Probleem met OpenSSL upgrade
  • RvdH
  • Laatst online: 28-07 15:42
RvdH
Uitvinder van RickRAID
Euhm, help!
Probeer net OpenSSL te updaten ivm de recentste worm/exploit.
Nu wilt mijn Apache geen SSL connecties meer accepteren:
[17/Sep/2002 12:20:26 28128] [info] Server: Apache/1.3.26, Interface: mod_ssl/2.8.10, Library: OpenSSL/0.9.6g
[17/Sep/2002 12:20:26 28128] [info] Init: 1st startup round (still not detached)
[17/Sep/2002 12:20:26 28128] [info] Init: Initializing OpenSSL library
[17/Sep/2002 12:20:26 28128] [info] Init: Loading certificate & private key of SSL-aware server www.geheim-want-ongepatcht.nl:443
[17/Sep/2002 12:20:27 28128] [info] Init: Seeding PRNG with 136 bytes of entropy
[17/Sep/2002 12:20:27 28128] [info] Init: Generating temporary RSA private keys (512/1024 bits)
[17/Sep/2002 12:20:28 28128] [info] Init: Configuring temporary DH parameters (512/1024 bits)
[17/Sep/2002 12:20:29 28129] [info] Init: 2nd startup round (already detached)
[17/Sep/2002 12:20:29 28129] [info] Init: Reinitializing OpenSSL library
[17/Sep/2002 12:20:29 28129] [info] Init: Seeding PRNG with 136 bytes of entropy
[17/Sep/2002 12:20:29 28129] [info] Init: Configuring temporary RSA private keys (512/1024 bits)
[17/Sep/2002 12:20:29 28129] [info] Init: Configuring temporary DH parameters (512/1024 bits)
[17/Sep/2002 12:20:29 28129] [info] Init: Initializing (virtual) servers for SSL
[17/Sep/2002 12:20:29 28129] [info] Init: Configuring server www.geheim-want-ongepatcht.nl:443 for SSL protocol
[17/Sep/2002 12:20:42 28134] [info] Connection to child 4 established (server www.geheim-want-ongepatcht.nl:443, client 212.187.x.x)
[17/Sep/2002 12:20:42 28134] [info] Seeding PRNG with 1160 bytes of entropy
[17/Sep/2002 12:20:42 28134] [error] SSL handshake failed (server www.geheim-want-ongepatcht.nl:443, client 212.187.x.x) (OpenSSL library error follows)
[17/Sep/2002 12:20:42 28134] [error] OpenSSL: error:1409D08A:lib(20):func(157):reason(138)
[17/Sep/2002 12:27:26 31718] [info] Connection to child 16 established (server www.geheim-want-ongepatcht.nl:443, client 193.120.x.x)
[17/Sep/2002 12:27:26 31718] [info] Seeding PRNG with 1160 bytes of entropy
[17/Sep/2002 12:27:26 31718] [error] SSL handshake failed (server www.geheim-want-ongepatcht.nl:443, client 193.120.x.x) (OpenSSL library error follows)
[17/Sep/2002 12:27:26 31718] [error] OpenSSL: error:1409D08A:lib(20):func(157):reason(138)
Komt deze foutmelding jullie bekend voor, en hoe is het op te lossen? Wil die server zo snel mogelijk patchen natuurlijk..
Google levert gewoon geen enkele resultaten! :/
  • Skinkie
  • Laatst online: 09-06-2020
Skinkie
Op naar de 500
modssl ff recompilen?
Steun Elkaar, Kopieer Nederlands Waar!
  • RvdH
RvdH
Dat heb ik al 20 keer gedaan.
Net als ldconfig runnen, alles wat te maken heeft met ssl / php / apache recompilen..
  • Skinkie
Skinkie
Op naar de 500
strlen schreef op 17 september 2002 @ 16:02:
op zo'n moment vraag ik me altijd af of je compiler make opties hebt meegeven bij het installeren van openssl en modssl :)
  • RvdH
RvdH
Als gcc opties zou missen zou het zeer waarschijnlijk niet eens compileren.
hmz, volgens google heeft het te maken met verschillende versies headerfiles. Probeer anders eens _alles_ wat apache nodig heeft te compilen met als prefix /test oid, en vervolgens alle --with-... statements voor configure te laten wijzen naar software geinstalled in /test
