Oke, ik heb dus een driver gedownload die iemand me hiero heeft gegeven voor m'n geluidskaart (XpressAUDIO(TM) 16-it sound). Dat was een zip-file, en he hem dus geunzipt, nu staan er 3 bestanden, 2 txt-bestanden, en een txt-bestand met op het iccon een geel sterretje (ofzo). Dat is alles.
Hier komt de 'release'-bestand:
Version Comment
1003 Added code to make the BLASTER env variable more complete. This fixes Quake
and probably some other games running in a DOS box. Also modified the INF files
so they have no references to Creative, only work with PNPB003 and CRX0002 and
there are two INF's now. One to be used with Compaq's DRVINS.EXE program and
the other to be used on all other devices.
1004 Added code to enable MUTE for the MIDI slider control and added a fix for the
Quake 2 audio problem.
Files Changed: controls.c, init.c, mgxsb16.rc, mix_objs.c, mixer.h, cnfgmgr.h
1005 Fixed a bug that caused the midi output to mute when the user muted the wave output.
1006 Fixed the Quake I bug #1796 which was two problems. The mixer was hozing the
HW instance allocation in the system VM. Eggplant was also reseting the SB HW
which turned the CD volume off.
Files Changed: mgxsb16.asm
1007 Added ac97 codec support.
errata:
1) In the Mixer, clicking MUTE on the MIDI slider doesn't mute MIDI music.
2) In the Mixer, the mixer levels for WAVE and MIDI sources are incorrectly
coupled. Moving the WAVE slider affects MIDI output level and vice-versa.
They should be independent.
3) There are portions of the Audio Compatibility Test (ACT) that the
drivers probably won't pass.
4.06.00.
1009 Fixed problems with ACT 4.1. Updated AC97 codec controls. Fixed mixer bugs.
Changed version number to comply with PC98 requirements (See PC98 section 6.0).
Removed VOICEIN from mixer options. See README.TXT for more details.
4.06.00.
1010 Fixed ACT 4.1 wave test bug. Fixed WaveIn Record volume. Ran ACT 4.1 tests
with new BIOS. See ACTNotes.txt for more ACT details.
4.06.00.
1011 Quick release to test Motorola extended functionality - do not distribute!
4.06.00.
1012 Fixed full duplex on ACT test.
Added support for 3D, secondary mic in mixer app
New mixer layout -- completely re-done.
Fixed some mixer bugs
PROB; Tone controls are lopsided and don't work
PROB: Sometimes installing over old version causes really bad sound. Must
un-install old driver, remove .inf, and install new driver. Some registery
work in the .inf should fix this.
PROB: Mic volume is set via ac97 interface, not via SB mixer. May cause problems
on non-ac97 codec boards. VSA/extended recording controls
makes SB mixer work flakey.
PROB: Phone controls works poorly. It appears to be a hardware problem. More
investigation.
Er staat d8 ik in dat er een aantal bestanden meer moeten zijn, maar die staan er helemaal niet bij, doe ik nu iets fout of ?!?
Version Comment
errata:
4.06.00.
4.06.00.
4.06.00.
4.06.00.
investigation.
AMD Phenom II X6 1090T | 2x 4GB Kingston | Geforce GTX 560TI | Creative I-Trigue L3450
