kan iemand mij deze route uitleggen...
want Chello kan het niet.
Voor alle duidelijkheid de server staat vlak bij Londen die ik gebruik.
S'avonds een hele hoge ping en verbinding onstabiel.
Als ik tracer gebruik gaat het van A'dam , Londen, New York ???? en weer terug.
Hoe kan dit en waarom niet de kortste route?
hier de tracer......
traceroute to 193.133.240.103 (193.133.240.103), 30 hops max, 40 byte packets
Hop host/router naam host/router IP AutonomousSystem Response tijden
1 V21.ah00rs01.net.upc.nl (212.142.28.225 ) [AS8209 ] 1 ms 1 ms 1 ms
2 Gig6-0.ah00rt03.brain.upc.nl (212.142.28.121 ) [AS8209 ] 0 ms 0 ms 1 ms
3 srp8-0.ah00rt01.brain.upc.nl (212.142.32.49 ) [AS8209 ] 0 ms 0 ms 0 ms
4 srp0-0.am00rt02.brain.upc.nl (212.142.32.2 ) [AS8209 ] 4 ms 4 ms 4 ms
5 srp0-0.am00rt06.brain.upc.nl (212.142.32.44 ) [AS8209 ] 4 ms 4 ms 4 ms
6 nl-ams01a-rd1-pos-3-0.aorta.net (213.46.161.53 ) [AS6830 ] 4 ms 4 ms 4 ms
7 nl-ams02-rd1-10gige-7-0.aorta.net (213.46.161.58 ) [AS6830 ] 4 ms 4 ms 4 ms
8 no-osl-rd-01-pos-0-1-0.chellonetwork.com (213.46.160.150 ) [AS6830 ] 12 ms 12 ms 12 ms
9 uk-lon01a-rd1-pos-1-0.aorta.net.174.46.213.in-addr.arpa (213.46.174.1 ) [AS6830 ] 12 ms 12 ms 12 ms
10 213.46.160.106 (213.46.160.106 ) [AS6830 ] 78 ms 79 ms 78 ms
11 gige3-0.ipcolo1.NewYork1.Level3.net (63.209.170.101 ) [AS3356 ] 79 ms 79 ms 79 ms
12 gigabitethernet2-1.core2.NewYork1.Level3.net (64.159.17.70 ) [AS3356 ] 79 ms 79 ms 79 ms
13 102.ATM2-0.BR3.NYC8.ALTER.NET (209.244.160.162) [AS3356 ] 79 ms 79 ms 79 ms
14 0.so-5-0-0.XL1.NYC8.ALTER.NET (152.63.19.46 ) [AS701 ] 80 ms 80 ms 80 ms
15 0.so-4-0-0.TL1.NYC9.ALTER.NET (152.63.0.173 ) [AS701 ] 86 ms 81 ms 81 ms
16 0.so-7-0-0.IL1.NYC9.ALTER.NET (152.63.9.245 ) [AS701 ] 81 ms 80 ms 80 ms
17 0.so-1-0-0.IR1.NYC12.ALTER.NET (152.63.23.62 ) [AS701 ] 80 ms 81 ms 81 ms
18 so-1-0-0.TR2.LND9.Alter.Net (146.188.15.30 ) [AS702 ] 90 ms 90 ms 90 ms
19 so-6-0-0.XR1.LND9.Alter.Net (146.188.15.42 ) [AS702 ] 90 ms 90 ms 90 ms
20 POS3-0.cr1.lnd10.gbb.uk.uu.net (158.43.150.97 ) [AS1849 ] 90 ms 90 ms 90 ms
21 pos1-2.cr2.lnd4.gbb.uk.uu.net (158.43.254.9 ) [AS1849 ] 91 ms 91 ms 91 ms
22 fe0-1-0.gw6.lnd4.gbb.uk.uu.net (158.43.172.133 ) [AS1849 ] 160 ms 188 ms 207 ms
23 intesyst06-gw.pipex.net (193.133.240.254) [AS1849 ] 96 ms !A * 96 ms !A
DONE
  • Greyfox
  • Laatst online: 22-09 16:22
Greyfox
MSX rulez
Hij neemt een beschikbare route en dat hoeft zeker niet de kortste te zijn.
Veel verkeer gaat via een bepaald knooppunt en dat kan best wat verder weg liggen.
MSX 2 rulez more
  • fetcher
  • Laatst online: 18-09 15:40
De interconnectie (peer) van chello met uunet ligt er uit :)
  • PilatuS
Waarschijnlijk is die route op dat moment toch wel de snelste route
De snelste route hoeft niet altijd de kortste te zijn :)
Greyfox schreef op 27 september 2002 @ 15:02:
Wat verder liggen ok maar New York......
  • fetcher
Gebeurt wel eens vaker hoor, beter dan dat je pakketje NIET aankomt :D
  • PolarBear
PilatuSSS schreef op 27 september 2002 @ 15:04:
En dan heb je een routing systeem als OSPF en dan kan je naar NY worden gestuurd/
