm"
;"3" = "/usr/share/enscript"
;"4" = "/usr/X11R6/lib/X11/fonts/Type1"
[WinMM]
"Drivers" = "wineoss.drv"
"WaveMapper" = "msacm.drv"
"MidiMapper" = "midimap.drv"
[wineoss]
"UseMMap" = "Y"
"FullDuplex" = "N"
;; sample AppDefaults entries
;[AppDefaults\\iexplore.exe\\DllOverrides]
;"shlwapi" = "native"
;"rpcrt4" = "native"
;"ole32" = "native"
;"shdocvw" = "native"
;"wininet" = "native"
;"shfolder" = "native"
;"shell32" = "native"
;"shell" = "native"
;"comctl32" = "native"
;[AppDefaults\\setup.exe\\x11drv]
# </wineconf>
die path naar windows en system kloppen......
ben ik hier de error of is wine het ???
meschien even hier reposten? tis er voor bedoelt enzo.
en het is niet alsof het 4 pagina's naar beneden staat.
WineX 2.0
k kep CS nu draaiend op wineX maar ik kan alleen LANNEN
als ik een internetgame wil joinen zegt ie dat ik alleen een game kan joinen als ik de cstrike custom game heb geinstalled .... vaag dus
want ik install vanaf en retail CD ...
die update heb ik uiteraard al gedaan
maar het vage is dat hij em helemaal niet ziet
ik install vanaf de HL generations CS cd en hij ziet die hele cs mod niet
  • BoGu5
  • Laatst online: 08-09 21:21
BoGu5
hmmmz
Verwijderd schreef op 02 October 2002 @ 19:15:
Ik heb precies hetzelfde probleem, ik heb met de search/google nog geen oplossing kunnen vinden, heeft iemand hier mss al een oplossing voor?
Ik draai winex-cvs 3.1
request.getCookies();
  • blouweKip
  • Laatst online: 10-09 22:37
Beetje oude topic he, maar voor CS kun je beter geen winex gebruiken, winex is voornamelijk gefocust op d3d emulatie, wine is beter voor opengl applicaties (bij mij werkt cs/hl dan ook niet met winex 2,3 of cvs maar wel met wine)
"For my friends, anything; for my enemies, the law."
Verwijderd schreef op 02 oktober 2002 @ 19:15:
Kan je andere mods wel zien? Ik heb zoiets ook gehad, je moet eerst naar de dir waar je halflife hebt geinstalleerd, en dan moet je halflife starten
Ik moest een server joinen door bv een hlsw of gamespy achtig programma te gebruiken. (ik gebruiktte XQF/qstat hiervoor), dan ga je dus niet via de menuutjes in cs zelf maar connect je in 1x.
Probeer eens http://lhl.linuxgames.com...ife-HOWTO-0.5.html#AEN271
[ Voor 6% gewijzigd door Verwijderd op 30-06-2003 23:47 ]
  • blouweKip
Btw, ik herinner me dat ik dit probleem niet had toen ik cs als volgt uitvoerde:
wine -- hl.exe -game cstrike/ -console
  • T-Blizzard
  • Laatst online: 11-09 14:20
Bij mij installde die perfect
Alleen als ik hl wil runnen blaat ie dat ie 16 bits kleuren wil??
Hoe krijg ik dat weg?
  • blouweKip
In wine toevoegen aan je config
[version]
"windows" = "win2k"
In winex weet ik t niet direct, daar kun je misschien nog winver=win2k gebruiken (aangezien het op een oude wine is gebaseerd)
  • T-Blizzard
Ik heb nu de hele game werkend....
alleen lagged me geluid nog een beetje, ook met _snd_ bla bla 0.23
En de textures zijn nie om aan te zien heeeel erg uitgerekt ofzo
  • T-Blizzard
Oke alles werkt nu :) sound en beeld perfect play on lan perfect
alleen bij internet game gaat het fout
fixme:winsock:WS_bind Setting WS_SO_REUSEADDR on socket before we binding it
fixme:winsock:_get_sock_fd handle 0 is not a socket (GLE 6)
fixme:dc:LockWindowUpdate (10021), stub!
fixme:dc:LockWindowUpdate (0), stub!
[ Voor 81% gewijzigd door T-Blizzard op 02-07-2003 17:03 ]
