asp connection
  • 42 views sinds 30-01-2008
Ik heb de volgende pagina's opgezet in asp:
\connection\verbindingmedic.asp
Set Conn = Server.CreateObject("ADODB.Connection")
sConnection = "Provider=Microsoft.Jet.OLEDB.4.0;" & _
"Data Source=" & Server.MapPath("\mccane\db\HPmedics.mdb") & ";" & _
"Persist Security Info=False"
Conn.Open(sConnection)
in \db directory staat de database HPmedics.mdb
Vervolgens deze gemaakt en deze staat gewoon in default directory
<%@LANGUAGE="VBSCRIPT" CODEPAGE="1252"%>
<!--#include file="Connections/verbindingMedic.asp" -->
Dim rsMedic
Dim rsMedic_numRows
Set rsMedic = Server.CreateObject("ADODB.Recordset")
rsMedic.ActiveConnection = MM_verbindingMedic_STRING
rsMedic.Source = "SELECT * FROM Members"
rsMedic.CursorType = 0
rsMedic.CursorLocation = 2
rsMedic.LockType = 1
rsMedic.Open()
rsMedic_numRows = 0
Dim MM_paramName
' *** Go To Record and Move To Record: create strings for maintaining URL and Form parameters
Dim MM_keepNone
Dim MM_keepURL
Dim MM_keepForm
Dim MM_keepBoth
Dim MM_removeList
Dim MM_item
Dim MM_nextItem
' create the list of parameters which should not be maintained
MM_removeList = "&index="
If (MM_paramName <> "") Then
MM_removeList = MM_removeList & "&" & MM_paramName & "="
End If
MM_keepURL=""
MM_keepForm=""
MM_keepBoth=""
MM_keepNone=""
' add the URL parameters to the MM_keepURL string
For Each MM_item In Request.QueryString
MM_nextItem = "&" & MM_item & "="
If (InStr(1,MM_removeList,MM_nextItem,1) = 0) Then
MM_keepURL = MM_keepURL & MM_nextItem & Server.URLencode(Request.QueryString(MM_item))
End If
Next
' add the Form variables to the MM_keepForm string
For Each MM_item In Request.Form
MM_keepForm = MM_keepForm & MM_nextItem & Server.URLencode(Request.Form(MM_item))
End If
Next
' create the Form + URL string and remove the intial '&' from each of the strings
MM_keepBoth = MM_keepURL & MM_keepForm
If (MM_keepBoth <> "") Then
MM_keepBoth = Right(MM_keepBoth, Len(MM_keepBoth) - 1)
End If
If (MM_keepURL <> "") Then
MM_keepURL = Right(MM_keepURL, Len(MM_keepURL) - 1)
End If
If (MM_keepForm <> "") Then
MM_keepForm = Right(MM_keepForm, Len(MM_keepForm) - 1)
End If
' a utility function used for adding additional parameters to these strings
Function MM_joinChar(firstItem)
If (firstItem <> "") Then
MM_joinChar = "&"
Else
MM_joinChar = ""
End If
End Function
<html>
<head>
<title>Members</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
</head>
<body background="AchtegrondHPM.gif" text="#FFFF00">
<p><strong><font color="#FFFF00" size="5">Hollow Point NL Medics Members</font></strong></p>
<table width="75%" border="1" cellspacing="0" cellpadding="0">
<tr>
<td><A HREF="Detailpagina.asp?<%= MM_keepNone & MM_joinChar(MM_keepNone) & "id=" & rsMedic.Fields.Item("Members").Value %>"><%=(rsMedic.Fields.Item("Members").Value)%></A></td>
</tr>
<tr>
<td> </td>
</tr>
</table>
<p> </p>
</body>
</html>
rsMedic.Close()
Set rsMedic = Nothing
Waarom doet i het niet?
adres http://www30.brinkster.com/mccane/memberstwee.asp
  • Altaphista
  • Laatst online: 01-09 09:22
Altaphista
1. check manual, 2. ask
ASP:
Arguments are of the wrong type, are out of acceptable range, or are in conflict with one another.
/mccane/memberstwee.asp, line 8
hoe ziet line 8 eruit?
Je gaat het pas zien als je het doorhebt.
van welke file? Ik heb 2 files voor de connectie van asp met html en die staan beide bovenaan pagina.
  • gorgi_19
  • Laatst online: 18:55
gorgi_19
Kruimeltjes zijn weer op :9
Waarom hij het niet doet?
Regel 8 : rsMedic.ActiveConnection = MM_verbindingMedic_STRING
Dit betekent: Vul de property ActiveConnection van de instance rsMedic met de variabele MM_verbindingMedic_STRING
Dit is een verwijzing naar de variabele MM_verbindingMedic_STRING
Deze variabele MOET een connectionstring bevatten.
Waar wordt deze variabele in jouw code gevuld met een connectionstring?
In je vorige topic stond onder andere in de sluitmessage dat het misschien een idee is om enkele tutorials door te nemen; hier blijf ik bij, want je hebt volgens mij nog een beetje moeite met de basisbegrippen van programmeren in ASP / VBScript, zo niet met programmeren in het algemeen.
Gewoon eenvoudig beginnen met
Response.Write "Hello World"
en
Dim strTekst
strTekst = "Hello World"
Response.Write strTekst
Digitaal onderwijsmateriaal, leermateriaal voor hbo
  • robjanssen
  • Laatst online: 02-08 16:10
robjanssen
Software Developer
Probeer dit eens:
Dim Conn
Dim strSQL
Dim rsMedic
strSQL = "SELECT * " _
            & "FROM Members"
rsMedic.Open strSQL, Conn, 3, 1
  • D2k
  • Laatst online: 31-08 10:19
D2k
zie gorgi_19
begin bij hello world
en niet gelijk met databases
zolang je de basics van een taal niet beheerst zal dit deel ook niet werken
Doet iets met Cloud (MS/IBM)
