De GoT afkortingenlijst
  • 287 views sinds 30-01-2008
  • Steve
  • Laatst online: 06-10 22:56
Steve
Krokodil \o/
Hierbij de lijst, aanvullingen/aanpassingen enz graag hieronder vermelden.
Mod: kan hij misschien sticky ?
AAF = Advanced Authoring Format
ABR = Available Bit Rate
ACD = Automatic Call Distribution
ACPI = Advanced Configuration and Power Interface
ADC = Analog to Digital Converter
ADPCM = Adaptive Delta Pulse Code Modulation
ADSL = Asymmetric Digital Subscriber Line
AES = Audio Engineering Society
AGP Accelerated Graphics Port
AI= Artificial Intelligence
AMD = Advanced Micro Devices
API = Application Programming Interface
ARP = Address Resolution Protocol
ARPA = Advanced Research Projects Agency
ASCII = American Standard Code for Information Interchange
ASF = Advanced Streaming Format
ASPI = Advanced SCSI Programmable Interface
AT&T = American Telephone and Telegraph Company
ATA = Advanced Technology Attachment
ATM = Asynchronous Transfer Mode
ATRAC = Adaptive Transform Acoustic Coding
AVI = Audio Video Interleaved
b = bit
B = byte
BASIC = Beginner's All Purpose Symbolic Instruction Code
BBS = Bulletin Board System/Services
BiMOS Bipolar Metal Oxide Semiconductor
BIOS = Basic Input/Output System
BISDN = Broadband ISDN
BIT = Binary Digit
BMP = bitmap
BPR = Business Process Re=engineering
BRI = Basic Rate Interface
BUS= Broadcast and Unknown Server
CA = Certificerende Autoriteit
CA = Computer Associates
CAD = Computer Aided Design
CAM = Computer Aided Manufacturing
CAS = Clustering Avalability Software
CATV = Cable Television
CBR = Continuous Bit Rate
CCITT = Consultative Committee for International Telegraph and Telephony
CD = Compact Disc
CD=DA = Compact Disk Digital Audio (ook: Audio CD)
CD=I = Compact Disc Interactive
CD=ROM = Compact Disc Read Only Memory
CDF = Channel Definition Format
CDRW = Compact Disk Rewritable
CDTV = Compact Disk Television
CELP = Code Excited Linear Prediction
CFML = Cold Fusion Markup Language
CISC = Complex Instruction Set Computer
CM = Continuous Media
CMOS Complementary Metal Oxide Semiconductor
COBOL = Common Business Oriented Programming Language
COM Component Object Model
CORBA = Common Object Request Broker Architecture
CPU = Central Proccessing UnitCPU Central Processing Unit
CRT = Cathode Ray Tube
CSCL = Computer Supported Cooperative Learning
CSCW = Computer Supported Cooperative Working
CSS = Cascading Style Sheet
CSTA = Computer Supportede Telephony Applications
CT = Computer Tomography
CTCI Computer To Computer Interface
CTI = Computer Telephone Integration
CVE = Centrale Verwerkingseenheid
DAC = Digital to Analog Converter
DARPA = Defense Advanced Research Projects Agency
DASD Direct Access Storage Devices
DAT = Digital AudioTape
dB = Decibel
DBS = Direct Broadcast Satellite
DCC = Digital Compact Cassete
DCOM = Distributed Component Object Model
DCS Decision Support Systems
DDR = Double Data Rate
DDS = Direct Digital Synthesis
DEC Digital Equipment Corporation
DHTML = Dynamic Hypertext Markup Language
DIMM = Dual in line Memory Module
DIN = ?
DIP = Document Image Processing
DLT Digital Linear Tape
DMA = Direct Memory Access
DMI = Desktop Management Interface
DOS = Disk Operating System
DOS Disk Operating System
DPRL = Digital Property Rights Language
DRAM Dynamic Random Access Memory
DSDM = Dynamic Systems Development Method
DSLAM = Digital Subscriber Line Access Multiplexer
DSP = Digital Signal Processing
DSSSL = Document Style Semantics and Specification Language
DSTN = Dual Scan Twistle Nematic
DTD = Document Type Definition
DTP = Desktop Publishing
DVD = Digital Versatile Disk
DVI = Digital Video Interactive
EBU = European Broadcast Union
ECL = Emitter Coupled Logic
ECP = Extended Capability Port
EDI = Electronic Data Interchange
EDIFACT = Electronic Data Interchange For Administration Commerce and Transport
EDM = Electronic Document Management
EDMS = Electronic Document Management System
EDORAM = Extended Data Out Random Access Memory
EIS = Executive Information System
EPP = Enhanced Parallel Port
ESPS = Entropic Signal Processing System
ETD = European Telework Development
FAQ = Frequent Asked Questions
FAT = File Allocation Table
FCC = Federal Communications Commission
FDD = FloppyDisk Drive
FDDI = Fiber Distributed Data Interface
FFT = Fast Fourier Transform
FIFO = First In First Out
FIFO = Firts In Firts Out
FM = Frequency Modulation
FMV = Full Motion Video
FORTRAN = formula translation
FTP = File Transfer Protocol
FTP = Foiled Twisted pair
GIF = Graphics Interchange Format
GIS = Geographic Information Systems
GNOC = Global Network Operations Center
GPS = Global Positioning System
GSM = Global System for Mobile communication
GUI = Graphical User Interface
HDD = HardDisk Drive
HDTV = High Definition Television
HF = High Frequency
HHM = Hidden Markov Models
HP = Hewlett Packard
HTML = Hyper Text Markup Language
HTPP = Hypertext Printing Protocol
Hz = Hertz (kHz: kilo Hertz)
I/O = channel = Input/Output channal
IAHC International Ad Hoc Committee
IBM = International Business Machines
IC = Integrated Circuit
ICT = Informatie= en Communicatietechnologie
IDC = International Data Corporation
IDE = Integrated Drive Electronics
IEC = International Electro=Technical Commission
IEEE = Institute of Electrical and Electronics Engineers
IETF = Internet Engineering TaskForce
IETF = Internet Engineering Task Force
IIOP = Internet Inter=ORB Protocol
IKP = Internet Keyed Payment
IMA = International MIDI Association
IMAP = Internet Message Access Protocol
INTEL = Integrated Electronics
IP = Internet Protocol (zie ook TCP)
IPP = Internet Printing Protocol
IRQ = Interupt ReQuest
ISDN = Integrated Services Digital Netwerk
ISO = International Organization for Standarization
ISP = Internet Service Provider
IT = Information Technology
ITU = International Telecommunications Union
IVR = Interacyive Voice Response
JDBC = Java Database Connectivity
JPEG = Joint Photographic Experts Group
JPG = JPEG = Joint Photographic Experts Group
LAN = Local Area Network
LCD = Liquid Crystal Display
LEC = Lan Emulation Client
LECS = Lan Emulation Configuration Server
LED = Light Emitting Diode
LES = Lan Emulation Server
LIFO = Last In First Out
LIMDOW = Light Intensive Modulation Direct Over Write
LISP = LISt Processing
LP = Long Player
LPC = Linear Predictive Coding
LWDPA = Lightweight Document Printing Application
M$ = Microsoft
MAC = Media Access Control
MAN = Metropolitan Area Network
MASM = Macro Assembler
MBS = Media Broadband Services
MCA = Micro Channel Architecture
MDI = Multiple Document Interface
MFM = Modified Frequency Modulation (idem dito als RLL).
MFTP Multicast File Transfer Protocol
MHEG = MultiMedia Hypermedia Expert Group
MIDI = Musical Instrument Digital Interface
MIME = Multipurpose Internet Mail Extensions
MIPS = Million Instructions Per Second
MIS = Management Information System
MIT = Massachusetts Institute of Technology
MIT = Media Lab = Massachusetts Institute of Technology Media Lab
MMA = MIDI Manufacturer's Association
MNR = Mask to Noise Ration
MOSFET = Metal Oxide Semiconductor Field Effect Transistor
MP3 = MPEG 1 Layer 3 Audio
MPEG = Moving Picture Experts Group
MPIE = Multi Purpose Internet Extensions
MPOA = Multi=Protocol Over ATM
MPP = Massive Parallel Processing
MRI = Magnetic Resonance Imaging
MRX = Magneto resistive extended
MTBF = Mean Time Between Failures
MUDs = Multi User Dungeons
MVIP = Multi=Vendor Integration Protocol
NASA = National Aeronautics and Space Administration
NC = Network Computer
NCPC = National Capital Planning Commission
NDS = Novell Directory Services
NetPC = Network Personal Computer
NGI = Nederlands Genootschap voor Informatica
NLM = Network Loadable Module
NMOS = Metal Oxide Semiconductor
NSI = Network Solutions Incorporated
NTSC = National Television Systems Committee
ODBC = Open Database Connectivity
OFE = Open Financial Exchange
OLAP = Online Analytical Processing
OLE = Object Linked Embedding
OMG = Object Management Group
OpAmp = Operational Amplifier
OPS = Open Profiling Standard
OS = Operating System
OSD = Open Software Description
OSR2 = OEM Service Release 2
PABX = Private Automatic Branche eXchange
PABX = Public Automatic Branch Exchange
PAL = Phase Alternating Line
PAMR = Private Access Mobile Radio
PBX = Private Branche eXchange
PC = Personal Computer
PCI = Peripheral Component Interconnect Local Bus
PCMCIA = Personal Computer Memory Card International Association
PDF = Portable Document Format
PERL = Practical Extraction and Report Language
PhotoCD = Photo Compact Disk
PHP = Hypertext PreProcessor
PIO = Programable I/O
PMOS =Metal Oxide Semiconductor
PMR = Professional Mobile Radio
PNG = Portable Network Graphics
POP = Post Office Protocol
PPTP = Point=to=Point Tunneling Protocol
PRI = Primary Rate Interface
PRIM = Photorefractive Information Materials
PSTN = public switched telephone network
PTT = Post Telegraaf Telefoon
RAD = Rapid Application Development
RAM = Random Access Memory
RBOCs = Regional Bell Operating Companies
RDBMS = Relationele Database Management Systeem
RDF = Resource Description Framework
RF = Radio Frequency
RGB = Red, Green, Blue
RIMM = Rambus In line Memory Module
RISC processor = Reduced Instruction Set Computer processor
RLE = Run Length Encoding
RLL = Run Length Limited, een heel oude harddisk=interface (XT/286=tijd, nog voor IDE)
RMI = Remote Method Invocation
ROM = Read Only Memory
RSI = Repetitive Strain Injury
RSS = Roland Sound Space
RTF = Rich Text Format
RTSP = Real Time Streaming Protocol
SARC = Symantec Antivirus Research Centre
SCA = Single Connector Attachment
SCART = Syndicat des Constructeurs d'Appareils Radiorécepteurs et Téléviseurs
SCSI = Small Computer Systems Interface
SDH = Synchronous Digital Hierarchy
SDMS = Spatial Data Management System
SDR = Single Data Rate
SDRAM = Synchronous Dynamic Random Access Memory
SDSL = Symmetric Digital Subscriber Line
SECAM = Sequential Color And Memory (Sequential Couleur Avec Memoire)
SET = Secure Electronic Transaction
SGRAM = Synchronous Graphics RAM
SIAN = Stichting Informatiearchitectuur Nederland
SIMM = Single in line Memory Module
SIPP = Single Inline Pinleaded Package
SLA = Service Level Agreements
SLI = Scan Line Interleave
SMART = Self Monitoring, Analysis and Monitoring Technology
SMDS = Switched Multimegabit Data Service
SMP = Symmetric Multi Processing
SMPTE = Society of Motion Pictures & Television Engineers
SMS = Systems Management Server
SMTP = Simple Mail Transfer Protocol
SNOBOL = String=Oriented Symbolic Language
SOAP = Simple Object Access Protocol
SOM = System Object Model
SONET = Synchronous Opical Network
SPDIF = Sony Philips Digital Interface Format
SPL = Sound Pressure Level
SRAM = Static Random Access Memory
SSL = Secure Sockets Layer
STP = Shielded Twisted Pair
TCP = Transmission Control Protocol (zie ook IP)
TCP = Transport Control Protocol
TDM = Time Division Multiplexing
TDS = Tabular Data Stream
TFT = Thin Film Transistor
TIFF = Tagged Image File Format
TOS = Tape Operating System
TPM = Third Party Maintenance
TSAPI = Telephony Services Application Programming Interface
TTETRA = Trans European Trunked Radio
TTML = Tagged Text Markup Language
TTP = Trusted Third Party
TTS = Text to Speech
TV = Television
TXT = Ascii Text
UBR = Unspecified Bit Rate
UDP = User Datagram Protocol
UHF = Ultra High Frequency
UPS = Uninterruptible Power Supply
URL = Universal Resource Locator
USB = Universal Serial Bus
UTP = Unshielded Twisted Pair
VB = Visual Basic
VBA = Visual Basic for Applications
VBR = Variable Bit Rate
VCR = Video Cassette/Control Recorder
VGA = Video Graphics Array
VHS = Video Home System
VLAN = Virtual Local Area Network
VLB = Vesa Local Bus
VOD = Video On Demand
VR = Virtual Reality
VRAM = Video Random Access Memory
VTOA = Voice and Telephony over ATM
W3C = The World Wide Web Consortium
W3C World Wide Web Consortium
WAN = Wide Area Network
WFM Workflow Management
WINE = Wine Is No Emulator
WWW = World Wide Web
WYSIWYG = What you see is what you get
Xerox PARC = Xerox Palo Alto Research Center
XGA = Extended Graphics Array
XLL = XML Linking Language
XML = Extensible Markup Language
XSL = Extensible Stylesheet Language
  • LopeZ
  • Laatst online: 22:40
LopeZ
Too much is never enough
Euh ik geloof niet dat dit hier hoort :?
Ik snap ook niet helemaal wat dit voor zin heeft...
