Wat heeft het voor zin om dit (http://www.overclockers.r...?category=2&id=1032932792) -- 07:17 Intel Celeron 2GHz @ 3GHz silentsnow -- als nieuwslink (http://tweakers.net/nieuws.dsp) te plaatsen?
Plaatjes kijken
Professioneel Hyves-weigeraar
Microsoft SharePoint oplossingen | www.onlinesamenwerken.nl | Persian Dance Helia
Versta jij het niet?
Misschien dacht die gast dat ze het uit de pics wel begrepen
http://flickr.com/photos/itommy/
-1 Dubbelpost
babelfish.altavista.com
I smell a YodaI love, when appears something new, and today in our hands proved to be the completely new and very recently released processor Intel Cheleron of 2.0GYuz. you you know that it differs from covered itself with the indelible disgrace of low-order processors Cheleron It sochket 478 fact that it is made on the basis of the nucleus/kernel Of nortyushood. Truth our hopes were not realized and it did not obtain additional k3w- memory.As in processors Intel Cheleron of y."GYuz and Intel Cheleron of y.8GYuz , produced on the basis of nucleus/kernel To shillamette, its volume is as before equal to 128 KB and by analogy processor can be attributed to the family Of nortyushood-y28.Processor in Malaysia is assembled, is marked SL'LCH, it operates at a frequency of 400 MHz.That me astonished, so his this supply voltage.It is natural that it was reduced in comparison with the junior fellows, but it proved to be higher than in "valuable" Pentium 4.1.525 v.
There is one additional interesting special feature in this processor.it is let out of 300 mm of silicic plates.What in this of such?Indeed all last processors from Intel are let out on this technology and even it is declared, that gradually all old Rya on the nucleus/kernel Of nortyushood, except Rya y.'A, also will begin to be produced of the plates of larger size/dimension.Entire the fact is that to me, until now, fell not one "old" processor, made in a new way.In the "new" processors are corrected the discovered errors, is carried out even certain redizayn of nucleus/kernel and there is the assumption (not checked/not verified) that they will be better accelerated/dispersed.It is most accurate to distinguish "new" processors of the "old" by the marking:in it number 6 instead of encountered previously number 5 compulsorily must be present.For example, "old" processor Intel Pentium of 4 2.0 GYuz was marked BY SLSHCHYR, and accurately the same "new" will be marked BY SL'GTS. but there is one additional method to distinguish processors, on the arrangement of elements on the reverse side.Compare two processors, to the left "old", and to the right "new":
Noticeable differences, truth?
Main convenience in the fact that it is possible not to examine the polustershuyusya marking, but to at first glance distinguish "new" processor of the "old".
Let us finish the lyric retreat (simply greatly it is desirable to protestirovat' "new" processors Rya) and let us approach checking of processor Intel Cheleron of 2.0GYuz. since it it is let out on the 0.13- micron technology, theoretically it must be accelerated/dispersed rather well, and we are now verified this in practice.This system was assembled for the tests:
Mother.YePoKh Of ep-yagyaa roar.1.0, BIOS from 22.08.02
Memory.512 MBYTES PCH2"00 DDR SDRAM CHL2.SHCH SECH
Video - NVIDIA To geForche of 4 Tiya'00
Khard - IBM DTLA 305020
Processor.Intel Cheleron of 2.0GYuz
Thermo-paste.Kpt-8
Operating system - Shindoshs KHP (detonator 29.42)
Maternal pay easily determined processor and established/installed correct coefficient and stress/voltage.I established/installed memory for the frequency synchronous with the processor, taymingi 2.5-3-3-6, stress/voltage thus far did not increase and for the beginning timidly advanced FSB of 133 MHz.No hitches.system was loaded both at this frequency and on 140 MHz.Here I made a small pause and it conducted several tests, but processor behaved irreproachably.Then (as before without raising stress/voltage!)4 with the dying down of heart it advanced the frequency of 150 MHz and its processor took!There is a gigahertz from air, there is Cheleron of e.0GYuz!
Yes, they infrequently us gladden by such processors.Cheleron of 2.0GYuz repeated the success Of cheleron of e00MYuz and Cheleron of y.0A.it is accelerated/dispersed one and a half times!Unfortunately, all my further attempts to raise frequency to the success did not lead.System started even at the frequency of busbar/tire 166 MHz, but Shindoshs no longer was loaded.It did not help and an increase in the stress/voltage to 1.725 v and I returned to the frequency FSB of 150 MHz.
Time arrived to verify however, that we had first and what they attained by so outstanding a dispersal/acceleration.Tests in Tsuake 3 arenas were conducted during tuning of quality To yuigyu Of tsuality and permission/resolution of y0ya2kh"'8 with the aid of demki FOUR.In eDMark 200YSE was passed the complete cycle of tests with the tuning on silence/supression and in the same permission/resolution of y02yakh"'8. first the processor was checked in the standard regime/conditions:with FSB of 100 MHz and with the memory DDR2'' as most common, then at the frequency of busbar/tire and memory 150 MHz.For the comparison I took only available processor Rya of y.'A to me at this moment and conducted the same tests under the same conditions.
Yes, here situation no longer appears so/such iridescent.It is necessary to send this diagram in AMD, since this is the obvious case, which wonderful illustrates thesis that megahertz.this not most important.Look, what colossal role the volume of k3w- memory plays.Two-gigahertzCheleron in the nominal rating lags behind processors Rya, working at the frequency 1600 MHz.it is less on 400 MHz.It wonderfully drove away and very noticeably (although, of course, not one and a half times) increased its productivity.So it passes Rya y.'A, nevertheless frequency is higher almost two times, but it is worthwhile to place Rya in the same conditions, for the frequency of 150 MHz, as Cheleron it occurs noticeably more weakly, in spite of superiority in the frequency in 600 (!) MHz.
There is nothing surprising in this.Processors Rya on the nucleus/kernel To shillamette partly were so/such nelyubimy, since we could not show decent productivity.Only with the output/yield of the processors Of nortyushood summary effect from an increase two times of the volume of k3w- memory and increase in the clock frequencies yielded positive results.But Intel Cheleron of 2.0GYuz of memory is two times less on the processor than on ignominious Shillamette even by one increase in the frequency much not to attain.It is now understandable, why Intel four times decreased the volume of k3w- memory by Cheleron of 2.0GYuz in comparison with the valuable processors on the nucleus/kernel Of nortyushood.With this excellent razgonyaemost'yu and memory 256 KB it would become is too dangerous, too it would approach its noticeably more dear elder brothers it would prevent sales of the processors Of rya. Therefore if earlier company it held in control the productivity Of cheleron with the aid of the slow busbar/tire 66 MHz, now it found new bridle.k3w- memory.
The sum of our first acquaintance with the processors Intel Cheleron of 2.0GYuz (Nortyushood-y28) is intelligible and obvious.this the first decent processor Of cheleron hearth Sochket 478.If inexpensive, but sufficiently rapid system is necessary to you, then because of the excellent overklokerskomu potential and the relatively low price this there will be outstanding selection.But if productivity is necessary to you, then it is better to look to the side of other processors.
We thank company NTTS electron- service for the given for the testing processor.
Journalism is printing what someone else does not want printed; everything else is public relations.
Of course, it's mineVerwijderd schreef op 27 september 2002 @ 20:00:
Goed idee Rataplan.
Maar vooral ook zo ontzettend LEUK! Van de FP:
Hij verwacht dat het Überholzklotz geen dertig jaar mogelijk, das zal zijn om minuscule in de Menselijke bloedbaan te injecteren, Microchips getroffenes De hersenen samen te laten werken en innerlijke gevoelens sensoren, letterlijk te getroffen anderen Tür deze elektronisch über te sturen delen.
Getroffenes dit idee im het achterhoofd zijn sommige tot voorkort als sciencefiction bestempelde taferelen das ondenkbaar niet meer, aldus Kurzweil.
