[WINXP]Probleem drivers van NIC
Heb net een 3com905c-tx-m in me PCI sloten gestopt,
Windows XP vindt hem netjes zelf alleen zegt dan na het installeren van de drivers
"There was a problem installing this hardware
Ethernet controller
The data is invalid"
dus ik denk dat ligt aan de drivers in winXP, dus ik download de drivers van de 3com pagina, krijg ik hetzelfde gezever.
Iemand een idee waar 't aan kan liggen?
al gevonden in de search, sorry. :X
  • Sjah
  • Laatst online: 21-09 22:06
ander pci-slot. zijn je pci-sloten overgeklokt?
Nee, maar de oplossing las in het verandere van wat registry_data
"Have had same problem with SCSI card. Folow instructions below. Works a treat.!!
This error appears to be due to a protection problem in the Windows registry and can occur with a variety of drivers (sound cards and SCSI drivers have been reported). To fix this problem, go to Start, Run... and type "regedit" without the quotes to run the Registry Editor. Navigate to
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\ENUM\PCI
and you will see a number of keys of the form "VEN_xxxx", where xxxx are strings like "1102&DEV_0004&SUBSYS_00011103&REV_04". Under each of these folders will be another folder with a long numerical name. Open each folder and look for the "DeviceDesc" which matches the hardware you are trying to install. Right Click on the "VEN_xxxx" for that device and select 'Permissions' and then tick "Allow" for "Full Control". Close Regedit and then continue with the installation of your device."
Heel vaag dus
