Nero errors, Compaq CDD4801
  • Crysania
  • Laatst online: 13:54
ik krijg nu al 4x achter elkaar de zelfde error.
ik heb al op alle snelheden gebrand en ze gaan allemaal kapot. waar ligt het aan??
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
Windows NT 5.0
WinAspi: -
ahead WinASPI: File 'D:\Nero\Nero\Wnaspi32.dll': Ver=2.0.1.28, size=172099 bytes, created 6/22/2002 15:33:54
Nero Version: 5.5.2.4
Recorder:             <PHILIPS CDD4801 CD-R/RW> Version:  1.5 - HA 2 TA 1 - 5.5.2.4
 Adapter driver:      <atapi>                   HA 2
 Drive buffer  :      2048kB
CD-ROM:               <COMPAQ   DVD-ROM DRD8120B>Version: 1.09 - HA 2 TA 0 - 5.5.2.4
=== Scsi-Device-Map ===
DiskPeripheral       : MAXTOR 6L080J4                   atapi Port 1 ID 0  DMA: On
DiskPeripheral       : IBM-DTLA-307030                  atapi Port 1 ID 1  DMA: On
CdRomPeripheral      : COMPAQ DVD-ROM DRD8120B          atapi Port 2 ID 0  DMA: Off
CdRomPeripheral      : PHILIPS CDD4801 CD-R/RW          atapi Port 2 ID 1  DMA: Off
AutoRun : 0
CmdQueuing     : 1
CmdNotification: 2
WriteBufferSize: 34603008 (0) Byte
ShowDrvBufStat : 0
EraseSpeed     : 0
BUFE           : 0
Physical memory     : 255MB (261680kB)
Free physical memory: 129MB (132236kB)
Memory in use       : 49 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry: 1
Wizard: Off
CD-ROM (ISO)
30.9.2002
18:33:26    #1 Text 0 File Reader.cpp, Line 133
    Reader running
18:33:26    #2 Text 0 File Writer.cpp, Line 125
    Writer CDD4801 CD-R/RW  running
18:33:26    #3 ISO9660GEN -11 File geniso.cpp, Line 4210
    First writeable address = 0 (0x00000000)
18:33:26    #4 Text 0 File ThreadedTransferInterface.cpp, Line 665
    Setup items (original item values)
     0: TRM_DATA_MODE2_FORM1_NOSUB (CTransferItem)
        2 indices, index0 (150) not provided
        original CD pos #0 + 333131 (333131) = #333131/74:1.56
        relocatable, CD pos for caching/writing not required/required, no patch infos
18:33:27    #5 Text 0 File Burncd.cpp, Line 1509
    Recorder:  PHILIPS CDD4801 CD-R/RW;
       CDR code: 00 97 15 17; OSJ entry from: Ritek Co.
       ATIP Data:
         Special    Info [hex] 1: C0 00 90, 2: 61 0F 11 (LI 97:15.17), 3: 4F 3B 49 (LO 79:59.73)
         Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
18:33:27    #6 Text 0 File ThreadedTransferInterface.cpp, Line 800
    Prepare recorder CDD4801 CD-R/RW  for write in TAO
    DAO infos:
    MCN:
    TOCTYPE: 0x20   Close CD
    Tracks 1 to 1:
       TRM_DATA_MODE2_FORM1_NOSUB, 2048/0x0, ISRC "", FilePos 0 307200 682559488
18:33:27    #7 Text 0 File ThreadedTransferInterface.cpp, Line 828
    Removed 2 run-out blocks from end of track 1.
18:33:27    #8 Text 0 File ThreadedTransferInterface.cpp, Line 665
    Setup items (after recorder preparation)
        -> TRM_DATA_MODE2_FORM1_NOSUB, 2048, config 0, wanted index0 0 blocks, length 333129 blocks [CDD4801 CD-R/RW ]
18:33:27    #9 Phase 24 File dlgbrnst.cpp, Line 1353
    Caching of files started
18:33:27    #10 Phase 25 File dlgbrnst.cpp, Line 1353
    Caching of files completed
18:33:27    #11 Phase 36 File dlgbrnst.cpp, Line 1353
    Burn process started at 8x (1200 KB/s)
18:33:27    #12 Text 0 File ThreadedTransferInterface.cpp, Line 1836
    Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
18:41:30    #13 SCSI -1061 File Cdrdrv.cpp, Line 1353
    SCSI Exec, HA 2, TA 1, LUN 0, buffer 0x022F85CC
    Status:     0x04 (0x01, SCSI_ERR)
    HA-Status   0x00 (0x00, OK)
    TA-Status   0x02 (0x01, SCSI_TASTATUS_CHKCOND)
    Sense Key:  0x04 (KEY_HARDWARE_ERROR)
    Sense Code: 0x44
    Sense Qual: 0x85
    CDB Data:   0x2A 0x00 0x00 0x04 0x56 0x00 0x00 0x00 0x1E 0x00 0x00 0x00
    Sense Data: 0xF0 0x00 0x04 0x00 0x04 0x53 0x16 0x13
                0x00 0x00 0x00 0x00 0x44 0x85
18:41:30    #14 mmc -1061 File Writer.cpp, Line 311
    Internal target failure
18:41:30    #15 Text 0 File ThreadedTransfer.cpp, Line 218
    all writers idle, stopping conversion
18:41:30    #16 Text 0 File ThreadedTransfer.cpp, Line 212
    conversion idle, stopping reader
18:41:30    #17 CDR -201 File WriterStatus.cpp, Line 162
    Invalid writestate
18:41:30    #18 TRANSFER -18 File WriterStatus.cpp, Line 162
    Could not perform EndTrack
18:41:30    #19 Phase 38 File dlgbrnst.cpp, Line 1353
    Burn process failed at 8x (1200 KB/s)
18:41:30    #20 Text 0 File Scsicmd.cpp, Line 371
    SCSI not using temporary buffers
    20 out of 20 temporary buffers allocated
Existing drivers:
File 'Drivers\NeroCD2k.sys': Ver=1.0.0.9, size=44227 bytes, created 6/22/2002 15:33:54
  • Brazza
  • Laatst online: 11-09 13:18
Brazza
Byte me!
Staat hij wel als master op je IDE kanaal, Heb je DMA aanstaan? Drive kapot? Firmware update??
  • Crysania
Brazza schreef op 30 september 2002 @ 18:47:
master, ja.
DMA, volgens mij wel
Drive kapot, Ik hoop het niet
Firmware update, het lukt me niet de laatste versie te downloaden, maar hij heeft het eerst wel gedaan, maar sinds gisteren doet hij het niet meer.
  • Angels2
  • Laatst online: 15-03-2025
Sense Key: 0x04 (KEY_HARDWARE_ERROR) Sense Code: 0x44 Sense Qual: 0x85
Dit is een hardware fout. Wou je soms overbranden? Dan is het normaal. Anders niet.
Lees it eens en je ziet dat de brander op de secundary staat, tesamen met een DVDROM en dat de DMA afstaat. Staat beter aan, maar voor een 8sx schrijver maakt dat niet te gek veel uit.
Volgende keer wel je serial en naam wegknippen, dat heeft ons niet te interesseren.
  • Angels2
Je kan eens bij www.philips.com/pcstuff kijken op de website (zoek naar PCRW804) en haal de flashtool af. Je kan van 1.5 naar 2.5. Je ledje gaat niet meer zo mooi zijn, maar er is wel een verbetering van de 1.5 naar de 2.5 firmware.
Die website is wel een echte catastrofe (daar heeft Philips weer eens de prijs gewonnen van de meest onmogelijke website, proficiat...):
kies klantenservice
Onder service voor een product kies je downloaden
Dan kan je pcrw804 kiezen (eender welk land), en dan krijg je het flashtool.
Flash je drive (de firmware zal van dan 2.5 worden).
  • Crysania
Angels2 schreef op 30 september 2002 @ 20:07:
kies klantenservice
dit lukt dus niet, ik heb flashtool geinstalleerd, maar ik zie geen nieuwe drivers staan in het programma terwijl ze wel in de directory staan. dit programma werkt voor geen meter. p.s. ik heb al 4 versies geprobeerd en ze werken allemaal niet.
misschien ligt het aan win2k.
p.s.2 ik was niet aan het overburnen.
  • Angels2
Da's spijtig. Kan je eens in een win98 PC proberen (alhoewel ik mijn drive wel kon flashen met win2000). De file die je nodig hebt is v2_5.cvt.
  • Crysania
Angels2 schreef op 01 oktober 2002 @ 08:38:
ik ben nu bezig met op een ouwe pc windows98 op te zetten. ik hoop dat dti gaat werken
