Het niet zichtbaar veranderen gebeurd waarschijnlijk niet omdat je de active desktop op enabled hebt staan. Het volgende stukkie code heb ik ooit van
www.delphi3000.com geplukt en verhelpt dit probleempje. Let wel, het is niet mijn code, courtesy
www.delphi3000.com .
You may have noticed that using SystemParametersInfo
to change the wallpaper when ActiveDesktop is turned on
doesn't work. The reason is because you need to use
the IActiveDesktop COM interface. Using SystemParametersInfo
still works, but it doesn't update the wallpaper.
Note that the IActiveDesktop interface requires a
Shell32.dll version >= 4.71. The document titled
"Get a File Version" demonstrates how to check the
file version and uses the shell32.dll as an example.
Here is an example of using IActiveDesktop to work with
the wallpaper. It assumes that you have 3 labels on a form
and two buttons with the default names.
uses
ComObj, // For CreateComObject and Initialization/Finalization of COM
ShlObj; // For IActiveDesktop
{ The CLASS ID for ActiveDesktop is not defined in
ShlObj, while the IID is so we define it here. }
const
CLSID_ActiveDesktop: TGUID = '{75048700-EF1F-11D0-9888-006097DEACF9}';
{ Demonstrate getting the Wallpaper }
procedure TForm1.Button1Click(Sender: TObject);
var
ActiveDesktop: IActiveDesktop;
CurrentWallpaper: string;
CurrentPattern: string;
WallpaperOptions: TWallpaperOpt;
tmpBuffer: PWideChar;
begin
// Create the ActiveDesktop COM Object
ActiveDesktop := CreateComObject(CLSID_ActiveDesktop) as IActiveDesktop;
// We now need to allocate some memory to get the current Wallpaper.
// However, tmpBuffer is a PWideChar which means 2 bytes make
// up one Char. In order to compenstate for the WideChar, we
// allocate enough memory for MAX_PATH*2
tmpBuffer := AllocMem(MAX_PATH*2);
try
ActiveDesktop.GetWallpaper(tmpBuffer, MAX_PATH*2, 0);
CurrentWallpaper := tmpBuffer;
finally
FreeMem(tmpBuffer);
end;
if CurrentWallpaper <> '' then
Label1.Caption := 'Current Wallpaper: ' + CurrentWallpaper
else
Label1.Caption := 'No Wallpaper set';
// Now get the current Wallpaper options.
// The second parameter is reserved and must be 0.
WallpaperOptions.dwSize := SizeOf(WallpaperOptions);
ActiveDesktop.GetWallpaperOptions(WallpaperOptions, 0);
case WallpaperOptions.dwStyle of
WPSTYLE_CENTER: Label2.Caption := 'Centered';
WPSTYLE_TILE: Label2.Caption := 'Tiled';
WPSTYLE_STRETCH: Label2.Caption := 'Stretched';
WPSTYLE_MAX: Label2.Caption := 'Maxed';
end;
// Now get the desktop pattern.
// The pattern is a string of decimals whose bit pattern
// represents a picture. Each decimal represents the on/off state
// of the 8 pixels in that row.
tmpBuffer := AllocMem(256);
try
ActiveDesktop.GetPattern(tmpBuffer, 256, 0);
CurrentPattern := tmpBuffer;
finally
FreeMem(tmpBuffer);
end;
if CurrentPattern <> '' then
Label3.Caption := CurrentPattern
else
Label3.Caption := 'No Pattern set';
end;
{ Demonstrate setting the wallpaper }
procedure TForm1.Button2Click(Sender: TObject);
var
begin
as IActiveDesktop;
ActiveDesktop.SetWallpaper('c:\downloads\images\test.bmp', 0);
ActiveDesktop.ApplyChanges(AD_APPLY_ALL or AD_APPLY_FORCE);
end;
GA-Z170XP-SLI - i7 6700K 4.0GHz - 16GB DDR3 - Corsair 300R Wnd - Corsair CX750M - AMD 7950 3GB
