Certificaat werkt niet.
Ik krijg m'n certificaat niet geïnstalleerd. Wat gaat hier mis :?
Let niet op de rest van de site, hij is nog in aanbouw.
http://www.czgroep.nl/
En dan clicken op "Go to secured site"
  • Rukapul
  • Laatst online: 07:40
Er is geen root certificaat aanwezig voor de Issuer, logisch aangezien het een testcertificaat betreft.
OU = For VeriSign authorized testing only. No assurances (C)VS1997
OU = www.verisign.com/repository/TestCPS Incorp. By Ref. Liab. LTD.
O = VeriSign, Inc
Beetje onduidelijk welk probleem je trouwens bedoelt. Als ik OK klik om het certificaat te accepteren dan krijg ik 'invalid browser':
ActiveX Control Download Error
You may be using a Windows 2000 computer without adequate permissions.
You may have encountered this error because of the following reasons -
You may have clicked 'No' when prompted to download the ActiveX control(s)-If this is the case click the back button of your browser and when prompted to download the ActiveX control click 'Yes'
You may be working on a Windows 2000 machine without adequate permissions-You need to be a Power User or a Local Administrator on this computer and you need to allow ActiveX controls in your browser.If you are not sure whether you have the correct permissions please contact your system administrator and send the following link.
https://certificaten.vecozo.nl/VSApps/win2kCenter.htm
This link contains information that your administrator can use to enable your machine with the necessary software.
You may not have allowed the download of ActiveX controls in your browser-If you are a Power user or a local administrator you need to enable ActiveX controls in your browser and try your operation again. You can enable ActiveX controls in your Internet Explorer options as follows -
IE4 - Go to View->Internet Options menu and select the Security pane.You can either set the security level as Medium or choose Custom Level, ensure that you enable Download signed ActiveX controls and Script ActiveX controls marked safe for scripting
IE5 - Go to Tools->Internet Options menu and select the Security pane.You can either set the default security level as Medium or choose Custom Level, ensure that you enable Download signed ActiveX controls and Script ActiveX controls marked safe for scripting
Dat hele verhaal staat dan weer op een pagina die via SSL beveiligd is waarvoor wel een geldig certificaat is.
  • DeFeCt
  • Laatst online: 31-08 15:42
DeFeCt
je wéét toch
Netjes dat dit zo openstaat.....
Zou dit een verklaring zijn waarom mijn mail na 2 maanden nog steeds niet is beantwoord door CZ ?
(nofi)
Dit lijkt me trouwens niet echt de juiste groep (/13) voor dit soort vragen
[ Voor 0% gewijzigd door DeFeCt op 02-10-2002 15:12 . Reden: probeert behulpzaam te zijn ]
Flickr
  • Rukapul
Wat ranzig trouwens wat voor VBScripts er allemaal in die tussenpagina zitten.
Die copyright statement is ronduit belachelijk :)
| Copyright (C) VeriSign, Inc. created 1996. All rights reserved. |
| This is an unpublished work protected as such under copyright law. |
| This work contains proprietary, confidential, and trade secret |
| information of VeriSign, Inc. Use, disclosure or reproduction |
| without the expressed written authorization of VeriSign, Inc. |
| is prohibited. |
Ik geloof dat ie nu wel published is ;)
