[debian] Kde 3 kdenetwork is niet te apt-get-en
  • OMX2000
  • Laatst online: 00:02
OMX2000
By any means necessary...
Ik krijg het niet voorelkaar om apt-get install kdenetwork te doen... Ik heb kde3 kunnen installeren (kdebase etc.), maar kdenetwork lukt gewoon niet. Ik draai nu dus wel kde, maar ik mis nog allerlei applicaties die in kdenetwork zitten. Ik draai debian unstable...
Dit is de melding die ik krijg
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
Sorry, but the following packages have unmet dependencies:
kdenetwork: Depends: kdict (= 4:3.0.3-1) but it is not going to be installed
Depends: kit (= 4:3.0.3-1) but it is not going to be installed
Depends: kmail (= 4:3.0.3-1) but it is not going to be installed
Depends: knewsticker (= 4:3.0.3-1) but it is not going to be installed
Depends: knode (= 4:3.0.3-1) but it is not going to be installed
Depends: korn (= 4:3.0.3-1) but it is not going to be installed
Depends: kppp (= 4:3.0.3-1) but it is not going to be installed
Depends: ksirc (= 4:3.0.3-1) but it is not going to be installed
Depends: libmimelib1 (= 4:3.0.3-1) but 4:2.2.2-14.1 is to be installed
  • active2
  • Laatst online: 17-07 21:56
active2
Google is your friend
Dan doe je die pakketjes er ook in! Dan kun je zien welke packages conflicten geven!
Google, Het mirakel van de 21e eeuw!!!!
  • OMX2000
OMX2000
Ok 1 voor 1 de pakketjes installeren werkt...
