Samba trouble (Debian Sid)
  • riotrick
  • Laatst online: 04-07 15:29
Ik heb zojuist m'n debian bakje geupgrade van Sarge naar Sid en nu werkt samba niet meer. Ik draaide versie 2.2.5 nu is die geupgrade naar 2.99+3.0cvs20020906.
M'n config is niet veranderd. Volgens testparm is die ook ok.
In de netwerkomgeving op win9x clients zie ik de bak wel staan, maar als ik er op klik krijg ik:
Geen toegang tot \\schaap
Dit apparaat bestaat niet op het netwerk.
Hieronder mijn config:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
[global]
    smb passwd file = /etc/samba/smbpasswd
    wins server = server03.edg
    printing = lpr
    dns proxy = no
    encrypt passwords = yes
    socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
    printcap name = /etc/printcap
    max log size = 0
    hosts allow = 127.0.0.1 10.0.0.
    preferred master = no
    password server = server03.edg
    security = server
    server string = Debian GNU/Linux Sid
    workgroup = EDG
    local master = no
    log file = /var/log/samba/%m.log
    netbios name = schaap
    load printers = yes
    os level = 1
[homes]
    writable = yes
    valid users = %S
    browseable = no
    comment = Home Directory
    create mode = 0664
    directory mode = 0775
[filesystem]
    path = /
    writable = yes
    valid users = @root
    comment = Root filesystem
    create mode = 0664
[www]
    comment = Lokale webserver
    path = /var/www
    valid users = @root
    writable = yes
    create mode = 0664
  • riotrick
Ik zie net in de logs van de puter die verbinding probeert te maken het volgende:
[2002/09/20 11:40:13, 0] lib/fault.c:fault_report(36)
[2002/09/20 11:40:13, 0] lib/fault.c:fault_report(37)
  INTERNAL ERROR: Signal 11 in pid 1083 (2.999+3.0cvs20020906-1 for Debian)
  Please read the file BUGS.txt in the distribution
[2002/09/20 11:40:13, 0] lib/fault.c:fault_report(39)
[2002/09/20 11:40:13, 0] lib/util.c:smb_panic(1151)
  PANIC: internal error
[2002/09/20 11:40:17, 0] lib/fault.c:fault_report(36)
[2002/09/20 11:40:17, 0] lib/fault.c:fault_report(37)
  INTERNAL ERROR: Signal 11 in pid 1084 (2.999+3.0cvs20020906-1 for Debian)
[2002/09/20 11:40:17, 0] lib/fault.c:fault_report(39)
[2002/09/20 11:40:17, 0] lib/util.c:smb_panic(1151)
[2002/09/20 11:41:44, 0] lib/fault.c:fault_report(36)
[2002/09/20 11:41:44, 0] lib/fault.c:fault_report(37)
  INTERNAL ERROR: Signal 11 in pid 1088 (2.999+3.0cvs20020906-1 for Debian)
[2002/09/20 11:41:44, 0] lib/fault.c:fault_report(39)
[2002/09/20 11:41:44, 0] lib/util.c:smb_panic(1151)
Lijkt dus een bugje in samba zelf. Maar goed ik heb voorlopig samba maar weer even gedowngrade naar de versie uit Debian testing (2.2.3nogwat). Deze versie doet het wel prima.
