Video in && Out => rondsuizen??
  • WarMaster
WarMaster
Nosce te ipsum
Ik zit hard te denken om een costum box te maken met aan de ene kant scart, en aan de andere kant video in && out, en sound in && out.
Echter, bestaat er een kans op het rondsuizen van beeld of geluid?
Ik geloof trouwens ook dat dit alleen met composiet kan, of toch ook met s-video?
Al die scart-layouts zijn overal anders :(
We live in a primitive time don't we, neither savage nor wise. Half measures are the curse of it; any rational society would either kill me or put me to some use.
  • WarMaster
WarMaster
Nosce te ipsum
Weet in ieder geval iemand of de S-Video naar Composiet ook andersom gebruikt kan worden?
D.w.z dat er weer een S-video signaal uitkomt als je een composiet aanbiedt?
  • DJSmiley
  • Laatst online: 14:05
svideo -> composite kan, en andersom ook prima
http://www.hut.fi/Misc/El...rcuits/svideo2cvideo.html
S-video to composite video adapter
This simple adapter can be used to convert Y/C video (S-video) to a composite video. This adapter is useful in cases where your video output device has only S-video output but your signal source accepts only composite video input. This circuit works with both PAL and NTSC video standards.
Can the circuit used in other way ?
If you try to connect the circuit in opposite way so that you have a composite video signal which yoiu want to feed to S-video input then you might wonder would this circuit work also in that way. The answer is that the circuit sort of work also in this way. If you connect a comoisute video source to a S-video input of your TV using this circuit, you will get a full color picture on your TV screen. The downside of this is that the picture quality will be worse than if you were using the real composite vidoe input of your TV. The reason for this is that after the circuit the color information is still in the brighness signal, you you see some interference on the screen caused by color subcarrier which gets to the screen. This all means that you can use this circuit as last change in situations where you don't have a composite video input. The picture quality is degraded, but propably still usable for some not so demanding applications. A real well working solution would be much more complicated than this circuit.
  • WarMaster
WarMaster
Nosce te ipsum
Ik zat zelf te denken aan een spoeltje van 460pH gezien het feit dat het precies het geinverteerde van een condensator is...
überhaupt geen idee of die dingen bestaan, maar ik zal ffffff kieken in de conrad gids :)
  • WarMaster
WarMaster
Nosce te ipsum
Hmmmm ik zie wel dat er veel signaalverlies/storing optreed bij het omzetten naar composiet... Das klote, want ik dacht niet dat Scart tegelijkertijd composiet in en uit toelaat.... of wel?
