Officiele patch voor GP3 is er eindelijk :o)
  • LoneRanger
http://www.alphaf1.com/gp3/
voor diegene[n] die liggen/lagen te slapen :)
Wat die patch allemaal precies doet kun je daar ook lezen [teveel om op te noemen nml]
De patch is 5mb.
Only fools are enslaved by time and space.
  • D.R.
D.R.
XBox Live Tag: CrazyCavia
Dan copy & pasten we toch..
Gameplay Enhancements
* Improved Advanced Controls interface.
* Added support for controller fire buttons 1 to 16.
* Added support for up to 6 axes per controller.
* Menus can be controlled with the accelerator, brake, and steering when in "Control driven calibration" mode.
* Implemented an option to reverse the direction of force-feedback where the steering was pulling left on some older wheels.
* Implemented a new control device named "Pit signal device" in the advanced control menu. This allows the fire buttons on controllers to be used to activate or cancel the pit signal (instead of the RETURN key).
* The grip and bumpiness corrected on grass alongside kerbs.
* The grass is modelled correctly for bumps and grip within the pitlane.
* Greatly improved wet weather tyre changing AI and precipitation modelling.
* Graphics calibration system prediction accuracy improved.
* Black flags removed from the outside of overrun kerbs.
* Wing repair time affects pit-stop time.
* Cars more sensitive to fence collision damage.
Fixes to
* Link Mismatch problems when 2 players are linked and there is a tumbling, breaking up car, and the two machines have different views of the action.
* Cars stopping every lap after 3rd pit-stop if 3 pit-stops are attempted.
* Improve issues with chicane barriers at Monaco.
* Grid order problem when saving on exit after qualifying session.
* Car getting stuck while queuing for the pit after a collision.
* Data logging occasionally fails to fetch the lap just completed, after driving into the pits.
* Changing help options during a hot lap could sometimes affect the replay.
* Last gear change LED stays lit until it is okay to change down.
* A loaded game-save (saved near start of wet race) causing the AI cars to pit after a lap or two to change tyres.
* On loading a game before ever going in the 3D then the track would not change its wetness/dryness for the rest of the session, even if the rain changed.
Graphic Improvements
* Support for 3Dfx Voodoo2 cards improved.
* Attached camera view car polygon layering improvements.
* Anti-alias levels corrected on Direct3D fences when camera is zoomed.
* Graphically improved pitlane/ sliproad join problems.
Flickr | Groningen Eelde Aviation Society | Flightdiary
thx:)
