Het grote ECS K7S5A (3.1) Topic !
  • 52 views sinds 30-01-2008
  • Weezer-DC
  • Laatst online: 13-07 08:52
PROCESSORS
-462 pin Socket A supports the AMD® K7 processors
-Full series of Athlon XP / Athlon / Duron processors
CHIPSET
-SiS® 735 System Chipset
-Super I/O and LPC - ITE8705F
-System Hardware Monitor: Built-in ITE8705
-LAN: MAC integrated in SiS®735 & PHY on board (Optional)
-AC97 Audio Codec
SYSTEM BIOS
-2 DDR DIMM sockets and 2 DIMM sockets support (can not be used simultaneously)
-Two 184-pin DDR SDRAM (DDR200, DDR266) or
-Two 168-pin 3.3V SDRAM (PC100, PC133)
-Maximum: 1.0GB (DDR or SDRAM)
MEMORY
-AMI 2Mb Flash ROM
-Supports Plug and Play 1.0A, AMP 1.2, Multi Boot, DMI
-Full support for ACPI revision 1.0 specification
I/O INTERFACE
-Supports Plug and Play function
-PS/2 keyboard and PS/2 mouse connectors
-Dual USB Ports and LAN connectors
-One - EPP/ECP mode parallel port
-Two - 16550 high-speed serial I/O ports
-Audio Ports (Line-in, Line-out, Mic-in, CD-in and game port)
-Dual PCI IDE interfaces - support four IDE devices (PIO mode 4, DMA Mode 2, Ultra DMA 33/66/100)
-Supports 360K~2.88M Byte, 3 Mode FDDs or LS120
-ATX Power Supply Connector
PORTS, HEADERS AND OTHERS
-IrDA Cable header
-Extra USB header
-Two CD-In headers
-Front Panel MIC/Line-out header
-HDD LED, ACPI MSG LED, Reset Switch, Power Switch headers
-CPU and Case Fan headers
-Modem Ring Wake Up Header
RTC & BATTERY
-SiS®® 735 included 256 bytes of CMOS SRAM
-With CMOS SRAM hardware clear jumper
EXPANSION SLOTS
-5 PCI slots, 1 4X AGP slot, 1 AMR slot
FORM FACTOR
-ATX (304mm*244mm), 4 Layers
Afbeeldingslocatie: http://home.planet.nl/~pijl0188/shared/images/k7s5a.jpg
Gebruik rechter muisknop en kies voor Doel opslaan/Save target
Nieuwste bios, Version 02/08/09 met LAN Release Note, Support AMD Athlon XP 2400+ and 2600+ CPU
Nieuwste bios, Version 02/08/09 zonder LAN Release Note, Support AMD Athlon XP 2400+ and 2600+ CPU
De nieuwste manual, Version 3.1
  • Weezer-DC
En dan meteen mijn probleempje, >:)
ik vind geen Power Led aansluiting,
in de manual kan ik er ook niks over vinden,
iemand hier een oplossing voor ?
  • Daacuso
  • Laatst online: 10-09 17:40
Kan jij niet beter gaan slapen? :?
If you'd ask me what's more important you or my life; I'd answer my life and you'd walk away without knowing that you are my life!
  • nOLoGIc
  • Laatst online: 04-08 20:44
Die is er wel maar is niet compatible met veel kasten. Het is een 2-pins aansluiting gewoon bij HDD-led, powerswitch e.d. Ik heb bij 2 kasten van de 3-pins stekker het middelste (lege) gat er tussenuit moeten knippen.
Op m'n k7s5a brandt de led zoals het hoort en knippert ie in standby.
Op mijn k7s6a (heeft 3-pins maar ook niet standaard) brandt de led alleen in standby mode (pin 1,2 van 3 gebruikt).
Op de k7s6a van een vriend brandt ie ook niet als de bak aanstaat en knippert ie in standby.
Header heet trouwens in de manual "FP PWR/SLP" op pin 2,4 van FPI Connector.
Aangezien dat dit vaak onduidelijk is, hier de oplossing:
FP1 pin nr.
2468
13579
power led op 2-4 (+-)
power knop op 6-8 (+- maakt niets uit)
hdd led op 1-3 (+-)
reset knop 5-7 (+-)
Het kan zijn dat de powerled conector van sommige kasten een drie pins aansluiting hebben, om dit op te lossen is heel simpel: gebruik een naald om het plasic lipje op te tillen en haal de het draad je eruit, verplaatsen naar middelste.
Vindt je dit te moeilijk kan je altijd het connectortje doorknippen.
  • Weezer-DC
Afbeeldingslocatie: http://home.planet.nl/~pijl0188/shared/images/k7s5a1.jpg
Ik heb dus pin 1 verbonden met pin 5,
nu kan ik dus mijn 3 pins power led aansluiting gebruiken,
deze oplossing omdat deze kast nog even heel wou laten,
chieftec kastje wat ik nog geen 24 uur heb ;-)
  • Abbadon
  • Laatst online: 12:58
Oh alsjeblieft. Dit is een oud bord en daar gaan we echt geen 'groot' topic voor openen; er bestaan al honderden topics over dit bord. Topics waar eveneens dit power LED gebeuren aan bod komt. Dus use the search :)
