[Q3] GLW_StartOpenGL() - could not load OpenGL subsystem *
  • 266 views sinds 30-01-2008
  • iFluX
  • Laatst online: 14-07-2024
iFluX
.....Pokes Your Eye.....
hiya
ben Quake3 net aan het installen en krijg ik een foutmelding waar ik geen hol mee kan :D |:(
dit zegt ie :Q3 1.11 win-x86 Nov 24 1999
----- FS_Startup -----
Current search path:
C:\Program Files\Quake III Arena\baseq3\pak0.pk3 (3539 files)
C:\Program Files\Quake III Arena/baseq3
execing default.cfg
execing q3config.cfg
couldn't exec autoexec.cfg
...detecting CPU, found x86 (P5/Pentium2, MMX)
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
Joystick is not active.
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
--- Common Initialization Complete ---
Winsock Initialized
Opening IP socket: localhost:27960
Hostname: o3g1z9.arnhem.chello.nl
IP: 62.195.61.12
Working directory: C:\Program Files\Quake III Arena
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\SYSTEM\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 16
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 16, 16, 0 )
...23 PFDs found
...GLW_ChoosePFD failed
...23 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...calling CDS: ok
...23 PFDs found
...23 PFDs found
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
iemand die mij een beetje kan helpen? :'(
draai quake op een : P2 266 mhz matrox MGA-G100 AGP
greets cyc
  • McFlipp
  • Laatst online: 22-04-2023
McFlipp
24...
Bekend probleem, zie oa dit topic.
En voor GL-setup check hier.
Mijn Airliners.net foto's
A bird in the hand is worth two in the bush - Aesop
  • DroogKloot
DroogKloot
depenisvanjezus
Uhm, d'r staat een dikke P4 in je sig... waarom zoul je Q3 uberhaupt op die brakke 266 willen spelen?
En je hebt GLSetup nodig, *erg* bekend probleem dit. :)
Ehm.... www.google.com en http://gathering.tweakers.net/forum/find + http://arethusa.tweakers.net/~acm/omega/omega en een duidelijke topictitel zou ook wel kunnen.
grrrr..... ik ben zoals altijd weer te laat :P
• titel kan veel beter
Van: Quake 3
Naar: [Q3] GLW_StartOpenGL() - could not load OpenGL subsystem *
• zoekvraag.
• Onnodige replies verwijderd.
