Ik heb een asp pagina gemaakt en een database en beide geuploadt naar brinkster.com. Maar als ik de file uitvoer, krijg ik deze foutmelding.
Microsoft OLE DB Provider for ODBC Drivers error '80004005'
[Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified
/mccane/Memberstwee.asp, line 8
Hieronder staat de volledige asp code.
<%@LANGUAGE="VBSCRIPT" CODEPAGE="1252"%>
<!--#include file="Connections/verbindingMedic.asp" -->
Dim rsMedic
Dim rsMedic_numRows
Set rsMedic = Server.CreateObject("ADODB.Recordset")
rsMedic.ActiveConnection = MM_verbindingMedic_STRING
rsMedic.Source = "SELECT * FROM Members"
rsMedic.CursorType = 0
rsMedic.CursorLocation = 2
rsMedic.LockType = 1
rsMedic.Open()
rsMedic_numRows = 0
Dim MM_paramName
' *** Go To Record and Move To Record: create strings for maintaining URL and Form parameters
Dim MM_keepNone
Dim MM_keepURL
Dim MM_keepForm
Dim MM_keepBoth
Dim MM_removeList
Dim MM_item
Dim MM_nextItem
' create the list of parameters which should not be maintained
MM_removeList = "&index="
If (MM_paramName <> "") Then
MM_removeList = MM_removeList & "&" & MM_paramName & "="
End If
MM_keepURL=""
MM_keepForm=""
MM_keepBoth=""
MM_keepNone=""
' add the URL parameters to the MM_keepURL string
For Each MM_item In Request.QueryString
MM_nextItem = "&" & MM_item & "="
If (InStr(1,MM_removeList,MM_nextItem,1) = 0) Then
MM_keepURL = MM_keepURL & MM_nextItem & Server.URLencode(Request.QueryString(MM_item))
End If
Next
' add the Form variables to the MM_keepForm string
For Each MM_item In Request.Form
MM_keepForm = MM_keepForm & MM_nextItem & Server.URLencode(Request.Form(MM_item))
End If
Next
' create the Form + URL string and remove the intial '&' from each of the strings
MM_keepBoth = MM_keepURL & MM_keepForm
If (MM_keepBoth <> "") Then
MM_keepBoth = Right(MM_keepBoth, Len(MM_keepBoth) - 1)
End If
If (MM_keepURL <> "") Then
MM_keepURL = Right(MM_keepURL, Len(MM_keepURL) - 1)
End If
If (MM_keepForm <> "") Then
MM_keepForm = Right(MM_keepForm, Len(MM_keepForm) - 1)
End If
' a utility function used for adding additional parameters to these strings
Function MM_joinChar(firstItem)
If (firstItem <> "") Then
MM_joinChar = "&"
Else
MM_joinChar = ""
End If
End Function
<html>
<head>
<title>Members</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
</head>
<body background="AchtegrondHPM.gif" text="#FFFF00">
<p><strong><font color="#FFFF00" size="5">Members</font></strong></p>
<table width="75%" border="1" cellspacing="0" cellpadding="0">
<tr>
<td><A HREF="Detailpagina.asp?<%= MM_keepNone & MM_joinChar(MM_keepNone) & "id=" & rsMedic.Fields.Item("Members").Value %>"><%=(rsMedic.Fields.Item("Members").Value)%></A></td>
</tr>
<tr>
<td> </td>
</tr>
</table>
<p> </p>
</body>
</html>
rsMedic.Close()
Set rsMedic = Nothing
Weet iemand waar het aan kan liggen??
Dim rsMedic
Dim rsMedic_numRows
rsMedic.Open()
rsMedic_numRows = 0
Dim MM_paramName
Dim MM_keepNone
Dim MM_keepURL
Dim MM_keepForm
Dim MM_keepBoth
Dim MM_removeList
Dim MM_item
Dim MM_nextItem
End If
MM_keepURL=""
MM_keepForm=""
MM_keepBoth=""
MM_keepNone=""
End If
Next
End If
Next
End If
End If
End If
MM_joinChar = "&"
Else
MM_joinChar = ""
End If
End Function
<html>
<head>
</head>
<tr>
</tr>
<tr>
<td> </td>
</tr>
</table>
<p> </p>
</body>
</html>
rsMedic.Close()
