Waarom doet wolfenstein het niet?
  • 69 views sinds 30-01-2008
  • Meneer aard
  • Laatst online: 20:32
Meneer aard
Porsche rulez!
Een vriend van mij heeft wolfenstein vanmiddag gekregen. Hij heeft het geinstalleerd. Ik ff er naar gekeken of alles werkte, maar niet dus. Tijdens Het opstarten krijg je het scherm te zien. Keert weer terug naar windows krijg ik dit:
Wolf 1.0.0 win-x86 Nov 13 2001
----- FS_Startup -----
Current search path:
C:\PROGRA~1\RETURN~1\main\sp_pak2.pk3 (232 files)
C:\PROGRA~1\RETURN~1\main\sp_pak1.pk3 (1342 files)
C:\PROGRA~1\RETURN~1\main\pak0.pk3 (4775 files)
C:\PROGRA~1\RETURN~1/main
6349 files in pk3 files
execing default.cfg
couldn't exec language.cfg
couldn't exec wolfconfig.cfg
execing autoexec.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found Intel Pentium III
Bypassing CD checks
----- Client Initialization -----
Cmd_AddCommand: map_restart already defined
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\System32\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 32
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...35 PFDs found
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available :'( .
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem :'( .
Om een lang verhaal kort te maken geeft hij aan dat er geen 3dfx aanwezig is en ook het subsystem van opengl kan starten. Specs systeem: P3 600@600 128 mb ram, 25gb hd, Geforce 2mx400 32 mb. Win XP home.
Als de wereld vergaat; Ja dan zijn alle mussen dood:+
  • RedHat
  • Laatst online: 21:07
Download detonator drivers van www.nvidia.com, 3dfx = ander systeem als OpenGL, 3dfx != OpenGL.
  • kNarf_
  • Laatst online: 04-09-2024
Detonator drivers installeren !!!!!1111 8)7
  • Meneer aard
Meneer aard
Porsche rulez!
Waarom geeft hij aan dat er geen 3dfx is, dus ik moet de nieuwste detonator drivers hebben, dus niet van windows Xp, hier staan ze geinstalleerd als microsoft fabrikant en drivers. De instellingen van nvidia heb ik niet dus ik neem aan dat de dirver van windows XP zelf zijn.
  • Meneer aard
Meneer aard
Porsche rulez!
kNarf schreef op 13 september 2002 @ 20:41:
Dan ga ik maar detonator drivers downloaden met een 56k6 verbinding, hoelang zal ik er over doen met 10 meg?
aard: lang :) Maar er ziet niets anders op: d/l is het enige correcte antwoord. Misschien via iemand anders en ze op CD laten zetten? :)
