'Zon explodeert in 6 jaar'
  • 54 views sinds 30-01-2008
The Sun Will Explode In Less Than Six Years!
Wednesday September 18, 2002
By GEORGE SANFORD
The Sun is overheating and will soon blow up . . . taking Earth and the rest of the solar system with it, scientists warn.
The alert was issued after an international satellite photographed a massive explosion on the surface of the Sun that sent a plume of fire 30 times longer than the diameter of Earth blasting into space.
"It's a sign that the Sun is ready to blow . . . I don't know if I can put it any more plainly than that," says Dutch astrophysicist Dr. Piers Van der Meer, a top expert affiliated with the European Space Agency.
"It will be like a nuclear bomb trillions of times more powerful than the one dropped on Hiroshima going off at the center of our solar system.
"When that happens Earth will be instantly incinerated along with all life on it. It's like when a marshmallow falls into a fire, blackens and melts."
Scientists say the problem is the Sun is literally getting too hot.
The core temperature of the Sun is normally 27 million degrees Fahrenheit. But in recent years it's climbed to an alarming 49 million degrees, says Dr. Van der Meer, leader of a team of Amsterdam-based space scientists who've been tracking the changes in the Sun.
"It's quite similar to when a star goes supernova at the end of its life," Dr. Van der Meer explains. "Over the past 11 years, we've seen our Sun go through changes frighteningly like those that took place in Kepler's Star right before it was observed going supernova in 1604."
Temperatures on the surface of the Sun have been steadily climbing over the past decade, the scientists say.
"This, we believe, not man-made pollution, is responsible for global warming and the alarming effects that we've seen take place on Earth such as the melt-down of the Antarctic ice shelves," asserted Dr. Van der Meer.
The July 1 images were taken by the space-based Solar and Heliospheric Observatory (SOHO), a satellite designed to study the internal structure of the Sun and operated jointly by NASA and the European Space Agency.
"The explosion . . . known technically as an eruptive prominence . . . was colossal," said Dr. Van der Meer. "This is the final warning sign we've all been dreading."
The Dutch scientists calculate that if temperatures keep climbing at the current rate the Sun will be unable to sustain itself.
"It will blow apart like an out-of-control nuclear reactor within six years," predicts Dr. Van der Meer.
NASA refuses to confirm the Euro-pean scientists' assertions and a White House source said, "We don't need anyone spreading more panic now."
Het bericht is nog niet bevestigd, maar een klein beetje beangstigend is het wel. Dit zinnetje vind ik vooral beangstigend: "NASA refuses to confirm the Euro-pean scientists' assertions...". Waarom geeft de NASA geen duidelijkheid? Waarom zeggen ze niet meteen dat het niet waar is? Als ik bij de NASA zou werken, en ik zou weten dat het WEL waar is, dan zou ik juist een dergelijk bericht naar buiten sturen.
Nu even het bericht zelf. Via fokzine.nl kwam ik het nieuwsbericht tegen in de 'News & Gossip' sectie van Yahoo. Dit kan een aanwijzing zijn dat het een hoax is. Ook kan ik niets over Dr. Piers Van der Meer vinden met google. En als laatste heb ik dit bericht nog niet gezien op sites zoals CNN.com, Space.com, NASA.gov en ESA.int. Dit kan er allemaal op duiden dat het bericht fake is.
Maar wat als dit WEL waar is? Wat kunnen we als mensheid dan nog doen? Ik zeg niets! We kunnen ons niet verplaatsen naar een andere planeet, en we kunnen de aarde zelf ook niet verplaatsen. Zelfs als we de aarde kunnen verplaatsen is het nog weinig zinvol. Zonder de zon is er geen leven meer mogelijk op de aarde, dus het verplaatsen van de aarde is geen optie.
Wat denken jullie van dit bericht? En wat kunnen we als mensheid doen als het wel waar blijkt te zijn?
  • chucky666
chucky666
d.y.w.play?
een OW voor blaten in de IT? laat IT dan maar voortaan links liggen :(
Verwijderd schreef op 02 oktober 2002 @ 11:10:
Dat het ook wel in dat andere topic kon:
De zon explodeert binnen zes jaar...
Uh? Toen ik begon met typen bestond die andere thread nog niet. Jammer :(
  • Flekx
  • Laatst online: 07-11-2025
Ik denk dat we de zes jaar die we nog over hebben alleen maar moeten gaan feesten en zuipen en veel geslachtsgemeenschap moeten hebben!
  • Morgoth
  • Laatst online: 30-10 12:34
En deze kan ook dicht, zie sluitpost in andere thread over dit onderwerp.
