Pc crashes sometimes, can't find the cause
My problem is this:
Sometimes when I use or install an application and reboot my system my screen stays black and my system-speaker starts bleeping, and just doesn’t load anything.
It doesn’t do a memory test or loads the bios. The system just halts immediately. To stop the bleeping you can do just one thing and that’s pulling out the power plug, which after 10 minutes can be put back and then everything works like normal. This also always occurs while playing C&C: RED ALERT, RED ALERT 2, or TIBERIAN SUN. These games can be played for about 10 minutes, and then the picture freezes and the last 3 seconds of sound are constantly repeated. To stop this I have to reboot my system, which then shows the previously described problem. The weird thing is that this problem doesn’t occur on all locations I put my system. If I put it in my Bedroom, the problem doesn’t occur. My system configuration is:
- AMD Athlon1200 MHz processor
- MSI K7T Turbo mainboard
- VIA KT133A mainboard chipset
- Nvidia GEFORCE 2 MX 3D Accelerator (agp)
- Creative SoundBlaster Live! 1024 (pci)
- 128 MB RAM (just replaced by my local dealer)
- 40 GB Hard-Drive (ide)
- Logitech Pilot mouse+ (ps/2)
- Standard keyboard (Azona win 98) (ps/2)
- AOpen DVD-drive (ide)
- LG CED-8080B CD-Writer (ide)
- Intel V92 HAM Data Voice Fax Modem (pci)
- Realtek RTL8139 Family Fast Ethernet NIC (pci)
- Epson color 680 printer (usb)
- Logitech Wingman Formula Force GP Steering Wheel (usb)
- Mustek 1200 CU Plus Scanner (usb)
- Pinnacle PCTV TV Viewing card (pci)
- Windows XP Professional (the problem occurs with win 98, Win ME and Win XP)
If have updated all my drivers so that can’t be the problem, my local dealer can’t find the problem because it doesn’t occurs at their workshop. I have formatted my entire hard-drive about 3 times now. The peripheral-equipment doesn’t seem to be the problem because the problem also occurs if I don’t connect any of it.
  • Wekkel
  • Laatst online: 15-10 22:32
Wekkel
De downloadkoning
Nice post, but Dutch is preferred around here.
  • Vorkie
In which PCIslot is your Live! in? second of third? Use the newest drivers of the live! and install the via 4-1 Drivers, you can find it at www.viaarena.com
Your pinnacle PCTV Tv could be the problem too
Maar je kan nederlands, dus ik raad je ook aan te kijken of je pc stabiel is met zo min mogelijk erin, en kijk eens in de search
  • Sherlock
  • Laatst online: 16:02
Sherlock
No Shit
Misschien een voedingsprobleem? Omdat het op verschillende plaatsen wel of niet voorkomt.
Kan je de spanning eens doormeten waar het wel en niet gebeurt?
And if you don't expect too much from me, you might not be let down. Gin Blossoms - Hey Jealousy
  • Rhino
  • Laatst online: 20-08 13:03
Rhino
Dat ben ik
Eerst maar eens kijken wat voor bliepjes het zijn, het patroontje opzoeken in je mobo handleiding.
't zou een te hete proc kunnen zijn?
Wortelkanaal behandelingen zijn volgens mij niet zo prettig
  • GekkeR
  • Laatst online: 19-10 23:38
GekkeR
key = key
It looks to me that it's either the power supply , the graphics card or the soundblaster.
Try repositioning the soundblaster in different slots , try a different graphics card (if that's possible).
You can also try to see if you can alter some AGP options in the bios (as wel as some AGP voltage settings).
You should also enter the bios and look for various voltage options and statistics. If it shows that the 3.3 , 5.0 and 12v lines are underpowered , change your power supply.
Good luck , and let us know what it was :)
[ pctje te zien hier ] - Miauw
  • KillerAce_NL
KillerAce_NL
If it ain't broke...
Is it the KT133a bug with SB live! Soundcards ?
Try to flash a new bios for your Mainboard.
  • Vincent17
  • Laatst online: 17-10 17:52
Waarom antwoord iedereen in het Engels. Als je in z'n profiel kijkt heeft ie Nederlands ingevult
One thing, i have allways learn to never put thing like Soundcards or Network card under
Video cards....
  • KillerAce_NL
KillerAce_NL
TheJackal schreef op 19 september 2002 @ 11:59:
Hmm ben je een keer vriendelijk, is het nog niet goed :?
A friend had the same problem with the same MB.....
Problem was the Creatvie soundblaster....
Even when the onboard sound was disabled, it's doing some nasty things....
when he removed the soundblaster card, the problem was solved!
  • nexhil
  • Laatst online: 15:07
nexhil
BAM!
vague shit hoor
  • Vorlon
  • Registratie: Augustus 1999
  • Laatst online: 10-10 09:23
Klinkt als Soundblaster Live <-> Via 686b (kt133a) southbridge datacorruptie bug. Als je nou de live eruithaalt zou het probleem weg moeten zijn.
Ohja, heb je je systeem aan een stopkontakt met randaarde aangesloten? (vooral omdat je wel aard via de CAI aansluiting (via pctv))
[off-topic]
We spreken hier Nederlands, kleine moeite om je vraag dan ook daarin te stellen. Ik neem tenminste aan dat je dit ook op een aantal buitenlandse fora gepost hebt..
[/off-topic]
"You are not ready for immortality yet" - Kosh Nararek
Hey Flubbie het is een Nederlandstalig forum hoor! Mijn volgende topic wordt ook in het Spaans geopend.
  • Wekkel
Wekkel
De downloadkoning
quanta costa?
€5500
No me gusta
